Old 02-18-2008, 05:49 PM   #1
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Default Another - Cant get LC-1 readout in romraider
Innovate software sees it, ramraider giving me zeros, checking,unchecking , reboot etc etc, NG, any other software I can use that will intergrate my LC! easily?
Cheers
Kastley85891 is offline   Reply With Quote
Old 02-18-2008, 07:38 PM   #2
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
did you pick the right comm port under "plug-ins"
Casey is offline   Reply With Quote
Old 02-18-2008, 08:30 PM   #3
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
yeah-looks like I needed a fresh install of test release just did that with defs etc and already have Logworks files in the enginuity folder-Ill go out later and plug up to see
Old 02-18-2008, 11:24 PM   #4
quazimoto
Member#: 70395
You need to use the LC-1's software and set the fuel to gasoline.
quazimoto is offline   Reply With Quote
Old 02-18-2008, 11:44 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
1) Use LogWorks2 to figure out which COM port the LC-1 is on and verify that it's outputting data
2) Use LM Programmer to set the fuel type to Gasoline
3) Launch RomRaider logger
4) Under the Plugins menu, select Innovate LC-1 and set the port to the correct COM port
5) Check the LC-1 item in the logger's Data, Graph, or Dashboard view
You only have to do 1 and 2 once per reset of the LC-1, but 4 and 5 have to be done IN THAT ORDER every time you launch the logger
Old 02-19-2008, 01:51 AM   #6
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Thanks - will do this tom evening and report back - Im cool up to step 5 today but nothing logged, like I said I reinstalled Eng test tonight from scratch - it automatically knew I had the innovate SW installed so Im feeling confident, thanks again - This Forum wins
Old 02-20-2008, 02:07 AM   #7
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Weird, got to reinstall my logiworks software, reset up the LC-1, close the setup software then follow the procedure for com port and high lighting via Rom raider, runs and logs fine, next time I try, back to NG until I follow the whole re install etc etc, must be a vista thing...
So started of with 9.0:1 at WOT and some CEL's for missfire, prob due to teh richness, first revision begeed a 10.0:1 so getting there, no missfires, gonna throw up a few logs on Rom raider if any one interested.
Old 02-20-2008, 07:54 AM   #8
quazimoto
Member#: 70395
Make sure you are not logged in as an administrator.I think it is a Vista thing.
Cant get Romraider to upload onto laptop? liv4psi Newbies & FAQs 18 05-26-2010 03:31 AM
Can't get Romraider to recognize LC-1 MMWRX Open Source Reflashes 6 11-16-2008 10:47 PM
Romraider LC-1 download Geek Guy Open Source Reflashes 1 05-21-2008 11:51 AM
Best Location for a LC-1 WBO2 Sensor for RomRaider Logging? williaty Open Source Reflashes 16 03-10-2008 11:46 AM
Cant get my motor back in... HELP! nperkins Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-19-2007 11:57 PM
