Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 02-24-2008, 08:30 PM   #1
msingell
Member#: 153097
2012 CRZ
PWP
Default Ice on the inside of the windows, does this happen to anyone else?
does anyone experience condensation turning into ice on the inside of their car windows? it happens to the winshield, all 4 side windows and a little around the seal of the rear window. two things that i thought may be the problem are a. its worse the days after i wash the car. and 2. maybe im using too hot of defrost, causing condensation that becomes ice and eventually melts. thanks for any info!
msingell is offline   Reply With Quote
Old 02-24-2008, 08:54 PM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
is the HVAC on recirculate? That'd do it.
sniper1rfa is offline   Reply With Quote
Old 02-24-2008, 09:09 PM   #3
msingell
Member#: 153097
2012 CRZ
PWP
um...i have the setting on defrost/foot blower. and the icon showing the air coming from inside the car, which i think is the recirculate youre talking about. im going to try the other way for a while, thanks sniper1rfa for the input. and also, my rear defrost will turn itself off. thats normal, right?
Old 02-24-2008, 09:26 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
yeah, you want the lever to be over to the left (shows air coming from outside the car). Recirculate should only be used to maximize the a/c for a short period of time, or when driving through dust clouds or something.
Defroster shuts itself off normally. If the window warms up too much, the heating elements will burn out.
oh, also, remember that both defrost settings keep the a/c compressor engaged. Just FYI
Old 02-24-2008, 09:39 PM   #5
msingell
Member#: 153097
2012 CRZ
PWP
great, thanks for setting me str8. and i wish i didnt have to use up extra power to defrost and stay warm, but its freakin cold. so can you have the blower on in any way that doesnt engage the a/c comp?
Old 02-24-2008, 09:44 PM   #6
Checkered24
Member#: 153974
2007 WRX Ltd
Urban Grey
Yeah, if you have it set to recirculate the air in the car, it won't efficiently remove the moisture from inside the cabin. When you shut the car off, that moisture condensates on the windows, then freezes in the cold.
Try running it by pulling in outside air, with the AC on in defrost mode for a while. That should pull the moisture out. If you still have a lot of problems after that, it could be because your getting water leaking into the cabin from somewhere.
Checkered24 is offline   Reply With Quote
Old 02-24-2008, 10:17 PM   #7
RICH SPEC-C
Member#: 165972
04 Spec-C
WR Blue
Get yourself a car de-humidifier. Its a little bag with silica gel type filling and it sucks all the moisture out the air inside the car when its standing. I got one from a company over here in the UK www.frost.co.uk . They last for a couple of months then you just pop it on a heater to re-generate it.
Hope this helps
Rich
RICH SPEC-C is offline   Reply With Quote
Old 02-24-2008, 10:49 PM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Yeah, you can. Do a search for "A/C on defrost" and you will find the instructions. Basically, there is a little switch behind that dial that is pressed when the knob is on the defrost settings. Disabling the switch disables a/c on defrost.
I did it, because I like to cruise with defrost and the foot vents on. Just remember to run the a/c occasionally to keep the compressor oiled.
Old 02-25-2008, 09:34 AM   #9
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
It's the running of the a/c that removes the moisture from the air. Disabling that won't help as much with clearing your condensation.
CTKAG is offline   Reply With Quote
Old 02-25-2008, 09:36 AM   #10
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
That's been done to death.
Yeah, it's true, but not relevant at -10*F. If he wants, he can still manually enable the a/c with the "a/c" button.
Old 02-25-2008, 09:44 AM   #11
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
I don't get it on the front windshield but i do get it on the side windows after i wash my car. I just open the doors and wipe down the seals and windows.
gingertooth is offline   Reply With Quote
Old 02-25-2008, 11:26 AM   #12
cmiovino
Member#: 134005
2004 WRX Premium
YES.
This happened to me about two weeks ago and I was like wtf. Also, sometimes I get massive amounts of condensation on the inside, resulting in it looking like it just rained on the inside.
Does this happen to anyone else. niblick Newbies & FAQs 4 09-22-2007 12:47 AM
Does this happen to anyone else? SkirtBoy Off-Topic 6 10-25-2004 03:19 PM
This happened to anyone else on here? StevieD Texas Impreza Club Forum -- TXIC 4 07-13-2004 05:55 PM
this happen to anyone else? spit_heron Brakes, Steering & Suspension 8 01-30-2003 06:05 PM
('93-'01) Does This Happen to Anyone Else? Narso Impreza Forum 2 04-21-2001 05:50 PM
