Old 02-24-2008, 01:35 AM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default 2006 STi 91oct + Meth Tune
This is the same Mainline Dynolog that Easystreet use to have. If any of you remember i dyno'd 350whp on it before with my 2.2L, 60lbm turbo and a 30-40 shot oh naws. that setup trapped 115mph.
Jon was the best. Took his time to fabricate me some brackets for my 12L Spec C tank to mount in the trunk. The fabrication needed to be done since i have my Audio Integrations amp rack in there and it was in the normal mounting spot. I will snap some shots of it tommorrow.
Mods
2006 STi
FP Green 3" inlet/8cm hotness
Catless TBE
Perrin EL Headers
UR Up Pipe w/ Tial 38mm external gate
ESX/Spearco TMIC
APS 70mm CAI (new since last tune)
APS Turbo Inlet
Grimmspeed TGV deletes
DW 740cc injectors
Walbro 255lph fuel pump
Perrin EBCS
1 Step Colder Iridiums
ACT Clutch / GruppeS Flywheel
Opensource Tuned by [email protected]
Aquamist HFS-5 (new since last tune)
91 octane only (different dyno different shop)(old thread here with other Green dyno plots http://forums.nasioc.com/forums/show....php?t=1424912)
91 octane + Meth (basline is after 70mm maf scaling and on wastegate boostage)
boost and afr
Old 02-24-2008, 01:44 AM   #2
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Nice - looks fun - that meth give you a nice kick up the rear??
Kastley85891 is offline   Reply With Quote
Old 02-24-2008, 01:47 AM   #3
di2co
Member#: 105648
2006 STI
wrb
There is no way you made that much power I call BS
The meth kit install looks awesome. I can't wait to get back so I can go for a ride. If you need a DD let me know. I'm glad it's all done and now you have an exta meth kit for the bugeye
How much "alcohol" was consumed for the tune?
di2co is offline   Reply With Quote
Old 02-24-2008, 01:51 AM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
yup yup. +5psi and +6* of timing from the pump gas tune. ^^Added baseline plot to first post. It was after the 70mm was scaled and on wastegate boost.
Old 02-24-2008, 01:54 AM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
32 beers + 5 ounces of meth
Old 02-24-2008, 03:48 AM   #6
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
WHEEEEEEEEEEEE
im home!
HB Speed is offline   Reply With Quote
Old 02-25-2008, 11:12 AM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
log. I reduced the WGDC by 2% and took out 1-3* of timing from ~3500 to redline. Trying to be safe since i got tuned at sea level and i live at 3000ft. I will slowly start adding them back (which in ron terms means that for the first change i'll probably add 5% WGDC and 4* of timing and see what happens )
Timing and boost are smooth as a baby's but....i guess the 38mm ext gates dont suck after all.
Code:
RPM	FBKC	FLKC	BASE	ADV	IGN	IAT	KC	MRP	MAF	WSGT	THROT
2896	0	0	40.12	0	40	57	0	-5.8	29.64	18.04	18.43
2920	0	0	36.64	1.28	40	57	1	-1.6	46.8	27.45	30.98
2979	0	0	27.34	3.15	31.5	57	3	1.74	66.5	55.29	85.49
3068	0	0	21.17	4.42	26.5	57	4.5	3.63	78.44	64.71	100
3172	0	0	12.94	5.52	19.5	57	5.5	6.09	93.04	44.71	100
3314	0	0	10.96	5.98	17	57	6	9.72	117.29	42.35	100
3482	0	0	10.5	5.98	16.5	57	6	14.22	152.91	42.35	100
3649	0	0	10.26	5.98	16	57	6	19.3	180.15	42.75	100
3925	0	0	10.24	5.98	16.5	57	6	22.05	206.49	42.75	100
4118	0	0	10.57	5.98	16.5	57	6	23.36	221.9	42.75	100
4380	0	0	10.96	5.98	17	57	6	23.36	235.24	43.14	100
4633	0	0	11.24	5.98	17	57	6	23.36	246.36	43.14	100
4850	0	0	11.52	5.98	17.5	57	6	23.36	254.41	43.53	100
5106	0	0	12.08	5.98	18	59	6	23.36	268.45	42.75	100
5306	0	0	12.69	5.98	18.5	59	6	23.36	271.61	41.96	100
5504	0	0	13.19	5.98	19	59	6	23.22	277.02	42.75	100
5702	0	0	13.5	5.98	19.5	59	6	23.07	280.62	43.53	100
5916	0	0	13.79	5.98	20	59	6	23.07	289.61	43.53	100
6122	0	0	14.21	5.98	20	57	6	22.78	290.05	43.53	100
6275	0	0	14.35	5.98	20.5	57	6	22.78	291.84	43.53	100
6483	0	0	14.66	5.98	20.5	57	6	22.78	296	43.53	100
6588	0	0	15.06	5.98	21	57	6	22.64	291.82	43.53	100
6724	0	0	15.32	5.98	21	57	6	22.78	297.99	43.53	100
6941	0	0	15.46	5.98	21.5	57	6	22.64	291.33	43.53	100
7076	0	0	15.68	5.98	21.5	57	6	22.78	296.94	43.53	100
7129	0	0	15.84	5.98	22	57	6	22.78	295.96	43.53	100
7330	0	0	15.96	5.98	22	57	6	22.78	295.94	43.53	100
Old 02-25-2008, 12:19 PM   #8
SubySales
Member#: 172743
Something doesn't look right. I wouldn't drive it until you figure it out.
SubySales is offline   Reply With Quote
Old 02-25-2008, 01:20 PM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
What jumps out at you? Details? Please enlighten us.
wcbjr is offline   Reply With Quote
Old 02-25-2008, 02:46 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
i really need to fix this, it looks horrible
Old 02-25-2008, 03:07 PM   #11
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
The logs look good. Timing looks smooth. AFR is smooth and boost is smooth. However there are two noticable dips at 4500 and 5500 rpm on the graph. Post the AVCS logs so we can see what the cams are doing. Everything looks great on the tune and Jon did a good job!
Clark
AZScoobie is offline   Reply With Quote
Old 02-25-2008, 04:19 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
the avcs starts tapering at 4500. 5300 is where wsgtdc starts to taper.
Old 02-25-2008, 04:25 PM   #13
Phatron
Member#: 36033
CEO PhatBottiTuning
Spec C Tank
Old 02-25-2008, 04:49 PM   #14
AZScoobie
Member#: 8785
netcom.com
It looks good but I think with some fine tuning you can get those dips out. Also I think you can get the extreme end of your power band up a bit. The tune looks solid and smooth. You cant feel the dips on the road anyways! Nice Spec C tank man. Where did you buy it? I need to order one.
Clark
Old 02-25-2008, 05:20 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
Well the thing is I dont have a AF Gauge installed (i have one thats been sitting in my garage for 3 months) so if its a fueling issue I cant fix it. And I dont have any experience with the AVCS. I guess I can try varying the AVCS in that spot since its only 2-4 cells, but I have no way to know if its removing the dips.
The only measure of power i have back home is airboys spreadsheet. And as for the wsgtdc I did that when i removed the 2%.
Yeah I dont notice the dips on the street. Its pretty hard to notice anything with the external gate blaring and the aquamist gauge blinding me.
You'll have to ask jon about the spec c tank.....but i think he picked it up at harman.
I really like Jon and Im really happy with his work. He could have thrown my tank in the trunk really quickly and done a half ass intall, but instead he took the mounting brackets, cut and welded them, and spent several hours on it getting it to fit just right. Also he let me watch everything he was doing during the tune. I had a blast.
Old 02-25-2008, 06:21 PM   #16
LittleBlueGT
Member#: 96204
2013 STI GR
If you are logging with enginuity (romraider) then log Manifold Relative Pressure Direct.
This will go a bit higher then the 23.36 psi you are showing. You will have to subtract atmospheric pressure from your result though.
LittleBlueGT is offline   Reply With Quote
Old 02-25-2008, 06:24 PM   #17
AZScoobie
Member#: 8785
netcom.com
Cool. I will catch Jon on AIM and ask him about the tank. I am gong to put the SMC or Cooling mist kit in my car and I need that tank
Email me the logs on the road when you get time. I can tell if its the cams causing that dip and I will fix it or tell you how. That is if you even want to mess with it. Like you said you can feel it.
Clark
Old 02-25-2008, 06:36 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
are they the "intake VVT" ones? just those and rpm?
My butt dyno is only accurate to +-8hp, these dips are clearly +-5hp just a little outside of my accuracy.
2006 sti ATP35 Dyno tune, Makes 381whp@ 19.5psi 2gnt2wrx Proven Power Bragging 23 05-08-2010 09:33 AM
2006 STi BWS259 401whp 345tq crappy 91Oct ASU Proven Power Bragging 10 05-05-2010 10:32 PM
FS: (NH) Cobb AP V1 2006 STI w/ Pro-Tune Map sticky tires Engine/Power/Exhaust 0 05-19-2009 04:41 PM
04 STI Stage 2 Meth vs. No Meth Tune Tuning @ FLI Proven Power Bragging 53 04-24-2008 09:02 PM
FS:NJ-> 2006 STi AccessPort - Cobb Tuning - $550 saad Engine/Power/Exhaust 7 11-21-2006 12:27 PM
