Old 02-21-2008, 06:53 PM   #1
subywuby45
Member#: 168078
Default 2006 engine trouble
Hi there fellow subaru owners, I am in desperate need of help, no one I know can determine what is wrong with my subaru. Ill give you some background information first. I bought my car from and older man who drove it gingerly; It is a 2006 2.5rs impreza with right around 60,000 miles. Ive had it for a couple of months now. When I drive her I drive her fairly hard, every shift is around 3000 rpm. I also drive it really hard at least once a day(Ive been doing this for about a week or two), when I do this I go to a windy community and ill run my car (its bone stock) for an hour maybe hour and a half at full out racing speed, shifting past 4000 rpm on every shift, trying to get as much power out of the engine as possible, and cornering very hard. Anyway its time to cut to the chase, hears the problem: One day I start my car to go drive it somewhere and everything seems fine, then I start to speed and drive faster and faster (I live in the middle of nowhere) Its then that I realized that the power seemed to fall off the higher I got in the gear, so everytime Id shift Id look at the rpms and they looked too high for the amount of fall off I was feeling at the middle to end of the gears. I also realized that right after I shifted no matter how high the rpms and how quickly I got back on the gas the engine seemed to pick up and accelerate noticably slower, also the gears feel longer, noticably longer. Please, I need help.
subywuby45 is offline   Reply With Quote
Old 02-21-2008, 09:32 PM   #2
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
ummm.....yeah....
Subyroo2.5 is offline   Reply With Quote
Old 02-21-2008, 09:40 PM   #3
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
Your gear ratios aren't changing, and shifting at 3k is not driving fairly hard. And 4k isn't "really hard." Other than that, I don't know what to say. Your car is fine.
SilverSubie2.5 is offline   Reply With Quote
Old 02-21-2008, 11:16 PM   #4
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
60,000 miles on an 06? jesus my 06 has 27,000 and i thought that was a lot.
jordan s is offline   Reply With Quote
Old 02-21-2008, 11:25 PM   #5
piker28
Member#: 22664
my 04 is about to turn 30,000 and i thought it was alot ha
piker28 is offline   Reply With Quote
Old 02-22-2008, 12:15 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Bad tank of gas pulling timing?
And I'm WOT to fuel cut all day every day. You're babying that damned car.
Old 02-22-2008, 08:36 PM   #7
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
you change gas station/brand? Log it if it keeps up.
RaceFaceXC is offline   Reply With Quote
Old 02-22-2008, 09:55 PM   #8
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Weaksauce, I'm about to hit 31k
Counterfit is online now   Reply With Quote
Old 02-23-2008, 07:52 PM   #9
zavier
Member#: 141189
2007 Impreza 2.5i
Newport Blue Pearl
psh 2007 just topped 34k
also is this an auto or a manual? just wondering...but could it be your cat? just had to have a cat replaced on a saturn that didn't seem to want to accelerate and the rpms were just to high (auto) turned out the cat was bad/clogged.
zavier is offline   Reply With Quote
Old 02-24-2008, 10:30 AM   #10
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
i was thinking cat also, but thats really bad if the cat is toasted already... maybe driving it so easy isnt good for the cat?
Old 02-24-2008, 12:17 PM   #11
dan13
Member#: 157726
hunk of metal
ummm he thinks 4k is hard?
dan13 is offline   Reply With Quote
Old 02-24-2008, 01:38 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Do you think it's possible your clutch is beginning to go? Smell anything?
Tim Sanderson is offline   Reply With Quote
Old 02-24-2008, 03:29 PM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
That was my first thought, too.
Jon [in CT] is offline   Reply With Quote
HELP 2006 engine troubles subywuby45 Service & Maintenance 5 02-21-2008 09:38 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain 3 01-14-2003 09:04 PM
engine trouble yukon General Community 1 10-17-2002 07:19 PM
WRX Engine troubles subarugt Factory 2.0L Turbo Powertrain 0 09-19-2002 10:38 AM
'00 Legacy GT engine trouble... Kostamojen Legacy Forum 1 09-13-2002 03:05 AM
Message Board Statistics All times are GMT -4. The time now is 07:11 PM.
