Old 02-08-2002, 03:13 AM   #1
SJwrx
Member#: 14970
1997 GF8
multi
Default Acceleration Shudder?
I have an '02 WRX, and it is my first turbo car. I rev through first, then when I shift to second something happens. When I stomp or when I ease in the gear, the power fluxuates rapidly. Is this okay?
-Rich
SJwrx is offline   Reply With Quote
Old 02-08-2002, 03:34 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
If it feels like your car is surging and bogging really rapidly, it may be the hose to your waste gate is torn. Mine was and caused enough of an over boost to make the car pull timing. The car felt like it was osscilating between on throttle and off throttle really quickly.
supermarkus is offline   Reply With Quote
Old 02-08-2002, 03:41 AM   #3
Fubaru
Member#: 6046
'08 Prius
Is it a big fluctuation in power? Have a boost gauge - if so is the boost jumping around? Or is it more of a slight fluctuation, not enough to snap your head -- some have theorized that it's caused by the tumble valve generator in the intake.
Fubaru is offline   Reply With Quote
Old 01-09-2005, 02:56 PM   #4
JimGoode
Member#: 77305
2002 WRX Wagon
Question Did this get resolved?
(Late Post on old issue, sorry, but only thing I have found that sounds identical)
I am experiencing the same thing in my 2002 WRX. It is stock, 40k mi.
SJwrx, did you get this resolved?
Background:
The problem is not consistent or really that reproducable, but it typically occurs in 2nd gear at about 1750 to 2250 RPMs with small even gas pedal. Stock option boost guage does not seem to jump up and down at all and is usually at about -.7 to 0 and rising.
Car will lope or surge/hesitate for just about 3 to 5 bursts. This is very slight power gain/loss and is not noticable to passengers on all occassions.
(There is also a "flat spot" in the accellerator, so that at high boost with full or almost full throttle, the car has power, but then letting off the gas to about <50% pedal suddenly the car seems to get TONS of power and really goes)
Are these issues related?
theories I have heard on surging: Gary's Hesitation Fix
Torn Wastegate
Air Fuel mixture problem
Timing
Can you help troubleshoot on my own before I take it to the dealer?
--jg
JimGoode is offline   Reply With Quote
Old 02-21-2005, 06:57 PM   #5
sweethang1on1
Member#: 82058
1993 Impreza
candy red
Unhappy prblem with shuddering and back firing.
Im also having a problem but with my Impreza its shuddering and back firing but timing is on, new spark plugs and wires and every thing is up to date. I would like some help if i can get it before i take it to a dealer.
sweethang1on1 is offline   Reply With Quote
Old 03-06-2005, 04:49 AM   #6
SJwrx
Member#: 14970
1997 GF8
multi
I never got it fully resolved when I had my car stock. No that it has a turboback and uppipe, its one hell of a lot better.
Rich
I never got CEL's, misfires, I just felt it.
Old 03-06-2005, 09:47 AM   #7
Knotsure
Member#: 41730
1415 Legacy/Forester
D.Grey/White
Default How many miles?
How many miles do you have on it? Have you had any work done or recent major services/repairs? How long has it been doing this? More info may help get you some help here. There are some really knowledgeable folks on these boards, but they'll need something to go on.
Knotsure is offline   Reply With Quote
Old 03-06-2005, 01:10 PM   #8
chaddeus
Member#: 56624
2004 Subaru WRX STi
I have this minor problem with very cold engine. After like say 1 mins of driving, its ok
- Charles
chaddeus is offline   Reply With Quote
Old 04-06-2005, 03:49 AM   #9
Icon25rs
Member#: 20728
2006 STI
My 02RS does it in 1st, 2nd, and 3rd, and sometimes 4th if I mash the pedal down after I put it in gear.
Icon25rs is offline   Reply With Quote
Acceleration pull to the right?? scrappydoo7 Brakes, Steering & Suspension 3 06-01-2010 10:57 AM
Odd Shudder/ thunk on acceleration from stop dobiewrx Transmission (AT/MT) & Driveline 3 04-15-2009 06:24 PM
Shuddering on acceleration kleen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-23-2008 09:07 PM
Clutch shudder while accelerating sphinx Warranty Issues & SOA Problems 5 08-07-2002 04:37 PM
