Old 02-24-2008, 08:23 AM   #1
tmeh
Member#: 30800
2000 .7 RS
Default Thermostat housing part number for oil cooler?
Can anyone tell me what the part number is for the thermostat housing that is used on a Non-Turbo car with a factory oil cooler?? (pre 2004) Forester had this, for example... from what I can tell, after 2004 they all seem to be mounted from the front
It is the same style as a regular water pump where the thermostat housing bolts up from the bottom, not from the front, except it has an extra inlet on the passenger side of the housing
It's hard to tell from parts diagrams since I can't find actual part numbers...
tmeh is offline   Reply With Quote
Old 02-24-2008, 08:30 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
so what you are after is an older forester AT thermo cover?
this must be as only the AT foresters had the oil cooler.....
Jamie
Old 02-24-2008, 08:37 AM   #3
tmeh
Member#: 30800
2000 .7 RS
It seems so, because I was looking at my first setup yesterday and it is plumbed into the thermostat cover, I couldn't remember if I had changed the water pump to get it installed.
So since I'm doing it ALL over again, that cover is what I need(in addition to all those hoses you found numbers for)... I just got some Impreza part manuals, but as you have just indicated, they don't help!!
since no model of domestic Impreza has that, a Forester part number is what I'm after...
Thanks Jamie
Old 02-24-2008, 08:39 AM   #4
tmeh
Member#: 30800
2000 .7 RS
Thermostat housing, forester, auto trans 98-00 $33.73 $24.69
i guess its that one?
Old 02-24-2008, 09:30 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yeah i guess so, i just hope it works for your application....
pn is: 11054AA010
BOLTS from the bottom.... etc.
Jamie
WANTED: Part number for oil presure sending unit JeremyRS Electrical & Lighting 11 10-20-2011 02:46 PM
Bell housing Part number for 2006 STI STIlin' Private 'Wanted' Classifieds 4 11-07-2010 11:04 PM
Parts number for oil filter? Impact.blue Vancouver Impreza Club Forum -- VIC 6 10-22-2009 11:59 PM
Need part number for oil filler tube on '03 WRX JRach Service & Maintenance 2 01-31-2008 07:07 PM
Part number for oil valve. GameMastyr Newbies & FAQs 4 01-15-2003 08:20 PM
