Old 02-23-2008, 05:31 PM   #1
Bahoogas6
Member#: 144248
2008 WRX
Dark Metalic Grey
Default Help won't run!!
OK, first a little back ground, 96 Impreza 1.8, hit a deer, bent the cam sprocket and damaged the cam sensor(not to mention all the other damage) replaced the cam sensor and tweaked the sprocket back to not noticeable wobble, the car ran perfect. Couple of months later the car develops a noise, sounds like a possible exhaust leak, not really noticeable in feel. The next day I left for work and the car sounded and felt very rough. Later I had my son turn the engine over and the cam sprocket had a wobble in it (must have relaxed into the bend), replaced the sprocket with a new one from the dealer, and a new timing belt. Now the car does not run at all, the things I have covered are: The old and new sprockets are exactly the same in every way, the timing belt is installed absolutely correct (not my first one by any means), replaced the cam sensor because I had another, It is getting spark, It is getting good fuel, new plugs (also had them), and no engine codes. It does sound like it would occasionally very weakly hit and want to crank, but not good enough. What next??
Bahoogas6 is offline   Reply With Quote
Old 02-23-2008, 05:53 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
sounds like bent valve/s
novacivic is offline   Reply With Quote
Old 02-23-2008, 09:15 PM   #3
Bahoogas6
Member#: 144248
2008 WRX
Dark Metalic Grey
HMMMMMM, I guess a compression test, The one I have now will not reach deep enough into the heads to use, I am going to a friends next week to borrow his. Thanks.
Old 02-24-2008, 11:32 PM   #4
Bahoogas6
Member#: 144248
2008 WRX
Dark Metalic Grey
Any other possibilities?
Old 02-26-2008, 04:28 PM   #5
Bahoogas6
Member#: 144248
2008 WRX
Dark Metalic Grey
OK, I have 150,165,172 and 150 PSI on the cylinder pressure, I have spark (Really good), Plenty of fuel, new timming belt (done correctly and is right), new cam sensor, new cam sprocket. Had an alsmost exhaust leak sound (nothing looks like it was leaking) and no CELs. HMMMMMMMMM.
Old 02-27-2008, 08:25 AM   #6
Bahoogas6
Member#: 144248
2008 WRX
Dark Metalic Grey
Anyone??? any possible suggestion??
Old 02-27-2008, 10:13 AM   #7
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
pull the battery to reset the ECU and then try to start it.
Subyroo2.5 is offline   Reply With Quote
Car starts but won't run - VIDEO! HELP! trilap5e Normally Aspirated Powertrain 5 09-26-2013 04:16 PM
Car still won't run, please help! overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-13-2004 06:15 PM
!HELP! changed clutch car won't run TecHniKa Transmission (AT/MT) & Driveline 4 11-05-2003 04:49 PM
Need help, car won't run Ethan Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-19-2001 11:30 PM
