Old 05-01-2009, 12:27 AM   #1926
WRKX
Member#: 28402
2005 STI
CGM
I need some 2010 STI info or I'm buying an EVO No...really.
WRKX is offline   Reply With Quote
Old 05-01-2009, 09:33 AM   #1927
eps105
Member#: 205153
2014 Forester 2.5i
Venetian Red
SOA Blog: What can one do to ensure they get an invitation to a Legacy/Outback comparison test drive if/when they are scheduled? I am not a current Outback owner (I have a Forester) and want to make sure I am included.
5 or 6 years ago, when the previous gen Outback was released, SOA held a comparo in Philadelphia in the parking lot of the Philadelphia Park Racetrack. I remember driving a 3.0 and a 2.5XT with my wife, and some competing vehicles IIRC. It was a great experience. I hope SOA is doing this again.
eps105 is offline   Reply With Quote
Old 05-01-2009, 09:53 AM   #1928
Verwilderd
Member#: 185217
2008 Legacy GT
Poop Brown Metallic
Sign up for alerts on Subaru.com and also, if you're not signed up for mysubaru.com, I would do that as well. That way you'll be informed of upcoming Subaru drive events.
Verwilderd is offline   Reply With Quote
Old 05-01-2009, 12:25 PM   #1929
whoosh
Member#: 40989
OT vag inspector
they should have warehouse/pre-test at the westampton warehouse and free food like the first two i went to.
whoosh is offline   Reply With Quote
Old 05-04-2009, 01:44 PM   #1930
whoosh
Member#: 40989
OT vag inspector
i like the old 3.0r rims better
Old 05-04-2009, 02:39 PM   #1931
Sub!eDr!ver
Member#: 88924
2007 Tribeca Limited
05 LGT (98 LGT, 88 Justy)
I have a safety question for SOA Blog: Why is the throttle delay built into the ECU? I've had one instance where I almost got nailed by a truck because the throttle didn't react quickly enough.
I'm sure it's only a half-second delay (maybe less), but when a big truck is bearing down on you, a half-second can feel like an eternity.
I noticed it both in my '05 Legacy and my '07 Tribeca. With the 5MT Legacy, it's easier to offset the delay by just delaying clutch engagement until the engine responds. With the auto tranny in my Tribeca, it makes for a lurchy ride when transitioning from deceleration to acceleration (which happens way too often in rush-hour traffic).
Also, why the 2-second delay when shifting from Neutral to Drive? I sometimes pop it into neutral to avoid having to hold back the Tribeca so much at red lights, then pop it back into drive when the light turns green. The extended period of no throttle response makes other drivers get irritated that I haven't gone anywhere when the light turned green.
These delays seem excessive, and occasionally prove dangerous. Is there a way for the dealer to reduce or remove these throttle delays?
Sub!eDr!ver is offline   Reply With Quote
Old 05-05-2009, 12:33 AM   #1932
fishandring
Member#: 124042
2012 VW Golf TDI 2dr
2013 Mazda CX5
I know a way for you to not have the delay. Don't put your car in neutral at a light. That's just plain dangerous...
fishandring is offline   Reply With Quote
Old 05-05-2009, 12:50 AM   #1933
subySerb
Member#: 155411
not really if it's on level ground
subySerb is offline   Reply With Quote
Old 05-05-2009, 12:52 AM   #1934
phoenix96
Member#: 14148
2006 Legacy GT Ltd
2011 Outback 3.6R Ltd
I don't understand this. You don't want to press the brakes when you're stopped at a red light?
phoenix96 is offline   Reply With Quote
Old 05-05-2009, 01:27 AM   #1935
naimouasta
Member#: 47998
2002 WRX Wagon
2008 Legacy QSM
+1! the throttle is slow and makes driving slow/annoying/dangerous. throttle is so slow you have to let off the throttle a little under half a second before stepping on the clutch and grabbing the next gear. doing it this way allows the rpm's to drop to the correct place in the next gear. if you just drive it like a normal (cable throttle) car by letting off the throttle, clutch in and shift right away, the rpm's hang and the rpm's won't be at the correct shift point (rpms too high) in the next gear. slow throttle response also sucks when i want to blip the throttle on downshift; my cousin's mini cooper s is even worst at this.
only reason i see for this delay is for smoothness?...because the car/engine definately does not react to the smaller inputs of the pedal. one of the reasons why i love my 2001 impreza rs, it does what i want it to, and smoothness is based on driver skill.
naimouasta is offline   Reply With Quote
Old 05-05-2009, 11:53 AM   #1936
Sub!eDr!ver
Member#: 88924
It's mainly when the engine is cold and idle is boosted to 1500 rpm - my 'beca is trying to go when I don't want it to, so I pop it into neutral.
What's really odd is that in Drive, idle is at 1500 rpm, but in neutral it drops to about 700-800. When it finally warms up, idle in Drive drops to 700-800.
Old 05-05-2009, 01:22 PM   #1937
DrKev
Member#: 208161
Red
That's assuming you are able to accurately judge that you are (or are not) on level ground. That ability is not a given.
DrKev is offline   Reply With Quote
Old 05-05-2009, 01:39 PM   #1938
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
^^Hopefully he still has the brake on when in neutral.
I sometimes turn my car off entirely at long lights. I just watch the cross traffic's light and restart my car when it turns yellow.
Mike Wevrick is offline   Reply With Quote
Old 05-05-2009, 01:40 PM   #1939
Sub!eDr!ver
Member#: 88924
Brake pressure to hold a stop while in neutral is a lot lighter than brake pressure required while in Drive, especially at high idle.
Checking for level ground is easy - let off the brake, if you start to roll, reapply brake.
Besides, most manual-tranny drivers pop it out of gear at lights. What's so different about doing it with an auto?
Old 05-05-2009, 09:32 PM   #1940
WRKX
Member#: 28402
2005 STI
CGM
SOA - 2010 STI? Info please.
Old 05-05-2009, 09:53 PM   #1941
BigElm
Always under your radar!
Member#: 1568
^ They don't discuss future products.... (for the umphteen time).
BigElm is offline   Reply With Quote
Old 05-06-2009, 09:25 AM   #1942
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
IBmorecupholders (now with 100% more illumination!)
Spenk is offline   Reply With Quote
Old 05-07-2009, 01:47 PM   #1943
KURB21
Member#: 4690
2014 FXT
Default 2009 STI pricing/sales
While I know it is not possible to say "yes" or "no". Do you know if the 2008 STI end of year deals from last November are a once in a lifetime thing or is there a chance it could happen again this year? Heuberger Subaru in CO. Springs was very aggressive in their sale of those cars and was wondering if it may happen again. I have noticed that my local Subaru dealers do not seem to be carrying the STI in nearly the quantities they did last year, which worries me...since the 08 fire sale seemed to be due to overstock. Thanks for your time.
KURB21 is offline   Reply With Quote
Old 05-07-2009, 02:30 PM   #1944
SOA Blog
Member#: 171797
How can we say yes or no, without saying yes or no?
SOA Blog is offline   Reply With Quote
Old 05-07-2009, 02:31 PM   #1945
SOA Blog
Member#: 171797
Can't speak specifically for Tribeca, but I do know that a lot of 1st gears are very tall now to aid in emissions testing.
Old 05-07-2009, 02:36 PM   #1946
HB_Dad
Member#: 45190
2014 Impreza Sport L
You can say either:
"We have made a decision already but can't discuss it"
or
"We have NOT made a decision yet"
HB_Dad is offline   Reply With Quote
Old 05-07-2009, 02:51 PM   #1947
SOA Blog
Member#: 171797
Originally Posted by HB_Dad View Post
You can say either:
or
And neither makes you more informed.
Old 05-07-2009, 02:52 PM   #1948
Sub!eDr!ver
Member#: 88924
No, we were talking about the throttle delay built into the ECU.
I hear that the delay can be removed from the Legacy and Impreza via EcuTek or AccessPort. Custom tune.
Old 05-07-2009, 03:21 PM   #1949
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
SOA Blog,
2010 Forester pricing came out...any timetable on 2010 Impreza?
Old 05-07-2009, 03:27 PM   #1950
SOA Blog
Member#: 171797
SOA Blog,
q
No, not yet.
GM goes for hip with shotgun blog NYCshopper Non-Subaru News & Rumors 5 01-31-2007 07:21 PM
