Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-22-2008, 07:38 PM   #1
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Impreza GC8 03 rs engine in a 99rs?
03 rs engine in a 99rs is my question.
Will I able to use the 99rs ecu to run this engine?
I know my car have a maf will this be a problem also?
thanks for any help on this.
trinistyles is offline   Reply With Quote
Old 02-22-2008, 09:59 PM   #2
ToastermonkeyPat
Member#: 159826
1995 Impreza L
Aegean Blue
I don't think it'd work because the 03 is MAP and the 99 is MAF. I'm considering trying to convert my 99 RS to MAP. I'll post if I end up trying it out.
ToastermonkeyPat is offline   Reply With Quote
Old 02-23-2008, 12:50 AM   #3
GFimpreza
Member#: 40674
94 Impreza wagon
1.8L + 657cc's
Why not just swap the throttle bodies and run the 99 maf intake?
GFimpreza is offline   Reply With Quote
Old 02-23-2008, 10:26 AM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Swap the whole intake assembly over and the engine harness and then it should be a simple plug and play swap. I think the '03 has an egr pipe off the back of the drivers side head that you will not need in your '99RS. You should be able to find a pipe plug to seal up the hole. I went the other way, a rebuilt '01RS to '03 baja. I kept my '03 intake assembly and my heads as I needed the egr fitting. Also it doesn't make much of a difference but the pcv valves are different, you can either pull the fittings out of the block and swap them like I did or just change the hoses over for the pcv valves.
flstffxe is offline   Reply With Quote
Old 02-24-2008, 12:26 AM   #5
00LGTP
Member#: 172618
1995 EJ253/D25 GC
371hp/355tq 1.5xtr 93oct
i think the ECU's might be alittle different because of the MAF and MAP.
00LGTP is offline   Reply With Quote
Swapping 03 RS engine into 99 RS shane falco Newbies & FAQs 2 05-02-2010 03:53 AM
FS: 03 RS hood in silver only 1000 miles on it, in Santa Barbara PARANOID56 SCIC Private Classifieds 0 02-05-2007 11:14 AM
Anyone interested in buying a 03 RS 2.5l engine with 53k? jonnysubby North West Impreza Club Forum -- NWIC 8 11-22-2005 12:14 PM
03 RS Engine swap to 2.0L Wrx wiring question jonnysubby Electrical & Lighting 0 11-22-2005 12:17 AM
RS Engine in '95 L GoTdaSkiLz Normally Aspirated Powertrain 4 09-20-2002 10:01 PM
