#1 |
Member#: 170532
Vehicle:07 2.5i obsidian black |
Just bought a Blitz NUR spec rear exhaust off of ebay. My question for you guys is that : this is a bolt on axelback exhaust that came off an 02 wrx. Is the exhaust pattern the same on an 07 2.5i? Will this bolt right up or do I need to modify?
Peace
#2 |
Member#: 142268
Vehicle:2004 WRX it's white. |
I'm pretty sure you will have to do slight modification like rotating the flange or something like that, like people do when they fit the STI axleback onto the N/As.
#3 |
Member#: 166498
International
Vehicle:2013 FRS SWP |
I have the spec r exhaust but mine came off an 06 wrx, i think that the subaru applications changed on the 04 and up subarus. check blitzs website though to be sure that this is accurate. Basically if it shows one model pipe from 02 and up u are set.
#4 |
Member#: 22664
should bolt on if the nurspec is designed to work off wrx stock midpipes
eitherway its 2 bolts, pretty easy to find out yes or no |
#5 |
Visiting NASIOC Timeout
Member#: 94839
SCIC
Vehicle:2005 2.5 RS PSM |
06 and 07 2.5i.. WRX axleback will match up.. the catback still wont. 05 and under.. flange needs to be slightly rotated.. which is very easy & quick at any exhaust shop.
#6 |
Member#: 170532
DO i need to reset the ecu after install?
will this in anyway harm the engine? this should gain a little power, what about gas mileage, i know it increases with catbacks, what about axelbacks? |
#7 |
Member#: 22664
no reason to reset ecu, pretty impossible to harm the engine with this, doubt youll gain any power-gas mileage - etc its just for noise
| Thread Tools | |
| Display Modes | |
| 2.5 i exhaust - blitz nur spec s - axelback - may fit others | littlebhatia | Engine/Power/Exhaust | 9 | 08-02-2008 09:45 AM |
| Will Blitz Nur spec R midpipe work with Genome axelback? | Sevaru | Factory 2.0L Turbo Powertrain | 0 | 07-07-2007 12:36 AM |
| HKS DP --> Injen SES midpipe --> Blitz Nur Spec Axelback | arco | Factory 2.0L Turbo Powertrain | 4 | 03-29-2007 04:23 PM |
| blitz nur spec axelback | 05wrxwgn | Newbies & FAQs | 6 | 07-01-2006 09:35 PM |
| Does a blitz nur spec axelback fit an STI? | blue-ej20 | Factory 2.5L Turbo Powertrain | 4 | 12-04-2003 11:38 AM |
