Closed Thread
Old 02-18-2008, 02:58 PM   #1
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Default 07 STi with 8cm FP Green, EWG, headers, etc... 750cc or 850cc injectors?
I know the 07 STi fueling is a little different than its 04-06 STi counterpart, and I'm trying to decide on injector sizing for my setup. I'm deciding between Deatschwerks 750cc or 850cc top feed injectors. The 750cc are cheaper and I think they'll do the job, but I'd hate to find out I was wrong when my car's strapped to the dyno.
First, are there any drawbacks to going larger like difficulty of tune or rougher idle?
And finally, what do you think for this setup:
07 STi
3"/8cm FP Green
APS 70mm CAI
APS Turbo Inlet
APS DR525 FMIC
TGV Delete
Perrin Headers
TurboXS EWG Uppipe
TiAL 44mm EWG
HKS Downpipe
APS Catback
Walbro Fuel Pump
___cc Injectors?
I will be running an Aquamist water/meth injection setup as well but I dont want to have to rely on it in order to not run out of fuel.
If you can, please post reasoning to go along with your answer, or past experience with similar setups. Unfortunately I know the 07 STi specific stuff isn't as widespread.
TROLL is offline
Old 02-18-2008, 03:11 PM   #2
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I had 860cc injectors on my stock turbo 05 sti setup and it ran perfectly. I would strongly recommend that you go 860.
dexterous is online now
Old 02-18-2008, 03:25 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
i would personally go for headroom.
good to know. i just picked up a set of pe850s to go into my car with the stock turbo
nhat is offline
Old 02-18-2008, 05:04 PM   #4
PowerTrip
Member#: 158674
'15 STi Limited
I run DW850's on my stock turbo stage 2 set-up and it runs perfectly and idles smoothly. Headroom FTW
PowerTrip is offline
Old 02-18-2008, 05:45 PM   #5
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
I agree here.
Get a different DP though....
jordanretro1223 is offline
Old 02-18-2008, 05:50 PM   #6
subenerd
Member#: 72630
2004 STi
You need to ask your tuner.
subenerd is offline
Old 02-18-2008, 06:05 PM   #7
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
Originally Posted by jordanretro1223 View Post
I agree here.
are you telling me to get a different downpipe? i specifically chose to run this downpipe with my EWG setup because it reduces turbulence that would be caused by a bellmouth (which would be necessary for internal wastegate, but not for me). i even went as far as having a tab welded onto it to block off the internal wastegate area of the turbo since it is not being used.
thanks for the responses... seems that the 750cc should be fine but also sounds now like there are no drawbacks to the 850cc except for being $100 more.
TROLL is offline
Old 02-18-2008, 06:11 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
i know of a performance shop selling a set of helix 820cc topfeeds for $100 if you're interested.
nhat is offline
Old 02-18-2008, 06:36 PM   #9
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
+1 on that your tuner has to work with your goals ask your tuner what he/she prefers to tune.
I have modded OEM's to 920cc's and I idle at about 900rpms but its a smooth idle nothing rough about it.
4ST-AIR is offline
Old 02-18-2008, 08:34 PM   #10
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Alright well I stand corrected then bro. That seems like a good setup then. And since you are doing an EWG your plan makes perfect sense.
Good luck with the build.
Old 02-18-2008, 10:09 PM   #11
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
thanks...
i was waiting to hear back from my tuner and now i did... he said either should be fine but like what was said here, there arent any real drawbacks to going bigger.
TROLL is offline
Old 02-18-2008, 10:35 PM   #12
iRace559
Member#: 142654
2007 OBP WRX RA 1-4
Built Motor DOM3XT-R :)
Pmmed.
iRace559 is offline
Old 02-28-2012, 11:27 PM   #13
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
Get some 1000cc and call it a day, Gives you good head room if you want to go bigger or switch to race fuels later on
StupidFastWagon is offline
Old 02-29-2012, 01:47 AM   #14
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
thanks...
It really depends on your power goals as to whether 750's or 850's would be better for your setup. IMO if you are going to shoot for 400+ you should go 1000's leave yourself plenty of headroom to upgrade later down the road, and keeps your IDC's down. 850's are going to be pushed more than the 1000's, but you will definately run out of fuel on 750's before you run out of turbo.
2Fast4U1DAY is offline
Old 02-29-2012, 09:29 AM   #15
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
1. This is 4 years old. 4 years?!
2. How and why did you chime in after so many other responses? After 4 years.
3. The car just got tuned, with results posted in the PPB.
Shocked.
Zee Biker is offline
Closed Thread
750cc or 850cc Injectors? Coop1103 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 10-24-2009 06:27 PM
07 STI FP GREEN EWG 370/388 @23psi Slimsti Proven Power Bragging 25 03-20-2009 09:04 AM
WTB: Injen CAI, 750cc or 850cc Injectors Sideways76 Private 'Wanted' Classifieds 2 01-29-2009 07:31 AM
fp green, ewg, fmic, injectors, gauges, etc Almost_there_1 Engine/Power/Exhaust 61 08-16-2008 02:17 AM
Looking for an FP Green & a set of 750cc or 850cc injectors 03SuBbYWrX Private 'Wanted' Classifieds 3 10-24-2007 07:23 PM
