Old 02-18-2008, 07:43 PM   #1
ab0z
Member#: 126473
1978 Datsun 280z
Question What is this valve?
The other night I had been working on my car, and on the way home I stopped for gas. when I started my car after I filled up, it stalled immediately. My buddy and I popped the hood to look for a reason why it wouldn't stay running, and found this:
When we found it, the part that the hose attaches to was broken off in the end of the hose, and whatever genius was responsible had used electrical tape to hold it up to the spot where it should be. (I removed the tape to get a better look at it.)
My question is this: What is this valve called, and what does it do? I need to order a replacement, but I don't know what it's called, and I don't yet have a Factory Service Manual for this car.
Any help is appreciated!
ab0z is offline   Reply With Quote
Old 02-18-2008, 08:27 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I think that's a vapor purge control solenoid. Or something or that nature.
Tim Sanderson is offline   Reply With Quote
Old 02-18-2008, 08:30 PM   #3
ab0z
Member#: 126473
1978 Datsun 280z
So it's part of the evap. system then?
Old 02-18-2008, 09:24 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
whats it attached to? A vac tube? sense line? whats that attached to? Use some common sense to see what its sensing/controlling/etc. Not trying to sound like a dick, just trying to help and maybe give you a pointer. On that note, I have no idea what that is. :-)
Old 02-19-2008, 04:31 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yup.... that's what it is. Since it broke off, you have a vacuum leak. Plug the hose and don't worry about the sensor. Mine's been that way for years.
Jay Storm
Old 02-19-2008, 04:40 PM   #6
ab0z
Member#: 126473
1978 Datsun 280z
Thanks for the help guys!
I will check the cost on the valve, if it's too expensive I'll just do as you suggested.
Old 08-22-2008, 07:34 AM   #7
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
just to correct things, that is the airconditioning assist valve IIRC. One side goes to the intake tube, pre throttle plate. The other side goes to the intake manifold, post throttle plate. It is energized when the A/C is commanded on and lets calculated air past the throttle plate to assist in idleing.
turboL is offline   Reply With Quote
Old 08-22-2008, 12:16 PM   #8
ab0z
Member#: 126473
1978 Datsun 280z
Thanks for the information. I've been driving my Z all summer but I'm about to get the ol wagon ready for the winter season, and this is on my list.
Old 08-22-2008, 02:29 PM   #9
kay95
Member#: 45494
95 impreza L awd
green
+1
Though I dont think the ECU and control it. It is a on/off only valve. If you take it apart the top is threaded into the body to a plunger. Kinda like a needle valve. Though I dont know if you can adjust idle with that because the ECU might send a higher PW.
May I say this is a good wire to tap for a Boost control solenoid if you have no AC because it has switched 12v on all times.
kay95 is offline   Reply With Quote
Old 10-25-2008, 10:54 PM   #10
mandarin
Member#: 192579
95 Impreza 1.8
Anyone know the part number for this valve? I need one for the same reason.
Thanks -JonB
mandarin is offline   Reply With Quote
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 04:08 PM
What is this valve and should it buzz when I tap it? neo-sti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-16-2007 12:51 AM
What is this part in my fuel system. Can I remove this STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-06-2003 12:07 PM
what is this? is it a good deal? coilovers cheap? mcu81 Tri-State Area Forum 17 01-01-2002 11:24 AM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 09:53 AM
