Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 02-23-2008, 06:24 AM   #1
snobrder_ad
Member#: 129203
2004 WRX Aspen White
StgII
Question First DataLog... mind checking it out?
i posted on romraider's forum. but thought i could get some feedback on here as well. trying to learn the ever-so-fun part of the ecu and tuning it... http://www.romraider.com/forum/topic2828.html
check it out and let me know.
snobrder_ad is offline   Reply With Quote
Old 02-23-2008, 07:05 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
yeah you are having some issues. your Ignition Advance Multiplier (IAM) has dropped to 13, meaning you are only using 13/16 or 81% of your whole dynamic advance map.
it appears that you have a flat dynamic advance map that is set at 10*. now since your IAM is 13 you are only gonna use 8*. im guessing it got rounded down to 7.5 in the ecu since those are the highest knock correction value in your log. so you are basically knocking over the whole rpm range except at 3300-4000rpm. since you already have a flat advance map i would just go in and make your advance map correspond to the knock correction values you logged.
you can go read some suggestions on how to tune this in this thread
http://forums.nasioc.com/forums/show....php?t=1432656
i am guessing your maf table wasnt rescaled properly for your intake and your af corrections are off when you go open loop. you are knocking the whole way from 4200rpm to redline.
are you running worse gas now than when you got tuned?
also, you should consider lowering your boost at the higher rpm since your injector duty cycle is going over 100%.
Phatron is online now   Reply With Quote
Old 02-23-2008, 04:07 PM   #3
snobrder_ad
Member#: 129203
StgII
yeah, it was not feeling as good going above that 4k mark to redline. i think i need to get a new map on there and see how my car likes it. i could be fussing around messing with this one for a while and not make any progress due to my low understanding of tuning (and not trying to blow up my engine)
Old 02-23-2008, 06:14 PM   #4
snobrder_ad
Member#: 129203
StgII
question: why is it my throttle opening angle wont go above 90.xx on wot. ive done about 8 datalogs and each time, that is where it maxes at. othing is in the way on the pedal... is there anything i can do to fix this or check for??
Old 02-26-2008, 01:49 PM   #5
greddyvr4
Member#: 167296
did u upload ur new logger defs? dl it first. unzip it. and go to "my computer", program files, enginuity...and once u open that up, u will see an existing logger file named 'logger def xlm" something along those lines. Drag the new file u just unzippped into the enginuity main file. It will ask u "do you want to replace existing file?" click yes to all.
You update the ecu defs the same way. I hope this helps. I was lost for a sec as well. As for ur being high, I would lose the short ram(if ur maf wasnt rescaled from your tuner), check ur throttle cable to make sure its not too loose, and most importantly, get ur IAM back up to 16. But I agree with above, if ur seeing 7.5* kc with ur iam at 13, I wonder how advanced ur timing is with ur iam at 16. But without the map, its still hard to tell. If u want u can pm me the map and ill take a look at it.
But start from there. My bro's car was knocking with his cai. Dropped his iam down to 0. We put the stock intake with a kn panel back in. Reflashed the same map and drove around until the iam jumped back to 16. You will be able to tell the difference when ur ecu is "happy".
logs things like:
load(direct)
eng speed(rpm)
idc
throttle angle
feedback knock
fine learning knock
knock correction
timing advance
maf flow
wgdc
relative manifold pressure(corrected)
note* some of these you will see once u dl the new logger defs.
hope this helps buddy.
greddyvr4 is offline   Reply With Quote
30R Datalog....Pros Check it Please!! FocusdSound AccessPort 7 01-17-2009 10:49 PM
Bought a Honda.....and love it check it out, you'll like it JonP North West Impreza Club Forum -- NWIC 12 07-18-2007 12:03 AM
My first edited video...check it out. CaliSTile General Community 33 07-09-2007 09:18 PM
It is Done, Check it Out Flat Black and Blue 02 WRX mrtrex Member's Car Gallery 24 07-11-2003 08:55 AM
check it out...check it out...my pics from detroit :D shukes24 Mid West Subaru Owners Club Forum -- MWSOC 7 01-24-2001 10:01 PM
