Old 02-18-2008, 10:40 AM   #1
Mooneyes13
Member#: 113666
60' all over you
Default How to tell if U-Joints are going? Faint clicking noise from drivetrain
While doing my clutch (exedy stg1 w/ new oem flywheel) this past weekend it seemed like my u-joints felt notchy. From previous experience working on other vesicles didn't seem like this was a good sign? I do not feel any vibrations when driving the car.
However I do hear a faint ticking noise sometimes, if I press the clutch pedal in it goes away. This is at low speeds
06 wrx, vf39, 40k
Mooneyes13 is offline   Reply With Quote
Old 02-18-2008, 12:31 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
On mine it was more of a grinding, scraping, squealing with some jerking/nudging vibration only when taking off and disappearing when load was light. Basically sounding like a rock in the brake pads, couldn't find it till it got bad enough to start thumping the tranny/drive shaft into the tunnel area.
wrxdrvr is offline   Reply With Quote
Old 02-18-2008, 12:46 PM   #3
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
I believe if you go under the car and try to wiggle the driveshaft at the U-joints and you have any play your joints are probably bad. IIRC i did this on a chevy truck once...
Good luck
Jpizzzle is offline   Reply With Quote
Old 02-18-2008, 03:48 PM   #4
Mooneyes13
Member#: 113666
60' all over you
No play
Old 02-18-2008, 08:23 PM   #5
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Doesn't seem like U joints could go bad that fast on a 06. Possible just not likely. Any other symptoms?
Old 02-19-2008, 10:07 AM   #6
Mooneyes13
Member#: 113666
60' all over you
I just hear a faint little clicking noise at low speeds, if I push the clutch in it goes away. I am just not sure what this is related too! argh
Old 02-19-2008, 11:29 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
check your trans fluid, you probably have a couple chunks of metal that used to be teeth floating around in there.
Old 02-19-2008, 12:07 PM   #8
Mooneyes13
Member#: 113666
60' all over you
I would think I would feel some clunking if i sheared some teeth.
Old 02-19-2008, 01:33 PM   #9
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Man it sucks not being there to hear the sound!
How fast is the clicking?
Does it speed up when you rev the engine in neutral?
Does it sound like it is coming from the engine bay or under the car?
What RPM range?
Loudness on a scale of 1-10?
The more info the better.
Jon
Old 01-06-2014, 02:52 PM   #10
Jacksonville's Donatello
Member#: 133451
2015 Subaru Wrx
Jon I have something similar. Mine is a 06 wrx, 150,000 miles, stock turbo, running a different map, full hks turbo back exhaust with 4 inch down pipe. Short air intake. When slowing down I sometime I hear a clicking noise and also when driving accelerating usually you do not hear it but sometimes it creeps up and it's not super loud but is noticeable. It sounds like clicking going on and if I throw it in neutral you can hear it still but usually it goes away. It comes and goes but mostly from low speed you can hear it.
Highway not to much but if I notice it I usually throw it in neutral then back into gear once and it fusses and then stops. It sounds like it's coming from under the hood. I recently replaced my right cv axel because the inner boot went bad and was making a clank noise when in first and taking your foot off the gas provoking the car to jerk backwards and you would hear a clank. After searching for the issue I thought maybe my bad cv axel was the issue. So I replaced it Saturday actually and it got rid of the 1st hard jerk back noise after releasing your foot off the gas abruptly but I still can hear from time to time the clicking noise going
On. I may need someone to ride with me to figure this out but it's very annoying. Any ideas?
Jacksonville's Donatello is offline   Reply With Quote
Old 01-06-2014, 03:00 PM   #11
Member#: 133451
2015 Subaru Wrx
The clicking sounds pretty synced like fast but not as fast as I'm driving to be exact. If I rev the engine in neutral while driving it happens it doesn't really raise the sound of it but usually right after that it fusses for a sec and then it stops. I never had to rev it to stop it though it just does once I throw it in neutral usually. On a scale of 1-10 in sounds loudness I would say fairly an 4 maybeee.
In neutral I can rev the engine slowly higher and at any rev meter point and there isn't even a trace of the sound. I can really hoarse it loudddddd as well and hold it and not one trace of the sound. It's only when driving and mostly happening when slowing down. It doesn't do it as I speed up just will randomly start when cruising so I've been riding
With no music so I can catch it. Still factory shifter and all that. Clutch was replaced about two years ago but to be honestly the guy who did it was not qualified in my
Opinion to do it. Found out later this. He was a
Friend of my wife's family who just got out of prison and needed work and was well reputable once before so I figured I would let him do it to help him get on his feet. Bad choice because he had all kinds of problems along the way due to lack of proper work environment and tools. It didn't make any sounds like this though after that was done. This started about 3 months ago and has continued randomly since but not a day goes by I don't
Hear it!
Old 01-06-2014, 03:02 PM   #12
Member#: 133451
2015 Subaru Wrx
Oh yea it does sound like it's coming from under the hood somewhere though or maybe under the car in that area but it's hard to pin point being it only happens when I drive
Old 01-08-2014, 09:12 AM   #13
Member#: 133451
2015 Subaru Wrx
Any new information?
Old 01-08-2014, 11:02 AM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Get under the car and shake the driveshaft around. If you feel any play it's time for new u joints....which means a new driveshaft.
Tony
Old 01-08-2014, 01:45 PM   #15
Member#: 133451
2015 Subaru Wrx
Originally Posted by Turn in Concepts View Post
Get under the car and shake the driveshaft around. If you feel any play it's time for new u joints....which means a new driveshaft. Tony
Ok thank you tony, I'll give that a whirl and see what's up. Thanks!
How to tell if top hats are Group N's? nikiter Newbies & FAQs 11 07-27-2009 10:49 PM
How to tell if your pants are too low rubelcon Off-Topic 11 09-17-2008 12:40 AM
How to tell if my knuckle/wheel bearing are toast? Kwyjibo Transmission (AT/MT) & Driveline 2 05-06-2005 01:16 AM
How to tell if a sti uppipes flex joint is bad ronnyek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-23-2005 02:27 PM
how to tell if my Rota Battles are hubcentric? balajc Tire & Wheel 2 04-16-2004 10:45 AM
