Old 02-23-2008, 07:09 AM   #1
Nicky B.
Member#: 148261
2007 Scoopless&Proud
Default 2.5i with 92 oct.
Many people have said do no use anything Higher than 87 oct. After reading the manual, we should not be afraid of higher octane. the manual states " the 2.5L non-turbo engine is designed to operate using unleaded gasoline with an octane rating of 87 AKI OR HIGHER. But obviously race gas and high 90 octane is absurd
Nicky B. is offline   Reply With Quote
Old 02-23-2008, 08:29 AM   #2
gregp07h4
Member#: 156770
2007 impreza 2.5i
urban grey metallic
with gas prices the way they are, I don't know why you would want to put anything more than 87 octane in a n/a car that calls for 87 octane. I definitely wouldn't be afraid of it but i won't waste my money on it either. unless you have a chip or a cam or some other modification that requires you to boost your octane you're wasting your money.
gregp07h4 is offline   Reply With Quote
Old 02-23-2008, 10:25 AM   #3
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
it might make it run smoother, but I've tried 89 and 91 longterm in the winter to see if I could improve winter mileage... it works... but you don't get the improvement that justifies the extra 10-15 bucks or more per tank.
Sir-Knight is offline   Reply With Quote
Old 02-23-2008, 11:10 AM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
The only time I would use it is if it gave me more mileage than 87 but then I'd have to factor in how much I'm paying per tank.
EdHilario is offline   Reply With Quote
Old 02-23-2008, 12:42 PM   #5
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
What are you filling up? No Subaru, that's for sure.
It's more like $1.20-$2.40.
Old 02-23-2008, 01:02 PM   #6
Sir-Knight
Member#: 73636
newport blue pearl
55 L on a fillup... 1.10$/L where I live for 87, 1.25/L for 94 octane
Old 02-23-2008, 01:03 PM   #7
Sir-Knight
Member#: 73636
newport blue pearl
okay, so it's closer to 6-7$ a tank, but you don't get 6-7$ in savings per tank with the increased efficency.
lulz the edit button broke
Old 02-23-2008, 02:43 PM   #8
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
Why WOULD you want to? That is one of the glory of a NA subie, 87 octane!
It isn't like raising the temperature for the gasoline to ignite is going to help your car out.
ZeppelinPie792 is offline   Reply With Quote
Old 02-23-2008, 05:03 PM   #9
msingell
Member#: 153097
2012 CRZ
PWP
i have used both 87 89 octane and i beleive that the car runs better on 87. so im not sure if just dumping 92 into a 2.5i would yeild any results, but if you TUNED to a higher octane, im sure there could be benifits.
msingell is offline   Reply With Quote
Old 02-23-2008, 05:55 PM   #10
Nicky B.
Member#: 148261
yea its definitely not a $15 dollar difference. For me, 6 bucks extra a tank is not a big deal. I just switched to 92, i'm going to give it 3-4 tanks then see if I can notice any difference, if not i'll go down to 89. I just can't justify putting 87 in my car when most of the world doesn't even sell gas with that low of octane. Its all personal preference thought.
Old 02-23-2008, 07:26 PM   #11
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
Recently I started getting 20 miles less a tank than I used to I raised the octane and I started getting 300 again.
2.5i is offline   Reply With Quote
Old 02-23-2008, 07:34 PM   #12
Sir-Knight
Member#: 73636
newport blue pearl
I think you ought to look up octane on wikipedia.
North America uses the AKI (anti knock index) instead of a true octane rating(RON). In fact our 87 is the equivalent of the lowest grade fuels elsewhere.
Old 02-23-2008, 10:20 PM   #13
piker28
Member#: 22664
I use 89 and i think its a waste im just to stupid to go down to 87
piker28 is offline   Reply With Quote
Old 02-24-2008, 01:48 AM   #14
SubyRSdriver
Visiting NASIOC Timeout
Member#: 94839
2005 2.5 RS
Unless you have some type of built N/A motor.. like a high compression frankenstein.. using anything over 87 octane is a total and complete waste of money. it is a proven fact that there is no gain.. If your N/A has some type of knock, ping detonation etc to make it run smoother on 91 than 87... and it is not a built motor.. something is wrong with you car..
SubyRSdriver is offline   Reply With Quote
Old 02-24-2008, 12:44 PM   #15
dan13
Member#: 157726
hunk of metal
It would actually be hurting your motor unless you beat on it in the summer to use anything higher than 87.
High octane gases are designed to be used in motors than run hotter than your average toyota corolla. Thus they contain additives than allow it to resist igniting at low points in the cylinder. So if you use anything higher than 87 your cylinders are most likely firing more advanced than usual. In turn your motor is working harder along with the ecu freaking out.
dan13 is offline   Reply With Quote
Old 02-24-2008, 01:22 PM   #16
somethingpink03
Member#: 140864
2016 Forester
Crystal White Pearl
Let's do the math... Around here in New England, 89 is usually 8 cents more a gallon, and 91-93 is about 15 cents more. Let's round up our tanks to say... 16 gallons. By running 93 octane, even at dead low it would be only 2.40 cents a more to fill up. If you spend 35-40 anyway, what's an extra couple bucks??? If it means better gas mileage, then I say it's worth it. That's just my 2 cents.
somethingpink03 is offline   Reply With Quote
Old 02-24-2008, 02:06 PM   #17
piker28
Member#: 22664
but it was proven that it does not help in added gas mileage ive seen people actually go from 89 to 87 and say they get better mileage from it
Old 02-24-2008, 02:18 PM   #18
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I can back that one up...
When I use 89, I get a constant 15mpg. But as soon as I go back in 87, my gas mileage went up to 21mpg. Maybe my car wasn't meant to use 89 and the car is rejecting the 89. I'm going to stick with 87 from now onwards.
Spore is offline   Reply With Quote
Old 02-24-2008, 03:27 PM   #19
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
ignorance is taking hold and digging in here.
Old 02-24-2008, 05:04 PM   #20
imprezaowner27
Member#: 131299
2006 Impreza
Can anyone credible respond to this???
Ive used 87 octane, and recently have been putting 93 octane in because ive heard it was cleaner
but i could be completely wrong
imprezaowner27 is offline   Reply With Quote
Old 02-24-2008, 05:22 PM   #21
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
the octane rating has nothing to do with the purity or cleanliness of the fuel. while 93 may be cleaner in the case of some brands, it is not cleaner because it is a higher octane. The octane rating is the fuels ability to resist detonation (burning violently due to a high temp/hotspot or when its not supposed to basically) instead of burning in a nice controlled even flame front in the cylinder. im not credible as far as fuel goes by any means but i promise you that octane has nothing to do with how clean the fuel is.. in fact high octanes are achieved by adding things to the fuel (lead used to be used until the late 70's). some brands may add detergents or a high level of purification when producing their higher octane fuels but i have never heard of that, personally.
Old 02-25-2008, 01:21 PM   #22
JLW2007RS
Member#: 162089
2008 G37S IPL
Hope this helps, please take the time to read this
http://chemistry.about.com/library/w...abyb100401.htm
JLW2007RS is offline   Reply With Quote
Old 02-25-2008, 03:21 PM   #23
Sir-Knight
Member#: 73636
newport blue pearl
http://en.wikipedia.org/wiki/Octane_rating
Regional variations
In many parts of Europe, 95 RON (90-91 AKI) is the minimum available standard (but is called Premium Unleaded), with 97/98 being higher specification (being called Super Unleaded) In Australia, "regular" unleaded fuel is RON 91, "premium" unleaded with RON 95 is widely available, and RON 98 fuel is also reasonably common. Shell sells RON 100 petrol from a small number of service stations, most of which are located in capital cities. In other countries "regular" unleaded gasoline, when available, is sometimes as low as 85 RON (still with the more regular fuel - 95 - and premium around 98 available). In Russia and CIS countries 80 RON (76 AKI) is the minimum available and the standard.
It should be noted that this higher rating seen in Europe is an artifact of a different underlying measuring procedure. In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2.
Old 03-04-2008, 10:04 PM   #24
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
the 07 2.5i ecu is set to run on 87 octane . only way to benifit from higher octane is to tune it in
watchunglava is offline   Reply With Quote
FS: 6 Disc CD/MP3 Changer from 2007 Impreza 2.5i, with AUX Input Jack tarp Interior/Dressup/Audio & Security 3 08-27-2007 03:58 PM
2.5i with sti springs? 8smitty Normally Aspirated Powertrain 5 08-20-2007 11:25 AM
2.5i with wrx hood need some info.... stubz203 Normally Aspirated Powertrain 10 07-05-2007 05:16 PM
My 2006 2.5i with WRX sideskirts and spoiler Paraskass Member's Car Gallery 7 08-27-2006 02:26 AM
I drive an 06 2.5i with an automatic transmission... PockyPete Newbies & FAQs 8 08-09-2006 11:30 AM
