#1 |
Member#: 2196
I was wondering if anyone knows where I could screw temperature and oil sender units into the engine block?
#2 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
You wrote:
"oil and temperature sending units." Are you talking about oil pressure sender and oil temperature sender? You can screw in the oil pressure sender under the alternator. See here: http://www.geocities.com/matsut_rpi00/autometer.html You can weld in the oil temperature sender to the oil pan for the accurate temperature. However, I don't see why you can't use the same hole as the oil pressure sender to pick up oil temp. I guess it won't be as accurate. |
#3 |
Member#: 2196
ahh... thank you, I meant oil pressure (which I now know) and water temperature. So does any one know where the water temp sensor would go?
#4 |
Member#: 6
Vehicle:2007 BMW Z4 M Coupe Interlagos Blue |
FWIW, RalliSpec installed a water temperature sensor in the return "piping" which runs on top of the block, under the intake runners. Don't know if it's worth all the work for you, but mine was already apart, so installation was fairly easy for them.
Steve<br> http://www.forcefed4.com/ |
| Thread Tools | |
| Display Modes | |
| Oil temperature sender for OEM gauge kit | kegard | Electrical & Lighting | 1 | 10-05-2007 09:06 PM |
| Oil pump plugs good location for Oil pressure sender? | jsnuff1 | Factory 2.5L Turbo Powertrain | 10 | 06-26-2007 08:01 PM |
| Sandwich Adaptor for Oil Pressure & Temperature Senders | WRX05noob | Newbies & FAQs | 1 | 05-24-2005 07:38 AM |
| Oil Pressure Sender Location | Ramon_12345 | General Community | 5 | 12-31-2004 11:18 AM |
| oil pressure sender location on 04 STi | t00r t0g | Interior & Exterior Modification | 2 | 11-13-2004 11:49 AM |
