Old 02-26-2008, 02:18 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Caterham 7 RST-V8 with 500+ HP Supercharged 2.4L V8
As if 400 HP weren’t enough for the cart-like Seven roadster, Caterham has introduced an even more extreme version of the car developed in conjunction with niche engineering house, “RS Performance”. Dubbed as the Seven RST-V8, the ultimate Caterham packs a supercharged 2.4-liter 40-valveV8 engine that delivers more than 500 bhp at 10,000 rpm and 300 lbs-ft or torque at 8,500 rpm.
As if that wasn’t enough, weight reduction runs throughout the car, from the carbon fibre interior finished with Kevlar seats down to the hosing used on the cooling systems. According to Caterham, the RST-V8 weighs in a mere 520 kg or 1,168 lbs.
In terms of acceleration figures, the Brits claim that the ultimate Seven goes from nought to 60 mph (96 km/h) in less than 3.0 sec. In case you’re interested, prices for the RST-V8 start in the UK at £115,000 or $226,300 / 152,700.
http://carscoop.blogspot.com/2008/02...th-500-hp.html
Old 02-26-2008, 02:19 PM   #2
Lantec
Member#: 48685
2010 Prius
Wow, now that's a car worth dying in!
Lantec is offline   Reply With Quote
Old 02-26-2008, 02:22 PM   #3
Chiketkd
Member#: 71634
In hibernation...
The power-to-weight ratio for that car must be insane!!!!
Chiketkd is offline   Reply With Quote
Old 02-26-2008, 02:23 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
wow...500+hp on that go kart!
jigga is offline   Reply With Quote
Old 02-26-2008, 02:26 PM   #5
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
At that power to weight, it's definitely a car you'll be dying in!
I want...
FromageTheDog is offline   Reply With Quote
Old 02-26-2008, 02:31 PM   #6
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Just crazy,Coffin Rocket anyone!!
Old 02-26-2008, 02:34 PM   #7
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
That is just crazy.......You would be more just trying not to die than driving/enjoying it......
It would be a fun 3 seconds though......
SilverSubaab is offline   Reply With Quote
Old 02-26-2008, 03:21 PM   #8
CryderSpeed
Member#: 88816
TO TWERK
2.4L V8, 10k redline... the noise that mill makes must sound like angels singing.
CryderSpeed is offline   Reply With Quote
Old 02-26-2008, 03:30 PM   #9
Humphreyj
Member#: 81594
^ Or screaming.
Humphreyj is offline   Reply With Quote
Old 02-26-2008, 03:51 PM   #10
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Considering the power to weight, how usable is the power? Would you be spinning the tires in every gear, coming out of every corner? I wonder if the traction gained with some sort of AWD system would be worth the weight penalty?
foxboroxt is offline   Reply With Quote
Old 02-26-2008, 03:52 PM   #11
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
I admit I am not well versed in Caterham,but here it goes
Why did they go with a 2.4L V8 as opposed to 3 or 4 liter.I imagine size but an odd choice.
Old 02-26-2008, 04:12 PM   #12
russnuck
Member#: 81152
2008 WRX Sedan
Spark Silver Metallic
That's what F1 is limited to, there must be a good reason
Im sure it has to do with weight, size, and of course rotational mass inside the engine to achieve that type of rev limit.
russnuck is offline   Reply With Quote
Old 02-26-2008, 04:53 PM   #13
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
such a car would deserve to only be driven on the track in prime conditions, shod with R-comps or, better yet, real race slicks.
shikataganai is offline   Reply With Quote
Old 02-26-2008, 04:56 PM   #14
Lantec
Member#: 48685
2010 Prius
Well, the power is likely to be spread over a large rev band (10k) and the torque isn't as crazy as the hp, so it shouldn't be too insane, still insane nonetheless but a little less so
Old 02-26-2008, 05:14 PM   #15
bal00
Member#: 54772
The engine is made by Moto Power and based on two motorcycle I4's.
bal00 is offline   Reply With Quote
Old 02-26-2008, 05:17 PM   #16
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Thanks for the info..
Old 02-26-2008, 05:25 PM   #17
CFar
Member#: 51896
16 WRX
With a 150 pd driver (not I! haha) thats the same weight as an F1 car. Just about 200 hp short though
CFar is offline   Reply With Quote
Old 02-26-2008, 06:03 PM   #18
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
the engine was originally based on a Hayabusa heads. 1200 x 2 = 2.4L so it basically two motorcycle motors in a V.
I think they were working on a 2.6L version.
http://www.radicalextremesportscars..../indexspec.php
and here is another version of car and motor: http://thekneeslider.com/archives/20...8-for-the-dp1/
probably my favorite application: http://www.dpcars.net/atom/ag.htm
Rapid_Roo is offline   Reply With Quote
Old 02-26-2008, 07:22 PM   #19
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
And really, with around a 200lb pilot, this and the Hayabusa share a very similar lbs/hp figure. (About 2.73 vs. 2.75lbs/hp).
Chromer is offline   Reply With Quote
Old 02-26-2008, 11:19 PM   #20
manticus
Member#: 162857
The Caparo has a similar power/weight ratio - I think your biggest issue with this Caterham would be the same issue the T1 has: traction at lower speeds (exiting corners, etc.). Aero can only help when you're going at full speeds, but I don't see that much in terms of aerodynamic aids on the Caterham...
I'd still take a Caparo over this, there's just something intoxicating about a car that is just as likely to burn you alive as beat the Top Gear track record by 6 seconds.
Ian
manticus is offline   Reply With Quote
Old 02-26-2008, 11:32 PM   #21
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
That's the other thing I was wondering about, the aero on the Caterham. I imagine on a big track, drag would be somewhat limiting. Just the drag of your head has to be significant (Clarkson in the Atom......)!
Old 02-27-2008, 10:48 AM   #22
Chiketkd
Member#: 71634
In hibernation...
+12345
Old 02-27-2008, 12:01 PM   #23
Skunkers
Member#: 115480
While I do think Caterhams look like crap, there's no denying the bad-assedry of this vehicle. I would do really stupid things in order to own this car...
Skunkers is offline   Reply With Quote
Old 02-27-2008, 01:05 PM   #24
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Good info thanks.
In the Ariel Atom,It looks like the plugs go through heads like in the old Hemis.Also the engine is bigger than I thought it would be,when you said it was 2 motorcycle engines in a V.
Old 02-27-2008, 03:21 PM   #25
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
Very cool, but that's A LOT of cash for a ltd purpose vehicle. I guess I just need to make more money.
E. Nick is offline   Reply With Quote
More details on the 500-hp Ariel Atom 500 V8 darknightohio Non-Subaru News & Rumors 67 11-20-2010 10:23 AM
FS: 32k 05 STI with 500+ hp 500+ tq NewSTI SCIC Private Classifieds 7 03-17-2010 01:05 AM
18" wheels for track with 500+hp? BuggeyEYED Proven Power Bragging 20 09-20-2007 11:25 AM
18" wheels for track with 500+hp? BuggeyEYED Tire & Wheel 2 09-14-2007 10:36 PM
TSX swapped EG Civic with TONS of mods! 2.4L in 2100lb car! junk240sx Private Vehicle 'For Sale' Classifieds 0 12-22-2006 01:11 PM
