Old 02-18-2008, 10:53 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Consequences of Changing AF Learning Ranges?
So the AF Learning #1 ranges on my ROM are 0-4.5, 4.5-10, 10-22, and 22+. Idle learning fluctuates HUGELY (often more than -10 to +10) depending on the amount of heat soak. This would be fine if idle were confined to AF Learning #1 A. However, when the defrost kicks the AC on, it jumps up to about 4.7-4.9g/sec until the compressor cycles off again. This is just enough to skew the AF Learning #1 B value enough to make it totally wrong for the 5-10g/sec range.
Is there any reason not to alter the AF Learning #1 Ranges map to make A and B 0-5, 5-10 instead of the current map? This would confine the heat soak at idle Leaning changes to, well, idle.
2002 WRX problem with AF learned values... Chi_San Open Source Reflashes 4 10-13-2009 02:15 AM
AF Learning +14.99 ZR2_S10 Commercial ECU Reflashes 1 09-17-2007 09:38 PM
What are the consequences of pulling the ebrake on snow/asphalt? AndyRoo Brakes, Steering & Suspension 10 02-19-2003 03:17 PM
Fuel & Ignition Timing - Consequence of using MBC or UNICHIP? 02WRX_BLUE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-03-2002 04:54 PM
Consequence of having Turbo-back system malelee21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-09-2001 01:01 AM
