Old 02-10-2002, 05:09 AM   #1
tave
Member#: 14867
2002 wrx wagon
pearl black
Angry cold starts can suck
My 2002 WRX made a horrible noise on cold starts. Took it in, it was the cam belt tensioner. They put a new one in and everthings fine.
tave is offline   Reply With Quote
Old 02-10-2002, 02:32 PM   #2
6Pack
Member#: 13901
2002 WRX Sedan
I've had 2 cold start incidents so far (one after the Die Hard Gold battery). Never had a terrible noise, but keep us updated if you're still having cold start problems...
6Pack is offline   Reply With Quote
Old 02-11-2002, 10:38 AM   #3
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
Well, Mister Tave!
So it was the cam belt tensioner, glad you got it figured out.
BTW: This is Greg Downing with the Silver Wagon that likes to sit at the bar and drink the PowerHouse brew!
See ya maybe next Thursday.
Greg D.
gpd323 is offline   Reply With Quote
Old 02-11-2002, 07:44 PM   #4
sevenhead
Member#: 15073
2002 WRX Sedan
Lotus Seven, A-H 3000
Was your "horrible" noise a loud knock that went away after the engine was warm? Did it come on suddenly, say after 5k miles on the car? I am ready to take mine in. It is embarrasing.
Thanks,
Lee
sevenhead is offline   Reply With Quote
Old 02-12-2002, 01:11 AM   #5
tave
Member#: 14867
2002 wrx wagon
pearl black
Lee I would be willing to bet you have the same problem I did. Tave
Old 02-12-2002, 01:29 AM   #6
sevenhead
Member#: 15073
2002 WRX Sedan
Thanks for the response Tave. Off to the dealer.
Lee
Old 02-17-2002, 05:10 AM   #7
sevenhead
Member#: 15073
2002 WRX Sedan
tave,
you won the bet -- cam belt tensioner. thanks for posting.
Lee
Old 03-13-2002, 08:05 PM   #8
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I have a 00 RS and did a tensioner and belt replacement this past weekend.
http://www.geocities.com/subarupat/tensioner.html
Here is pics of my old one. I ment to take pics of the new one. If you look at the pics you'll see the shaft. That is pushed out by a spring inside and pushes against engine block and which pushes down on the tensioner to automaticlly tension the blet. To keep it from bouching up and down. It's built like a strut with a spring inside. The oil dampins the any up and down motion. What happens is the seal leaks and the oil escapes and there is nothing to dampin it any more. So what you hearing is the tensioner going down and than up and bottoming out.
Pat
Patrick L is offline   Reply With Quote
Old 03-15-2005, 04:25 PM   #9
sticky tires
Member#: 53985
Hmmm.
My 05 STi makes an intermittent whining noise during cold starts. Sounds like a belt too tight/loose.
Argh, now I need to take it in.
sticky tires is offline   Reply With Quote
Scratching/Scraping sound when cold starting speedracer47 Normally Aspirated Powertrain 14 05-23-2010 05:52 PM
Cold start noise. Sounds like marbles in a can... Valien Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-29-2006 07:52 PM
Cold Air Intakes Suck? SonicYellowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 10-07-2002 11:08 AM
Can the unichip cause cold-start problems MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-04-2002 03:00 PM
('93-'01) Cold starting up my Impreza RS 2001 AliasAngel Impreza Forum 17 06-01-2001 10:35 AM
