Old 02-26-2008, 07:51 PM   #26
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
Originally Posted by drummerRS2505 View Post
It will be loud on hard accel but it will make you . I have the stromung single hfc pipe and i think the RT pipe has 2 hfc. Mine is quite tame at cruising rpms and almost not noticeable on the highway/interstate. Just don't romp on it around cops, especially if they are tards in your area, you'll be fine.
Cool, thanks for the advice. The only way to tell is to install them. So i'll find out next week.
leafs fan is offline   Reply With Quote
Old 02-26-2008, 08:59 PM   #27
GrundleJuice
Member#: 165749
Originally Posted by Bluefoton View Post
True! But if you do it in an area where salt, snow, and slush make your life miserable every winter, you just ask for the headers to disintegrate after a few winters
Not to mention the entire drop of oil + wrapping = fireball issue...
No, actually it's not an issue. IF a drop of oil or even more than that soaked in the wrap it would priobably smell for a few miles but thats about it. I have soaked my OEM heatsheild insulation with oil just about every time i change it since the filter is above the header and it just does't happen (fire). And for the headers disintigrating in snow, salt, etc, that wont happen with a set of stainless headers. even the low quality stainless will last quite some time with all that crap on it. Salt not only lowers the freezing point of water to melt ice/keep it from freezing but it also lowers the boiling point of water so any moisture that is in the wrap will be out of it in the form of water vapor sooner than if there was no salt. I know it seems like salt and water would be the worst thing for steel headers but its ignorant to think that. just trying to be informative.
GrundleJuice is online now   Reply With Quote
Old 02-26-2008, 09:35 PM   #28
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Hm, thanks for the info. I did read a lot on here regarding wrap, and the opinions do seem to be divided
The sealer + wrap should in principle be sufficient (and happily endorsed by SubieGal if I'm not mistaken), yet the coolant catching on fire upon contact with the wrap wasn't an invented story. Then you have the issue of heat containment, and thereby larger T swing between the car running/cold, which in turn implies more mechanical stress, and possibility of cracking.
I wont argue against, as I don't have them on. Won't wrap mine now as they are on the car, and I dont have $ to get them off and on in a garage for the moment. So my only two cents is that it looks ugly
Old 02-27-2008, 12:29 AM   #29
pondomoto
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
pondomoto is offline   Reply With Quote
Old 02-27-2008, 02:48 AM   #30
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
Are you saying it sounds better cause the headers are wrapped or just better then stock. Please explain.
Old 02-27-2008, 04:31 AM   #31
pondomoto
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
sounds better than stock. when it was stock, there was hardly any rumble...
the ticking sound is a lil louder tho. in reality they should be ceramic coated or wrapped because it would deaden that sound. I love em and they sound great to me and i get compliments left and right...
Old 03-07-2008, 01:11 AM   #32
ShadowVlican
Member#: 156965
from a purely stock car to a UEL header, i couldn't hear a difference
it was when i installed an axleback, then the rumble came out
ShadowVlican is offline   Reply With Quote
Old 03-07-2008, 11:41 AM   #33
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^^ True. Little difference without a cat/axelback, unless you stand behind the car and someone revs it a bit. From the driver's seat any difference is drowned in the engine bay noise.
Old 03-07-2008, 01:05 PM   #34
SLI99
Member#: 134819
2005 Ford F150 FX4
Just finished my setup on my 99 DOHC Legacy
-Borla Header
-Custom axel back with a vibrant muffler
At Idle it sounds absolutly amazing with a 2.0 WRX Rumble to it....in normal driving conditions it just rumbles away and makes everyone look. At wide open throttle with the intake involved it will rattle your ear drums. From a being around subaru's my whole life i cant describe a nicer sound.
SLI99 is offline   Reply With Quote
Old 03-07-2008, 01:08 PM   #35
ShadowVlican
Member#: 156965
-Borla Header
lol that's EXACTLY what i'm running
Old 03-07-2008, 01:38 PM   #36
SLI99
Member#: 134819
2005 Ford F150 FX4
haha shadow... good minds think alike
Old 03-07-2008, 01:45 PM   #37
2.5GTLegacy
Member#: 111219
-Borla Header
Sound clip?
2.5GTLegacy is offline   Reply With Quote
Old 03-07-2008, 01:55 PM   #38
SLI99
Member#: 134819
2005 Ford F150 FX4
Ill have one by tomorrow
Old 03-07-2008, 02:05 PM   #39
2.5GTLegacy
Member#: 111219
So you just kept the stock cats and mid pipe?
Old 03-07-2008, 02:19 PM   #40
SLI99
Member#: 134819
2005 Ford F150 FX4
yep...going to be getting a midpipe soon
Old 03-07-2008, 02:29 PM   #41
2.5GTLegacy
Member#: 111219
cool. Im thinking of getting the borla knock offs, keep the stock cats, and stromung mid pipe and keep my spt axle back. should be a tad loud im assuming.
Old 03-07-2008, 02:52 PM   #42
SilverSubie2.5
Member#: 136144
2010 STi
With the stock cats and SPT axleback, I can't imagine it would be very loud at all. Certainly on the tamer end of things. Report back with how that sounds though, I'd be interested to know. I feel like while my STi axleback sounds ok with the Borla's, it's holding back way too much rumble. I need something that will let a little more rumble out, without being much louder.
SilverSubie2.5 is offline   Reply With Quote
Old 03-08-2008, 10:23 AM   #43
SLI99
Member#: 134819
2005 Ford F150 FX4
I just had that set-up with an SPT Axel back and you cant hear a damn thing unless you were to crawl inside the tailpipe
Old 03-21-2008, 05:27 AM   #44
Blue_Steel_00
Member#: 168831
2000 2.5RS
BRP
Last weekend I installed UEL Borla headers on my 2000 RS.
Current Set Up:
Ganzflow Intake>Borla Headers>Stock Dual Cats>2.5" Custom Midpipe>Prodrive Axelback Exhaust
The bass like pulsing is obvious when at idle, and the rumble is there (inside the cabin and outside) when accelerating from low RPM's. But the pulsing/rumble disappears after 3k and the intake can be heard. Do you guys think removing one of the dual cats or replacing them with a HFC will open her up a little more? Or do you think the Prodrive Axelback (which I think is similar to the SPT), is REALLY that good at muffling the sound?
Thanks.
Blue_Steel_00 is offline   Reply With Quote
Old 03-21-2008, 03:52 PM   #45
SilverSubie2.5
Member#: 136144
2010 STi
Yea, pretty much the same deal here. It sounds great until about exactly 3k like you said, then nothing. I'm surprised to hear that from the Prodrive, though.
Old 03-21-2008, 03:59 PM   #46
Bluefoton
Member#: 141373
2008 2.5i-hatch -
isnt the nothing because it's muffled by your intake? It's one of the reasons I went back to stock muffled intake... well for now.
Old 03-21-2008, 05:52 PM   #47
pondomoto
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
was there a verdict reached on whether or not it is good to wrap your headers? i cant stand the ticking sounds...
Old 03-21-2008, 06:28 PM   #48
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ Opinions are still divided. One thing is certain, the more snow you have, the worse of an idea it is because of the salt/sand/water combo. If you plan on keeping your car for another say two years, then why not... I dont think the headers will suffer too much in such a short timeframe.
Old 03-21-2008, 07:05 PM   #49
pondomoto
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
i heard something about the ceramic coating being a bad idea because of heat changes? i was thinking about doing this because i do travel into the snow almost every weekend during the winter... that being said, it will probably only be that frequent for 2 years and at that point, i could say screw it and just buy new ones or repair the damages i guess
Old 03-21-2008, 10:02 PM   #50
Blue_Steel_00
Member#: 168831
2000 2.5RS
BRP
I was surprised too, but I still love the Prodrive exhaust overall, its perfect in stop and go traffic. And I appreciate the fact that there is no droning at freeway speeds. But it would be great if I could maintain that pulse/rumble sound throughout the entire RPM range. I just donít know how to achieve this, since the HFC seems like it will be too loud for my taste, and the stock dual cats are too quiet.
The Ganzflow Intake doesnít really become vocal unless youíre at WOT. During normal acceleration I primarily hear noise from the engine from 3k to 4.5k, and then the intake kicks in. So for that reason I donít believe the intake is overpowering the headers and exhaust. Good question though.
WTT Stromung NA Catback/Borla UEL Headers for Stock Catback/Headers Plus Cash chop204 Engine/Power/Exhaust 14 04-05-2010 12:46 PM
Borla UEL Headers. Unknown Divorced DP. Immaculate! ChronoX720 Engine/Power/Exhaust 46 04-18-2009 12:55 PM
Stock Header VS. Borla UEL Gr3en Normally Aspirated Powertrain 6 04-17-2009 10:36 AM
Borla UEL Headers ? chop204 Normally Aspirated Powertrain 8 02-12-2009 03:04 AM
NJ: GC jet-hot coated borla UEL headers and stock headers M E R C U R Y Tri-State Area Private Classifieds 1 05-12-2008 02:58 PM
