Old 02-25-2008, 07:16 PM   #1
sanovichleo
Member#: 68099
2000 Impreza RSTI
Blue Ridge Pearl
Cool Coolant disappearing, wtf!!!
sup guys, heres my quick story...
i have a sti swap with a stock rs radiator, only 1 fan is hooked up (no a/c)
i went to a track last wkend and the car overheated and lost sum coolant... i filled it back up but ever since ive noticed that its slowly been losing coolant...
I thought there were some air bubbles in the system so i did the recommended procedure and popped the tank near the turbo, filled it up when engine was cool, warmed car up, let it cool back down.... The plastic overflow tank near the battery doesnt change levels, its still full, but the tank near the turbo continues to lose the same amount of coolant everytime after i refill it, warm it up and let the car cool back down... I thought that its just the air bubbles disappearing, but ive done this 3 times and everytime it loses the same amount of coolant at the tank near the turbo. Ive been leaving the cap on as the enigne warms up just as directed in the manual.
Any ideas??? dont wanna say it but it may be head gasket issue if its not the air bubble problem... I am getting a new and bigger rad asap but im concerned that a bigger rad isnt going to solve this problem.
Thanks in advance guys
sanovichleo is offline   Reply With Quote
Old 02-25-2008, 07:22 PM   #2
sanovichleo
Member#: 68099
2000 Impreza RSTI
Blue Ridge Pearl
oh and it was weird... i drove the car today,temp was normal while driving... parked and idled for 3 min, temp was still normal, didnt shut the car off and put it in first and 4 seconds later literally right after i pressed the gas temp spiked up to 2/3 H... very weird anyone know what that was about???
and ive had the car now for 2 months w the swap and this is the first overheating issue ive had with the stock rs radiator
Old 02-25-2008, 10:11 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
coolant pressure test ftw
fastnoypi is offline   Reply With Quote
Old 02-25-2008, 10:50 PM   #4
RoadTrippin
Member#: 161175
if it is slow coolant loss I would go with cracked rad, though if you overheated (depending on how bad) you could have possibly blown the head gasket in which case you may have coolant mixing with oil...would appear to be chocolate milkshake on the bottom of the oil filler cap or when you drain the oil. As far as the temp spike chances are after you overheated you probably busted the thermostat so it cant regulate temp anymore....
I would first find out for sure where you are leaking from, UV dyes can help if you cant find it on your own.
Next regardless of where it is leaking from it is always a good idea to replace the thermostat after an overheat (espeically if the head gasket is shot) its a cheap part and better safe now than putting in all new parts only to have the same thing happen again because you didnt replace the real problem.
RoadTrippin is offline   Reply With Quote
Old 02-26-2008, 02:30 PM   #5
sanovichleo
Member#: 68099
2000 Impreza RSTI
Blue Ridge Pearl
def gonna try to do a leakdown test asap
Old 02-28-2008, 10:57 AM   #6
sanovichleo
Member#: 68099
2000 Impreza RSTI
Blue Ridge Pearl
well just check the car again, the radiator (stock rs one) is leaking, hopefully thats the only leak lol... that was the only exterior leak that i saw, im going to get a compression check next week to check if the engine was damaged from the overheating issue...
I understand that the heads or block can warp if the car is overheating, but what generally is the time limit for that to happen? I mean how long does the car need to run hot before engine damage can be caused? BC everytime it overheated I immediately turned the car off
Old 02-28-2008, 10:05 PM   #7
nardvark
Member#: 145108
2002 Impreza TS
Well...I was riding in a mid-90's Contour, and a radiator hose cracked/failed/did something catestrophic. The amount of time was probably <20 seconds between when the needle started to shoot up, and when smoke started flowing over the windshield. Unfortunately we were on windy road so the driver couldn't kill the the power immediately (100 pound woman + no power steering = instant death).
I don't know what kind of engine was in the Contour, but aluminum engines are pretty intolerant of overheating. If you kept the temperature needle well away from the red zone, you're probably OK.
nardvark is offline   Reply With Quote
no coolant thermostat? WTF?! fl4tsc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-30-2008 03:53 PM
Coolant keep disappearing!!! Jerry Xu Normally Aspirated Powertrain 17 04-10-2008 12:02 PM
Disappearing / Reappearing Coolant AVATAR-X Service & Maintenance 3 08-13-2007 06:17 AM
Please help, coolant is disappearing! chuckml97 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-12-2007 03:21 PM
coolant being sprayed from overflow cap? wtf BIG_BALLS_BILLY Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 10-12-2006 12:23 AM
