Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-22-2008, 11:32 AM   #1
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Default STi headgaskets?
I am doing cams in my 05 RS and am thinking of doing STi headgaskets to up compression. What kind of a difference in power will I see? What are the pros and cons.
Thanks!
Gr3en is offline   Reply With Quote
Old 02-22-2008, 12:22 PM   #2
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
What are the physical differences in the EJ257 headgasket versus the stock one for your EJ253? Thicker, thinner, different material? I saw your post over at 2.5rs and was curious.
LTracer is offline   Reply With Quote
Old 02-22-2008, 12:39 PM   #3
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
The STi gaskets are thinner, about half thickness on the RS gaskets.
Old 02-22-2008, 01:16 PM   #4
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Any thoughts guru's?
Old 02-22-2008, 01:53 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I thought that the PHASE 2's are all the SINGLE layer HG??
The '96-'99 2.5L DOHC HG are THICK. '99-'01 2.5L SOHC are a SINGLE THIN HG. I remember seeing the STi HG and it's not THIN at all.
FuJi K is online now   Reply With Quote
Old 02-22-2008, 03:05 PM   #6
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Huh. Maybe I misheard my mechanic and he said thicker. That does make sense.
Old 02-22-2008, 07:55 PM   #7
GrundleJuice
Member#: 165749
isnt the STi HG to fit a closed deck or semi closed deck? Will it work ok with the open deck design in terms of allowing coolant to circulate properly? im not very familiar with the open deck ej25's vs the closed decks as far as cooling between the block and heads, just the first thing i thought of when thinking about STi motor vs n/a motor.
Old 02-24-2008, 10:50 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Unless I remember incorrectly, the STi HG's are .058, just like the '99-02 SOHC Ej25 HG. It's what I've used on my last couple of engines. However, I don't know what the thickness on an '05 EJ25 uses for a gasket. I know that engine has different pistons than mine and a different intake manifold but haven't followed the last couple of years of production closely enough to know of any other differences...
Old 02-26-2008, 05:22 AM   #9
subyboy
Member#: 119432
2005 Impreza WRX
World Rally Blue
I don't belive using STI hgs will raise the cr if anything it will lower it, as with the coolent circulation it has to deal with the heads it really wont matter on the block. For what ever hgs you do decide to use make sure that the coolant holes/ports on the heads and the gaskets line up. If they don't but are close you will have to moddify them.
My .02
Thanks
subyboy is offline   Reply With Quote
Old 02-26-2008, 10:20 AM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The coolant passeges are ALL in the SAME SPOT as always. Only difference are they moved a little left or right, and PHASE2 heads the passeges are BIGGER at the middle and around. They have NOT moved to anywhere where it's going to effect cooling.
If you've seen phase1, phase 2 heads, you'll know.
What's the Difference Between an 04 STi and 07 WRX/STI Headgasket? williaty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-29-2009 11:10 PM
OEM STI HeadGaskets FS $40 SHipped dingobite Engine/Power/Exhaust 0 10-17-2006 12:32 PM
STi headgasket part # PeteDucati Built Motor Discussion 2 09-15-2006 10:12 AM
FS (STi):CP forged pistons-ARP headstuds-COBB race bearings-STi headgaskets **NEW** phlegmon Private 'For Sale' Classifieds 11 05-26-2006 01:00 AM
Deep puddles + STi = HEADGASKET LEAK!! Need some suggestions for stronger motor ;) 300blueballs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-08-2004 07:26 PM
