#1 |
Member#: 58405
Vehicle:2004 Element GT65'd Hydra, Hydramist'd STi |
i was swapping out Intake manifolds today and snapped a nipple off the purge control solenoid valve.
I am running a hydra w/ rotated mount turbo, do i even need this? I'm assuming that its not essential and for emmissions, how do i go about bypassing it? thanks
#2 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Considering the hydra does not use the OBD system, no you don't need it. Just cap everything off.
Tony |
#3 |
Member#: 58405
cool thanks, just did it, capped off everything,
I left the hard line coming out by the fire wall to vent and capped off both ends of the hard line under the manifold the MAP line to Hydra is still going into the little black nipple coming out of the intake manifold , side question?? that black nipple, any idea where i can get one that is a 90, i guess i'll run over the theDepot and check if they have anything that would fit Last edited by 48mpg; 02-24-2008 at 07:46 PM. |
| Thread Tools | |
| Display Modes | |
| Purge Control Solenoid Valve DELETE! Any Info? | guitarmaster1195 | Factory 2.0L Turbo Powertrain | 2 | 09-27-2009 03:15 PM |
| WTB: Purge control solenoid valve | jblaine | Private 'Wanted' Classifieds | 7 | 04-21-2009 08:51 PM |
| Purge Control Solenoid valve? | Synx | Service & Maintenance | 4 | 07-02-2008 05:40 PM |
| Purge Control Solenoid Valve?? | abosworth | Normally Aspirated Powertrain | 3 | 07-21-2005 04:20 PM |
| Code 35 purge control solenoid valve troubles | theascen | Service & Maintenance | 2 | 04-02-2004 04:36 AM |
