Old 02-21-2008, 03:11 PM   #1
SubarNoober
Member#: 133261
Default Advice on timing belt parts, i.e. belt tensioners on EJ22
Had any good or bad experience with various brands of:
1) timing belts
2) tensioners
3) water pumps and other typical replacements while in there?
I've seen this kit at partsamerica. SKF makes a reasonable quality bearing, which is most of, but not all of a tensioners wear parts:
http://www.partsamerica.com/ProductD...pe=460&PTSet=A
They also had a "gatorback", which I think is made by goodyear, but don't know anything about the quality of the line.
SubarNoober is offline   Reply With Quote
Old 02-21-2008, 06:10 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
The SKF bearing is good...but the hyd. piston on the tensioner is the most important thing to ensure is good. OEM is probably best for this.
I've used ebay timing belts with no problems. I've never seen a "gatorback" style gilmer (toothed) belt....only ribbed, which happen to be pretty good.
Subaru Timing Belt Kit w/ Idlers & tensioner treeoflife Engine/Power/Exhaust 4 06-15-2009 08:57 PM
center timing cover and a/c belt tensioner madkayaker Private 'Wanted' Classifieds 6 03-14-2008 12:05 AM
Tension on power steering belt PHustle Newbies & FAQs 0 05-30-2007 10:12 AM
Timing belt issue- can't pre-load tensioner *pics* imprezdgc8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2006 08:55 PM
replacing timing belt tensioner on legacy? bugeye829 Normally Aspirated Powertrain 14 03-23-2005 11:38 AM
