Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-25-2008, 12:56 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default wierd engine install question
ok so i got me new engine in the car and mounted to the trans. But the bolts are not lining up with the holes for the motor mounts to go in. its sitting on the subframe, and is about 1/4 inch away from dropping right in to the holes. does ont have much room to push back. any tips to getting this sucker in? after i get it in, its just finishing up a few things and should be good for start up.
farrell is offline   Reply With Quote
Old 02-25-2008, 01:06 PM   #2
Meridius
Member#: 140682
06 WRB STI, 09
Legacy 2.5GT, 05 Fozzy
sounds like you got em on backwards, happened to me once so dont feel bad. try jacking the engine back up as high as you can getit and then you should be able to get them swapped backaround without puling the entire engine again, kinf of a pita but it can be done.
Meridius is offline   Reply With Quote
Old 02-25-2008, 01:10 PM   #3
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
:P i never took them off the new block. (using the mounts they came with.) so i would assume they are on the correct way.
Old 02-25-2008, 03:13 PM   #4
Meridius
Member#: 140682
06 WRB STI, 09
wrong mounts then? did the engine come out of the same car? Id just try taking the mounts off the old engine and put thm on the new one.
Old 02-25-2008, 05:34 PM   #5
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
same car same engine. it just needs a wiggle. seeing if anyone has gone through this.
Old 02-25-2008, 06:09 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
If it just needs a wiggle then commence wiggling. I don't know what you expect us to tell you.
Old 02-25-2008, 09:28 PM   #7
Meridius
Member#: 140682
06 WRB STI, 09
might just be hanging up then, try taking the pitch stopper loose to get some tension off of it then just grab ahold of the engine say by the valve covers and shake it back and forth if its as close as you say it its then it will more than likely drop in.
Old 02-25-2008, 10:54 PM   #8
GrundleJuice
Member#: 165749
hammer. 20 lb sledge should do er just fine. have to whack it just right though, or you'll break it. its all in the hips.
Old 02-26-2008, 03:22 AM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
A phooey.
Stick a long prybar up against the stud for the motor mount and smack it in there with a hammer. Then go to other side and do the same thing. It helps when you relieve some weight from the mounts too. Otherwise you may rip the threads off the motor mount studs. Jack up the trans a bit.
Tim Sanderson is offline   Reply With Quote
Wierd Engine Noise Skoodge Newbies & FAQs 6 09-24-2009 06:47 PM
engine install questions dt311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-17-2005 01:42 AM
Wierd engine sound SubyBean Normally Aspirated Powertrain 4 03-22-2003 05:29 AM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 10:04 PM
engine / tranny mount install question TerenceT Transmission (AT/MT) & Driveline 1 03-12-2002 01:46 AM
