Old 02-21-2008, 04:33 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default HELP - Broken down on side of road - PLEASE READ!
The car is a 2001 Legacy GT 5 SPeed with near 140K miles. The until today the car ran great.
The car was driven to work and parked. The 30 mile drive to work was completely uneventful. Now, its in the parking lot and wont run. It cranks strong (batter is good) and starts for a sec but then it dies. There are no obvious hoses or electrical connections that have popped loose.
UPDATE (SOLVED): The car was not getting good spark. I reseated all of the wires connecting to the coil pack and it fired right up.
dexterous is offline   Reply With Quote
Old 02-21-2008, 04:41 PM   #2
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
check the timing belt
PDLTURBO is offline   Reply With Quote
Old 02-21-2008, 04:49 PM   #3
Naito
Member#: 114263
2014 Forester XT
idle air control valve?
Naito is offline   Reply With Quote
Old 02-21-2008, 04:52 PM   #4
SubyMass
Member#: 136493
2015 WRX
GBP
Check fuel pressure- not sure on these engines but most have a schradder valve on the fuel rail.
Check spark by pulling a wire and sticking a screwdiver in it also touch ground so you can see arcing when you crank.
Intake cleaner/starting fluid is always a trusted friend when broken down. My old truck had 50-55 psi fuel pressure (which is good for most cars) but because chevy was trying something new in the early 90's, the truck needed 61psi to start, so a quick blast started her every time.
Stupid question, but did you check oil level/pressure?
SubyMass is offline   Reply With Quote
Old 02-21-2008, 04:57 PM   #5
piker28
Member#: 22664
Ok so first, get the sti up in the air, remove engine - trans - and read diff...
begin to insert these all into said broken down legacy than that = happy banana sleeper!
piker28 is offline   Reply With Quote
Old 02-21-2008, 05:05 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Unplug the MAF and start it. If it stays running...you probably got moisture built up in the MAF causing it to freak out. In this case, go pull the MAF off the 97 wagon and put it on to get you home.
Jay Storm
Old 02-21-2008, 05:34 PM   #7
dexterous
Member#: 23553
2014 WRX - Daily
Its not the timing belt unless it randomly skipped a bunch of teeth.
I will pull the plug off of the MAF to see if that changes anything. I am not sure how to check the fuel pressure without a gauge. Any ideas?
Old 02-21-2008, 05:35 PM   #8
dexterous
Member#: 23553
2014 WRX - Daily
By the way, you guys rock, thanks for the fast replies.
Old 02-21-2008, 05:52 PM   #9
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
I would say the MAF also.
swede978 is offline   Reply With Quote
Old 02-21-2008, 07:05 PM   #10
subywuby45
Member#: 168078
push it down a hill in third gear with the clutch in and pop start it, if it doesnt start after that then I dont know what it could possibly be.
subywuby45 is offline   Reply With Quote
Old 02-21-2008, 07:22 PM   #11
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
he said it starts then dies. its not his starter.
quadtard is offline   Reply With Quote
Old 02-21-2008, 07:51 PM   #12
jeisen
Member#: 27258
who dat be dat was?
we had a similar problem happen in one of our non-subarus recently. Drove fine when we parked it. Started it up and the fuel pump wouldn't turn on. It started for a second and once the fuel in the fuel lines was gone, the car wouldn't turn back on.
jeisen is offline   Reply With Quote
Old 02-21-2008, 09:00 PM   #13
dexterous
Member#: 23553
2014 WRX - Daily
I got it running again. It was not getting spark so a bit of terminal cleaning was all it needed. Strange that it would die like that. The only unfortunate part is that I ripped the living crap out of my 97 L to get a ton of spare parts before I made the 30 mile trip to the car. It took me three times longer to take the L apart that it did to fix the LGT. O well, at least its all working. Thanks again guys, that was an awesome response!
have you ever seen a subaru broken down on the side of the road? fiveoh88 General Community 129 07-15-2015 11:18 PM
Car is DEAD on side of road :(:( Please help. Superorb South East Region Forum 30 02-27-2009 10:26 PM
Girl killed while watching boyfriend change tire on side of road smithsmithy Off-Topic 52 10-27-2008 04:45 PM
mobile smog check on side of roads? sc0013z Texas Impreza Club Forum -- TXIC 14 03-21-2007 08:46 AM
sti on side of road vtecTHIS Mid Atlantic Impreza Club -- MAIC 0 07-25-2004 04:48 PM
