Old 02-26-2008, 12:02 AM   #1
WReXd
Member#: 114101
93 Impreza L Swap
Default think I fried my ecu...
So I flashed my ecu with ecuflash (internet getadom tune) using a friend's laptop (definitely not my first time). Some error popped up 2 or 3 times while I did it. As usual, it told me not to turn the key back from the ign on position, which I didn't. Finally it said the flash was successful, so I turned off the car, pulled the key out, disconnected the flash block and green connectors, and started the car. The car would crank but not start (tried 3 or 4 times), so I tried flashing the ecu again. No luck after that; I just kept getting errors over and over again, almost immediately after pressing "ok" for the flash. What could've happened?
WReXd is offline   Reply With Quote
Old 02-26-2008, 05:53 AM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Just reflash back to your previous rom image.
P.S. Did you modify the rom provided in any way?
wrxsti.l is offline   Reply With Quote
Old 02-26-2008, 08:12 AM   #3
Tea cups
Member#: 103136
do a hard reset (disconnect the neg terminal of battery and hit brake for 5 seconds), then try to flash again to a known good ROM
Tea cups is offline   Reply With Quote
Old 02-26-2008, 07:14 PM   #4
WReXd
Member#: 114101
93 Impreza L Swap
Thanks for the suggestion. It worked.
I Think I Fried My Canister Purge Solenoid Circuit Soul Shinobi Electrical & Lighting 1 10-22-2008 11:18 PM
Fried my ECU wiring? Fongers Open Source Reflashes 1 02-01-2008 12:26 PM
Fried my ECU today and burned up my motor. 06STi General Community 0 10-10-2006 11:18 PM
Think I fried my JL 12W3D2's SilvSuby Car Audio, Video & Security 18 06-26-2006 09:50 AM
