Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 04-09-2008, 08:34 PM   #51
shinji666
Member#: 152450
2001 Impreza 2.5RS
Hey Bluefoton,
just wondering do you have sound clip (rear/in car) of ur borla/sti catback setup? I got borla already and thinking of going sti catback. I'm wondering how it will turn out.
shinji666 is offline   Reply With Quote
Old 04-10-2008, 12:33 PM   #52
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Will get it this weekend. Still very happy with it. Very little noise increase in freeway coasting (which for me was important), but idle and city driving are just perfect.
here are two videos of the same setup though - they were the very reason I went for the sti catback!
http://www.youtube.com/watch?v=NOoLxePwvU8
http://www.youtube.com/watch?v=fAMwNseJ-58
Old 04-10-2008, 08:29 PM   #53
shinji666
Member#: 152450
2001 Impreza 2.5RS
thanks bluefoton! It sounds awesome =D
I wasn't able to find a sti catback locally but i was able to find the axleback. Do you think the sound will be any different?
Old 04-10-2008, 09:28 PM   #54
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Probably not difference in the sound. go for the axelback! Changing the catalyctic converter will make it significantly louder, though it wasn't something I looked for.
Let us know how you like it - and dont forget to fill your profile
Old 12-11-2008, 03:46 PM   #55
boymk
Member#: 172844
2007 2.5i
Newport Blue
currently boxer4racing offer $1500+ to get full stromung cat and borla headers +shipping.
If you want to pay for approximately $2000 for the "rumble" sound...
For me, I just use that money to exchange for a real wrx (may be older version) but it's not quite neccessary right now...
Good luck on finding the "rumble" bro
boymk is offline   Reply With Quote
Old 02-07-2010, 03:53 PM   #56
BLUJI
Member#: 52518
2002 OBS
savannah
Question
Originally Posted by RS Guy1513 View Post
gotta spray em so they don't turn into a wick...i got my wrap in a kit with spray and metal bands...also putting a skidplate under em, so hopefully that will keep alot of the salt and **** off
Did the header fit with the skidplate? I have an 02' wagon w/ the Primitive skids & was wondering if a uel header would fit with them. Also what brand header do you have? Regards
BLUJI is offline   Reply With Quote
Old 02-08-2010, 09:27 AM   #57
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Yes it does. I got a primitive skidplate with Borla knock-off UELs. However, I believe that longer spacers when bolting on the plate are required to accomodate the headers (I specified I have aftermarket headers when getting the skidplate, and I was told that it affects the spacer lengths)
Old 02-08-2010, 11:11 PM   #58
BLUJI
Member#: 52518
2002 OBS
savannah
Thumbs up skid + header
Thanks a lot Bluefoton! you've probably saved me from some frustration!
What height are the spacers approximately?
I could probably fab up some from round stock & get longer bolts.
Your whip sounds great, I definitely look forward to getting the header now
Old 02-09-2010, 01:11 PM   #59
Bluefoton
Member#: 141373
2008 2.5i-hatch -
I'll check when I get home, should have their emails somewhere. Something around 2" in front and 1" in the back, or less? The spacers are just aluminum cylinders stuck between the plate and the car,so nothing fancy. Also - in my opinion - the spacers they gave me are a bit too long in front, so if you have any shop capabilities, the best is to try it yourself.
It's not a too good photo for this purpose, but if you look at the front underneath the bumper you can kind of see the skidplate's line along with the three bolts/spacers. it's slightly bent upwards in front so that you dont decapitate anything too I have rubbed against roks and mud with the plate, and hit curbs more than once when parking perpedincularly to a sidewalk. Horrendous screeching noise of the metal against concrete, and never damaged anything. Solid stuff!
While you're at it, get an STI catback. Cheapest exhaust option by FAR for our cars, and while being much more quiet than any aftermarket solution, it sounds much better than stock exhaust + UEL headers.
Old 02-11-2010, 05:41 PM   #60
BLUJI
Member#: 52518
2002 OBS
savannah
Outback Sport skid+header
I see the plate hangs significantly lower than mine, I'll just have to make some 2" ones and cut down to a reasonable height after I put the header on. I did cut the factory plastic cover with a dremmel & put this one over it which keeps the sides closed up.
Also I do have an STI catbk. on it already & I definitely don't want it to be loud, just "sporty".
I love what you did with the headlights, Great job & Thanks again! ++
6/2010'
Just did my clutch recently and I added a fiberglass wrapped UEL Borla type header which I had to bend because it was hitting the chassis (not fun) but it sounds good now & just a shade quiet w/ the sti catbk.. Also on the skid plate the front spacers are 1 3/4" (Primitive's) & the rear are 1 7/8" ( I added) leaving about 3/8" between the header. 77mm for all 5 bolts + thick 3/4" washers.
Happy the way it all came together : )
Old 02-11-2010, 07:12 PM   #61
RaceCarRiot
Member#: 6542
1997 Ver IV
Running an STi rear section, with a straight through midpipe, and the Borlas on a 2.2L.
A bit LOUD when you get on it, but pretty much silent at cruise. Though there is a nasty ricer rasp between 2-3K if you're in a higher gear and get on it. Backfires like crazy engine braking.
Only real downside is the amount of heat escaping makes the engine take forever to get up to operating temperature, and the car runs a touch rich.
RaceCarRiot is offline   Reply With Quote
WTT Stromung NA Catback/Borla UEL Headers for Stock Catback/Headers Plus Cash chop204 Engine/Power/Exhaust 14 04-05-2010 12:46 PM
Borla UEL Headers. Unknown Divorced DP. Immaculate! ChronoX720 Engine/Power/Exhaust 46 04-18-2009 12:55 PM
Stock Header VS. Borla UEL Gr3en Normally Aspirated Powertrain 6 04-17-2009 10:36 AM
Borla UEL Headers ? chop204 Normally Aspirated Powertrain 8 02-12-2009 03:04 AM
NJ: GC jet-hot coated borla UEL headers and stock headers M E R C U R Y Tri-State Area Private Classifieds 1 05-12-2008 02:58 PM
