Old 02-24-2008, 07:59 PM   #1
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Default Speedo. Easier to pull tranny or engine?
97 Impreza Outback Sport 2.2SOHC Auto. I need to replace the vehicle speed sensor and need to know which would be easier. I have space to do either but not too much past that to work. So is it more worth the time to have to take appart all the exhaust and all to drop the tranni or unhook stuff to lift the engine. Suggestions?
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 02-25-2008, 04:14 PM   #2
elsanto
Member#: 34832
1989 M3
not sure lifting the engine would do you any good. you can probably get at it without dropping the trans, at least with a 5mt you can, really not sure wehre the vss is on the auto though.
elsanto is offline   Reply With Quote
Old 02-27-2008, 07:14 PM   #3
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Any second oppinions or more? Less of an issue as I'm having to drive it again without the speedo till I get my SVX with a new set of tires after last nights snowstorm and POT HOLE!
-Gaddis
Old 03-02-2008, 06:52 PM   #4
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Bump to see if anyone has any more oppinions. I can unbolt the engine and hoist it enough to shimmy into the bellhousing. I'm thinking that's my best bet as the least amount of disassembling things. My 3 litter will be here in a few days but I still need to drive the Impreza a little longer till I can start my swap. I don't like this whole revlimiting at 4k cause of the lack of the sensor and it's also killing my gas milage too while I"m driving. So anyone anything? Does that sound like a good idea?
-Gaddis
Old 03-02-2008, 07:19 PM   #5
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Bump it again.
-Gaddis
Old 03-02-2008, 08:23 PM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
Why would you need to drop the transmission or pull the motor? Just drop the exhaust, get a wrench on it and switch it out. It can be done.
legacy2003 is offline   Reply With Quote
Old 03-02-2008, 08:46 PM   #7
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Cause it's in the bell housing.
-Gaddis
anyone in prescott have a wrx tranny or engine out of a wrx? dan az South West Impreza Club Forum -- SWIC 10 05-16-2010 11:04 PM
tranny or engine swap first? shanemono4 Subaru Conversions 39 05-31-2008 10:02 AM
How do i take the 10mm hex bolt out to release tranny and engine? jefersun Transmission (AT/MT) & Driveline 3 06-02-2005 09:26 PM
Good place to pull 12v from engine bay WRX03 Electrical & Lighting 7 08-09-2004 06:03 PM
STi engine/tranny mounts = easier to hit reverse? Butt Dyno Transmission (AT/MT) & Driveline 11 02-12-2004 01:33 AM
