Old 02-22-2008, 09:28 PM   #1
Gettingthere
Member#: 155933
05 suby
Angry Oh shucky-darn it all... Help! car wont start!
Hey guys! my cousin owns a 2002 2.5rs with 80,000 miles on it. the car was running fine half an hour ago. We drove to mcdonalds for a quick bite. come out and the car wont start. So i think to myself its probably the battery and so i call my friend to come down and jump the car, we jump the car but it failed. I realized the lights come on and the radio works, so i crank the key and all we can hear is click click click clack clack. I did see the belts faceing the front of the car move for a second but stopped and kept on making the click clack noise. can anyone give me some inputs on whats going on? please!
Gettingthere is offline   Reply With Quote
Old 02-22-2008, 09:40 PM   #2
OBS Fan
Member#: 9751
First, don't use offensive titles on your post.
Second, go buy a new battery. If that is the OEM battery, your cousin is long due for a new one. A jump won't help a battery that is past its service life.
- OBS Fan
OBS Fan is offline   Reply With Quote
Old 02-22-2008, 09:56 PM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Busted starter, something between the starter and battery, or maybe it really IS the battery.
Counterfit is online now   Reply With Quote
Old 02-22-2008, 10:07 PM   #4
Gettingthere
Member#: 155933
05 suby
sorry about the offensive title, i would change it if i could i was just trying to get attention! haha
starter eh? will change battery and look into starter thanks!
Old 02-22-2008, 10:11 PM   #5
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
it might be the starter... if it is clicking then it is getting power. however it might not be enough power to actually turn over the motor. that clicking noise is the solenoid moving in and out however to make it click is far less power than actually turning the car over...
option 2... the starter doesn't work. take a hammer and give the starter a couple good smacks, then try to start the car again. or smack it while trying to start it... all good stuff... if you cannot find the starter then don't try... it should be on the driverside on the bellhousing... if this is going over your head then don't start hitting things with a hammer...
Zefy is offline   Reply With Quote
Old 02-23-2008, 02:19 AM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
firstly the comment about a jump not working on a battery past its service life is pure crap. If you jump it with pos to pos and neg to ground you will be bypassing your battery and using the donor battery in its place from an electrical standpoint, to put it simply. You can always jump straight to the starter solenoid (relay) and if it fires right up, its prob the wiring between the batt and relay or the batt itself. tapping the starter relay with a ham,mer can help if its a stuck relay but usually if you hear a click then the relay is working. (some cars have a relay on the starter itself and another between the starter and battery for some stupid useless reason. dont know if Subaru ever did that) A large resistance in the system can cause this problem also.. an example would be a bad ground that is drawing a lot of current, a bad ignition switch that is doing the same, a starter that is doing the same or anything drawing more current than it should be. anyway, hope you get it figured out.
Old 02-23-2008, 11:30 AM   #7
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
is it possible that you have a lock out switch just wondering cause that disables the engine but that would be under your security feature so if not that im goin with bad starter
Hedbergsuby07 is offline   Reply With Quote
Old 02-23-2008, 02:50 PM   #8
dalehatestheriaa
Member#: 170616
1998 MiatA!
BLACK
starter. had the same thing happen in a old car of mine, i was broke so i just pop started it on a regular bases, hahaha, til it got to cold out and i couldnt find any good hills.. if its a MT pop start it, drive it to a shop get a new starter
but just incase.... how many volts dose your battery have now? did you check it before? or just asume that its dead. If you get it started check how much your alt. is putting out, i belive it should be bwtn 12-14 depending but i could be off.
dalehatestheriaa is offline   Reply With Quote
Old 02-23-2008, 07:08 PM   #9
Counterfit
Member#: 124254
"The Scoobinator"
"Shucky-darn it all" FTW!
Old 02-23-2008, 09:48 PM   #10
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
I would hope the alt is putting out more than 12v.
Subyroo2.5 is offline   Reply With Quote
Removed battery, put it back in, car wont start DP1112 Car Audio, Video & Security 4 09-15-2006 06:03 PM
HELP Car wont start zinc99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-13-2004 01:59 PM
HELP CAR WONT START after sprayer install (im retarded) er murena Electrical & Lighting 4 06-29-2003 12:20 PM
NEED HELP! car wont start after deck installation! yeng Car Audio, Video & Security 7 04-28-2003 05:53 PM
Help, Car wont start... friday the 13th, coincidence? biggreen96 Legacy Forum 15 12-15-2002 03:34 PM
