Old 02-10-2002, 01:25 PM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Thumbs up I tightened my left rear lugnuts and my CEL went out!
For a month or so I've been having problems with a misfire on the #2 cylinder (see http://i-club.com/forums/showthread....86#post1449186 for details). At the same time, I've been getting an occasional noise from the left rear wheel, which I figured was my wheel bearing going bad.
Well, Friday I was going to be driving a somewhat long distance, so I decided to check the torque on all the lugnuts. Lo and behold, three of them on the left rear were loose!! So, I torqued things back down and away I went.
Since then, my CEL has been out! Could I have discovered some super secret Subaru CEL fix?
Seriously, I'm hoping my misfire has somehow managed to fix itself. I replaced the #2 spark plug and on two mornings since then the CEL was out when I first started the car, but it came on later in the day. This time it's been out since Friday, and that's even after doing a very cold start after the car had sat overnight in 10deg weather in NH. (The misfire CEL first appeared when the cold weather appeared here in CT).
Keep your fingers crossed! And for those of you with CELs triggered by an aftermarket header, go check those lugnuts!!
Pat Olsen
'97 Legacy 2.5GT sedan
Car repair wizard
Old 02-10-2002, 01:41 PM   #2
Jademonkey
Member#: 9213
2000 RS
Red
After installing my header, I made sure to tighten those lugnuts.
Good luck with the CEL...I know how frustrating that can be...
Jademonkey is offline   Reply With Quote
Old 02-10-2002, 04:06 PM   #3
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
Wink
If that CEL comes back, check your muffler bearings
Blinker fluid too
ylexot is offline   Reply With Quote
Old 02-10-2002, 04:16 PM   #4
GRWRX
Member#: 4129
2002 WRX sedan
Once I changed to synthetic blinker fluid, I never got another CEL. Turbo spool up is quicker also.
GRWRX is offline   Reply With Quote
Old 02-11-2002, 02:20 PM   #5
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
i have a carbon-fiber powerband on order . . .
and yes, those muffler bearings are SO problematic!
slater is offline   Reply With Quote
Old 02-12-2002, 01:14 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, damn, my magic wore off tonight and the CEL came back on. Very strange, I can't ever feel any difference in the way the car is performing, so I don't know why the CEL is being triggered.
slater - I hadn't thought about replacing the stock powerband with a carbon fiber one - that just might do the trick!
Pat
Old 02-12-2002, 11:56 AM   #7
Mike2000GT
Member#: 2709
2006 WRX Wagon
SGM
Pat,
Did you check the connector on the #2 injector? It may have gotten knocked loose when swapping out the exhausts from the dyno day.
Any exhaust leaks in that area?
How's the connection of the plug wires to the coil pack?
Just rattling some things off the top of my head.
Mike
Mike2000GT is offline   Reply With Quote
wtb: 04 wrx left rear knuckle and left rear laterial arm fdrx7 SCIC Private Classifieds 2 01-27-2010 01:12 PM
My 1st and 2nd gear went out! Need help went taking out tranny? Kavaoski_08 Transmission (AT/MT) & Driveline 4 09-29-2007 10:16 PM
How do I tighten/quiet the rear hatch on my 98 OB Sport? eakins Interior & Exterior Modification 3 06-03-2004 02:16 AM
I'm so proud of my left foot! I had my first unconscious left foot brake last night! Sean New England Impreza Club Forum -- NESIC 5 01-29-2002 09:49 PM
