Old 02-24-2008, 02:21 AM   #1
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Default Cosworth Cams
Any one fimilar with tuning the avcs system using the costworth EJ25 avcs cams? Cosworth info:
# Intake camshaft duration "278" deg.
# Intake camshaft lift 10.7mm
# Exhaust camshaft duration "274" deg.
# Exhaust camshaft lift 10.0mm
When I get my motor back from the builder these will be in the heads and I don't want to run into any issues so I would like to know what other tuners are running for advance with these cams.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 02-24-2008, 04:52 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
clark (azscoobie) knows but he probably wont tell you exactly what to do but he will point you in the right direction.....
try the guys in puerto rico, i believe several of them are running those. they would probably help you out.
Old 02-25-2008, 01:30 AM   #3
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Thanks, sent him a PM and we will see.
Anyone else, any advice?
-Rene
Old 02-25-2008, 10:20 PM   #4
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you should be alright because the cosworth cams have 8degrees of retard ground into them specifically so no one will have a problem with them.I have had this discussion with phil from element extensively.
john 1badSTI is offline   Reply With Quote
Cosworth Cams EJ25-Material added? (What other Cams are as well?) EjtwentyfiveSti Built Motor Discussion 5 04-16-2007 10:15 PM
Anyone comment on Cosworth cams vacuum and onset.... bboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 35 03-12-2007 08:53 PM
F.S, Sti heads,cosworth cams!!! blueflu Engine/Power/Exhaust 13 03-11-2007 12:53 PM
Cosworth Cams Work with a Non Sti Wrx Head? ozieleon04 Built Motor Discussion 1 12-27-2006 09:58 PM
Cosworth cams wearejoy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 02-15-2006 09:58 AM
