Old 02-26-2008, 04:08 PM   #1
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Default Log Analysis Please
Analyze this log, please. It's an 04' 5sp WRX running Ziggys Stage 2 map. No changes from his tuning (yet). The ROM can be found here viewtopic.php?f=15&t=529
It appears good to me from what's included in this log. IAM is @16, and the fine correction only takes a dip shortly after tip-in (cant figure out why, though.). Other than that, it seems clean. I am new to logging Subarus, but have logged and tuned a bit in the Mustang world (albiet a simplified version of what Enginuity offers and not ECU based).
The things I don't have (the owner has ordered them, and they will be installed soon... thursday... ), are an EGT sensor and a wideband. Hense the exclusion of that data. Once I have those two sensors, I'll be home free. But, based purely on what I was able to capture, do these values look clean? If so, and based on AFR's and EGT's, I may get a bit more agressive with the map. Also, I DO acknowledge that he is pretty much out of injector. We will not further this tune until we know for sure what's going on with temp and AFR and add more fuel. He plans on some pinks and a FP as well. He is gunning on max power from the TD04, and plans on porting the turbo. He alread has a ported throttle body, gasket matched manifolds, gasket matched uppipe, and cleaned up ERZ DP (for those of you that own one, you'll understand the cluster **** they made the bellmouth), and ported intercooler y.
http://home.mchsi.com/~drgrcr/Ziggy_stage_2_Jake.xls <<right click and save
Obsessive is offline   Reply With Quote
Old 02-27-2008, 07:42 AM   #2
Obsessive
Member#: 77302
damn well better
Anyone?... Bueler?... Bueler?...
Old 02-27-2008, 10:07 AM   #3
quazimoto
Member#: 70395
Try holding the throttle open 100% the whole run to redline.You want to be WOT the whole run.What gear did you do this in?
quazimoto is offline   Reply With Quote
Old 02-27-2008, 10:57 AM   #4
Obsessive
Member#: 77302
damn well better
Yeah, he let off a bit early.
It was run in 3rd.
I really want to know if the knock correction in the map SHOWN is acceptable. Basically is [email protected], and knock correction @10, and fine correction (except for those two -1.05 points early on) @0 an indication that the car is not finding knock.
We are going to log quite a bit more, and are getting used to the way the subie ECU works with knock correction. I have read a very good thread on here about the system, but want to back it up with someone who logs frequently to make sure that what I 'think' I'm looking at is indeed true.
E
Old 02-27-2008, 03:17 PM   #5
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Learning View will help out. Do some complete WOT logs though first.
http://www.romraider.com/forum/topic2772.html
bucket7788 is offline   Reply With Quote
Data logging/analysis (Motec, etc) twizzstyle Motorsports 9 10-23-2008 05:36 PM
Log Analysis? mrbalwrx UTEC 9 03-29-2007 06:08 PM
Log analysis! mrbalwrx Engine Management & Tuning 0 03-25-2007 08:46 PM
UTEC Logging/Analysis software (need programmers!) serendipity Engine Management & Tuning 1 11-15-2004 07:18 PM
New Data Log Analysis Software for All! DataLogLab Engine Management & Tuning 17 09-16-2003 08:00 AM
