Old 02-24-2008, 12:29 PM   #1
jack klompus
Member#: 152885
2014 Malibu LTZ
Default dynomat and paintless dent repair
Does having dynomat on the inside of your door panels make a diffrence for a dent repair guy?
jack klompus is offline   Reply With Quote
Old 02-24-2008, 01:39 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, if there is dynomat or a similar material stuck to the inner side of the panel, PDR on that panel will not be possible unless the material is removed.
You can ask your local dent guy if there are any other options but I don't think so.
Old 02-24-2008, 02:27 PM   #3
nardvark
Member#: 145108
2002 Impreza TS
You have dynamat on the metal of your door? If it's on the plastic, it's not an issue.
They take out dents by pushing the metal back into place with relatively sharp metal tools from the inside, so you could see why it would to be removed.
nardvark is offline   Reply With Quote
Old 02-24-2008, 02:31 PM   #4
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
You're supposed to apply matting matierals to the metal of the door...
Basically, every part of the door that resonates at an audible frequency (most of the door assembly).
It works by adding weight to the door's structure, the weight lowers the frequency the door resonates at. If you add enough weight to the door, the resonant frequency drops below an audible frequency, and rattles/etc go away. Sound quality increases, as the door no longer absorbs any of the speaker's energy/movement.
-- Dave
AcquaCow is offline   Reply With Quote
Old 02-24-2008, 02:34 PM   #5
nardvark
Member#: 145108
2002 Impreza TS
I understand your point, but on my car, the plastic makes more noise than the metal, because it vibrates and buzzes from engine vibration. If I were to do some noise reduction (which I think I will this summer), I'd start with the plastic. I might be an odd case though.
Secondly, this might be a stupid question, but isn't there a large part of the outer metal that is largely inaccessible without completely gutting the door (not just taking the plastic pieces off)? That's why I asked, because it would depend on where the dent was.
Old 02-24-2008, 04:25 PM   #6
jack klompus
Member#: 152885
2014 Malibu LTZ
that sucks. The stuff is next to impossible to remove. Hopefully theres other options.
Old 02-24-2008, 04:40 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
nope, you just have to work through the access holes that are there. It isn't fun, and you WILL bleed a fair amount in the process, but you can cover most of the outer surface of the door this way.
Old 02-24-2008, 04:49 PM   #8
jack klompus
Member#: 152885
2014 Malibu LTZ
Just cut it in small pieces and go to town.
Old 02-24-2008, 04:59 PM   #9
nardvark
Member#: 145108
2002 Impreza TS
Do you have to rip off the plastic covering (looks like thick saran wrap or something to keep out water), and reglue it if you do this?
Old 02-24-2008, 05:14 PM   #10
jack klompus
Member#: 152885
2014 Malibu LTZ
Yes, rip it out and throw it away. You dont need it.
Maybe I'll get pops a dent from as seen on tv and try it.
Old 02-24-2008, 05:20 PM   #11
nardvark
Member#: 145108
2002 Impreza TS
Ah, gotcha. Thanks for answering my inane questions. Those pops a dent things seem to work for shallow dents. Creases, or anything where the paint has been damaged are beyond help. DON'T use it on anything but original paint, it'll rip the paint right off.
Old 02-24-2008, 05:21 PM   #12
jack klompus
Member#: 152885
2014 Malibu LTZ
Thanks. yea its oem paint. It sucks cause Im really careful where I park. Its a small ding but I cant stand to have even one.
Old 02-24-2008, 05:48 PM   #13
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
for removing matting, especially if it's in small pieces, you can grab some canned air, invert the can, and freeze the area in question.
You may want to cut out the square in advance, if it's a large sheet in the way, and freeze it from both sides.
Then simply hit the frozen spot from the outside of your car and it should pop the piece right out. Failing that, you should be able to pry it out with a screwdriver from the inside.
-- Dave
Old 02-24-2008, 06:05 PM   #14
jack klompus
Member#: 152885
2014 Malibu LTZ
If I cant cut it out, I'll try and freeze it. Good idea.
Old 02-24-2008, 06:17 PM   #15
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Yeah, even if it doesn't pop right out while frozen, it should be 10x less sticky and shouldn't be too hard to pull out with a flat-head screwdriver.
Just wear a laytex glove or something to give you an extra layer so that you don't freeze yourself to it...
-- Dave
Window tinting and Paintless Dent Repair Chicago trymyrex21 Mid West Subaru Owners Club Forum -- MWSOC 5 04-03-2006 09:24 AM
windshield repair and paintless dent removal (long island) 516_WRX_V2 Tri-State Area Forum 2 11-19-2003 01:47 PM
Paintless dent repair in NY? moss Tri-State Area Forum 4 10-01-2001 03:49 PM
Paintless Dent repair in SE Mich? Bimmerman Mid West Subaru Owners Club Forum -- MWSOC 1 08-11-2001 11:46 AM
paintless dent repair bruno Tri-State Area Forum 2 04-29-2001 11:10 AM
