Old 02-25-2008, 12:31 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default highest CR Subaru engine ??
I"m weighing out my options for my rally car build. Not sure If I'm going FI or high CR NA.
Who of you out there are running high CR engines?
What kind of power are you making? whats your CR ??
mods ??
is it necessary to upgrade rods & pistons? or do you find your stock rods are adequite... I would assume cross drilling your stock crank is prefered in order to up your redline a bit.
IllNastyImpreza is offline   Reply With Quote
Old 02-26-2008, 02:47 AM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
sorry to ask, but what is CR?
PA-Outback2000 is offline   Reply With Quote
Old 02-26-2008, 08:47 AM   #3
Silver '02 REX
Member#: 27963
2013 Focus ST2
PB
Compression Ratio
Silver '02 REX is offline   Reply With Quote
Old 02-27-2008, 04:36 AM   #4
PA-Outback2000
Member#: 161832
i haven't seen many upgrades out there that go much passed 11:1 or so. i know mine is 9.7:1 or 10:1.
Old 02-27-2008, 08:46 AM   #5
Vmiz
Member#: 115744
i run a stock sti short block with 11.7
power is 150 t accross the board and 187 hp with the 06 intake manifold
spin the motor to 7500 every day around town and have no issues
Vmiz is offline   Reply With Quote
Old 02-27-2008, 02:34 PM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
awesome
must have some decent punch... is that wheel HP ???
Old 02-27-2008, 06:28 PM   #7
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
Whats so special about the 06 manifold?
Any more info on it?
Sorry for the higjack
Guerice is offline   Reply With Quote
Old 02-27-2008, 06:32 PM   #8
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
I know where there is a motor that runs 13:1 and has 300 hp all N/A for sale if anyones intrested.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 02-27-2008, 07:18 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
better runner design, better overall flow vs. other N/A intake manifolds.
rougeben83 is offline   Reply With Quote
Old 02-28-2008, 01:41 AM   #10
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
And arent they plastic, for lower intake charge temps....
Old 02-28-2008, 08:42 AM   #11
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
no in 2008 they changed over to plastic i believe but in 06/07 they were still metal.
zavier is online now   Reply With Quote
Old 02-28-2008, 09:46 AM   #12
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Sent a pm about this.
Josh
atech_rallyrs is offline   Reply With Quote
Old 02-28-2008, 10:43 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I would LOVE to see this '06 Manifold's runners. Is it something along the lines of the WRX manifold? BIG runners like that?
FuJi K is offline   Reply With Quote
Old 02-28-2008, 01:50 PM   #14
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Josh
I would love to build something like that...
what block did they start out with ??
Old 02-28-2008, 04:41 PM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^coughirishmikescough
Old 02-28-2008, 05:11 PM   #16
SURF4ME
Member#: 173128
2005 2.5 RS
if you are serious about N/A power.. you need to read the N/A white paper write up.. I remember when it was posted a few years.. very very informative.. it basically covers every aspect of N/A power.. have a look.. it should be a sticky.
http://forums.nasioc.com/forums/show...ighlight=paper
SURF4ME is offline   Reply With Quote
Old 02-28-2008, 05:13 PM   #17
SURF4ME
Member#: 173128
2005 2.5 RS
HIGH COMPRESSION PISTONS
This is the big dog of mods. Not necessarily because of power gains, of which there are good ones, but because of the work necessary to do this. The pistons raise the compression of the EJ25 from its decent 10:1 ratio to some where near 11.2:1 for street purposes. Anything beyond this requires high octane race gas to run correctly as well as standalone EM. At the 11.2:1 level the motor will require good quality premium all of the time. It has been brought to my attention that 12:1 compression may be the safe limit for 93 octane use. But a quality EM system is highly recommended, otherwise engine may BOOM!
This mod usually requires that the bottom end be beefed up. This means better main bearings, better rods and forged crankshaft for reliability. The pistons themselves cost around $700 -$800. TWE shows $719 on their site just for the pistons. The additional block work and parts will likely run another $700 - $800 assuming you do the assembly.
Additionally some owners are using the Sti’s EJ257 block as it has the necessary reinforcement already. New Sti Blocks cost about $1700 though used ones can be had for around $1000.
Old 02-28-2008, 10:48 PM   #18
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I might even end up just doing the frankenstien build... anyone remember the CR it produces on the 2.2 heads ?? and approximate HP ???
Old 02-29-2008, 04:22 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Find any N/A '05-07 EJ25 and there's the manifold. Not too hard to find.
I assume that came from the "white paper"? Not the most technically correct stuff there. New bearings are a good idea on any engine rebuild/upgrade, but the stock rods and crank should be perfectly fine, particularly at the power levels we're talking. Of course, you can be crazy like me and do lighter rods and piston pins, too (but I'll still be using the stock Phase II N/A crank).
Too bad you couldn't search for info on the frankenstein build, as it's never EVER been discussed in dozens of threads in this forum and the Built Motor forum and the Subaru Conversions forum.
As for approximate HP, as with any build, that depends on a helluva lot of variables. I say approximately 137.357573183097134578hp, but that's just me.
Pat
Old 02-29-2008, 09:53 AM   #20
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Originally Posted by Patrick Olsen View Post
... Of course, you can be crazy like me and do lighter rods and piston pins, too (but I'll still be using the stock Phase II N/A crank).
so what CR are you running ? whats your settup consist of ?
Pat
thats too bad... someone should talk about it more ...........
Old 02-29-2008, 10:18 AM   #21
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Ha ha yup. Its just sitting under a work bench all alone with no one to play with it. I really want to go pick it up. Well see how the money works out with tax retuns.
Josh
Old 02-29-2008, 10:39 AM   #22
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Josh
o **** thanks for reminding me... Gona go do mine right now
Old 02-29-2008, 04:29 PM   #23
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The engine isn't built yet - all the components are in storage waiting for me to complete a change of duty station. CR should be ~10.8:1 once it's all together. Phase I DOHC heads (Cobb ported), Phase II block, OEM Phase II pistons (100mm), Crower rods (quite a bit lighter than stock, can't remember the numbers off the top of my head), TWE piston pins (also quite a bit lighter than stock.
Pat
Non-Subaru engine into a Subaru jaed_43725 Subaru Conversions 17 06-24-2013 12:12 PM
Highest HP Subaru on Pump and race fuel? rice h8r Proven Power Bragging 142 01-21-2009 02:06 PM
('93-'01) Whats with these SUBARU Engines?????? cpages2 Impreza Forum 22 11-08-2007 07:44 PM
whos got the highest HP subaru? IllNastyImpreza Proven Power Bragging 26 04-14-2007 11:00 PM
My Yota Just Hitt 700,000 Whats The Highest Milage Subaru SleepinCreppin02 Off-Topic 54 01-20-2006 01:18 PM
