Old 02-05-2002, 12:05 PM   #1
TYPE wRx
Member#: 5510
Yellow, just like me...
Default softness hardness on cusco Zero 2s
ok, im running Cusco Zero 2s on my WRx and i cant seem to make the ride soft. its a very bumpy and harsh ride. i have it set at 5 all around. the TEINS seem a lot softer and a much more comfortable ride. What is the softest setting on this? also, what is a good way to tune these coilovers since there are so many different things that can be done. i shouldnt have baught this because of the difficulty and me not being a 100% track person yet.
tommy
sqc 010
TYPE wRx is offline   Reply With Quote
Old 02-05-2002, 12:32 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Someone can correct me if I'm worng, but I don't believe you'll EVER get a soft ride with the Cusco's because the spring rates are very high.
mav1c is offline   Reply With Quote
Old 02-05-2002, 05:09 PM   #3
Chris F
Member#: 494
2008 EVO X
I used to have these on my car. I belive that 5 is the highest damping rate, I suggest you try setting them to 1. Also, do you know what rate springs you have? If they are what Cusco sent with them, try some a lot softer. Those struts are really only good for track use (smooth track use!) I tried them for A/X and they where not the best. You might want to sell them and get different struts.
2c. from one who knows
Chris F
Chris F is offline   Reply With Quote
Old 02-05-2002, 05:38 PM   #4
r5t2
Member#: 1693
Hey are you nuts? 5 is the hardest setting!! Just kidding. 5 is the hardest tho. Try setting it at 2 all around. Setting it at 1 seems a little too under dampened for the springs (which are fairly stiff, so you could try a softer set) For the track start at 3 all around and go from there. Personally, I never felt the need to go over 3 even on the track.
Btw, these are excellent for track use and where these really shine.
ps: You could also try to adjust the travel length in the threaded strut housing to get a better ride over potholes and stuff. (Not sure if it makes a difference with really stiff springs)?
r5t2 is offline   Reply With Quote
Old 02-05-2002, 08:41 PM   #5
josh
Guest
Member#:
you will be able to get a bit more from tadjusting the rebound/compression, but not much. Cusco are certainly stiff. they were made for japanese roads that are smooth as a babys butt. not the neglected, havent been worked on in years american highways and byways.
and r5t2 is right. they make a great track setup, but unless your spending 80% of your time at the track, or absolutely MUST have a race setup all day long, then you got the right suspension. this is my opinion, so take it fwiw.
josh
Old 02-05-2002, 08:46 PM   #6
Basshead
Member#: 112
2011 Jetta TDI
I have cusco comp-2's with 392f/285r set on 3 all around and find it perfect for my tastes..wouldn't buy any other product for street use.
Basshead is offline   Reply With Quote
Old 02-05-2002, 08:49 PM   #7
BongMan
Member#: 2399
2001 Impreza RS
Question
yea play with the settings, but maybe it's too hard for your tastes. You could lift it to give the dampener more travel.
But I'd start with lowering the stiffness and then if all else fails rise up!
BongMan is offline   Reply With Quote
Old 02-05-2002, 11:38 PM   #8
TYPE wRx
Member#: 5510
thanks a lot for all the feedback, this helps and i love this set up. i havent gone to the track yet because of weather but i will be there 24/7 when the time is right.
tommy
sqc010
Old 02-08-2002, 11:56 AM   #9
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
Default Cusco Softness....?
I pm'd you, to ask, but I figured I'd post here...
So, did you lower the settings to their lowest? Much softer? Much easier to live with on NY streets?
Is it a lot softer then what you first tried?
I'm looking at buying these, but keep hearing they are way to stiff for regular street use..... in Omaha, the streets are pretty bad... pot holes and crap everywhere.... (I'm also looking at DMS 40mm with M2 spring setup)
With a coilover, I expect it to be firm, but I don't want it to make my teeth fall out either.
Any input would be appreciated
Kenneth2000 is offline   Reply With Quote
Old 02-08-2002, 12:41 PM   #10
TYPE wRx
Member#: 5510
hey kenneth, sorry, i did get ur PM but i did not chnage it yet. that is why i havent responded, i ddi not overlook ur PM. but i have played wit it a little and these r just stiff, if ur going for street/daily driving, these r alright, not that bad.. i had these on for about 2500 miles and its fine. i just feel its bumpy but its awesome. im gonna be doing a lot of track so im just looking forward to having these on the track. sorry for the late response. not much else i can tell u, but these r great, not sure if they're worth 2000, but they r nice and it is nice to say u have cusco zero2rs
tommy
sqc 010
Opinions on CUSCO Zero-2 (not R)?? Blk02WRX Brakes, Steering & Suspension 6 06-23-2003 11:06 AM
Anyone with Cusco Zero 2s in Socal That will give me a test ride tifosi77 Southern California Impreza Club Forum -- SCIC 15 11-29-2002 05:01 AM
Questions on Cusco Zero 2-R NotoriousWRX Brakes, Steering & Suspension 15 08-13-2002 12:10 PM
More on Cusco Zero 2R's JC12UZ Brakes, Steering & Suspension 6 06-14-2002 12:30 AM
Does anyone have on Cusco Zero 2R's? 1WRX2NV Bay Area Impreza Club Forum -- BAIC 3 04-28-2002 12:43 AM
