Old 02-23-2008, 09:59 AM   #1
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
Unhappy HELP!!!! possible rod snap or floating valve.....
ok so during some fun last nite in the snow my car developed a hellacious loud clanking noise in the #1 cylinder, i got it home barely and it was sluggish as all....anyways when i got it home i pulled the spark plug and it was fouled to no end, completly black all around. Anyways it will not start but i have great electrical voltage and everything else, i did notice that there was a sign of oil leakage around the spark plug boot area at the valve cover, anywho heres a video my buddy shot right as the problem arouse..
http://www.youtube.com/watch?v=zND0mM8oZ34
please help!!!!! its urgent
rllyrckt is offline   Reply With Quote
Old 02-23-2008, 10:15 AM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Sound like you spun a rod bearing.
flstffxe is offline   Reply With Quote
Old 02-23-2008, 11:10 AM   #3
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
that def does not sound good im going with thrown rod sounds really bad take it to subaru asap just out of curiosity does it even idel at all ?
Hedbergsuby07 is offline   Reply With Quote
Old 02-23-2008, 11:21 AM   #4
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
no it doesnt idle, it doesnt even start...
Old 02-23-2008, 11:31 AM   #5
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
i dont know if this will help at all but i went and pulled off the intake manifold earlier and by looking down at the ports of the #1 cylinder, i can see that both valves are still connected but there is a build up of carbon and moist oil on the port.
Old 02-23-2008, 11:39 AM   #6
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
take it to Subaru or some other mechanic you trust if it doesn't start then you might have snaped a rod and its fallen down into your oil pan thus its wedged and stopping things from moving a saw some similar sound in a forester forum a while back also is it the belts just wondering don't think so thought i would ask
Old 02-23-2008, 11:43 AM   #7
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
no all the belts are tight and what not....the car sounds like when you have a dead battery and it only cranks about a 1/4 turn then stops.....and no its not a dead battery....
Old 02-23-2008, 12:02 PM   #8
novacivic
Member#: 117980
2005 sti
wr blue
wanna sell it pm me
novacivic is offline   Reply With Quote
Old 02-23-2008, 12:04 PM   #9
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
ill let ya know...ive gotta get another motor to swap in there first, but if i do, youll be the first to know
Race Short Blocks / Rod and Piston Combos / Valve Train Packages / Timing Kits Built Industries Engine/Power/Exhaust 2 12-16-2009 01:00 PM
rod knock or valve knock Zerogravity Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 06-01-2009 12:28 PM
sink or float? yashuone Off-Topic 7 03-12-2009 04:51 PM
FS-Cosworth Hi/Capacity Oil Pan Kit, Cos. Rod/Main Bearings, BC Valves/Spring/Ret blackacres Engine/Power/Exhaust 22 02-14-2009 03:16 AM
WTB: V7 EJ207 Rods+crank, or AM rods+05 revised crank 5hif73r Private 'Wanted' Classifieds 0 12-28-2008 01:16 PM
