Old 11-20-2012, 05:25 PM   #826
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Originally Posted by Fonzey View Post
Out of interest, once the dials are plugged into the car - can the chip be reprogrammed via the car's serial interface port?
If the dealer for example needed to change the mileage on a car - would they be dismantling the cluster, unsoldering the chip and reprogramming or would they just plug into the diagnostics port and do it that way?
Dealers cant change the mileage at lest not that I have every heard. In the USA they would put a sticker on the door frame to indicate that the cluster was replaced at some mileage with a new one that has 0 miles on it.
I can program the chips without removing them from the cluster, but I have to remove the cluster from the car, disassembly it, and then solder some wires on to the board and use an in circuit programmer.
AFBeefcake is offline   Reply With Quote
Old 11-20-2012, 05:34 PM   #827
Fonzey
Member#: 338440
Thanks for the info Beefcake, much appreciated.
The incorrect mileage on my car wouldn't bother me so much, but I'd dread explaining the situation when it came to selling the car on!
Fonzey is offline   Reply With Quote
Old 11-21-2012, 11:33 PM   #828
grinch77
Member#: 198758
2004 STi
I just installed a Prodrive with dccd into my '04 STi and now the back lighting dosent work and none of the hvac controls light up. Anyone have a remedy for this?
grinch77 is offline   Reply With Quote
Old 11-25-2012, 11:38 PM   #829
Rymaster
Member#: 296277
2002 Impreza WRX
05 USDM STI Cluster into 02 WRX auto
-Cut B28 wire (cause radio fuse not to blow)
-Cut C9 wire (causing buzzing to stop)
-Shaved the A connector down slightly with a razor blade, leaving two open pins on the cluster exposed.
-Used two layers of electrical tape over the DCCD, ABS, Rear Diff Temp, and STI lights.
Sent cluster out to Speedometers, got it back within 2 weeks all done(slow shipping, they had it done the same day they got it)
Works great! Link to my thread about the swap.
http://forums.nasioc.com/forums/show....php?t=2436041
Rymaster is offline   Reply With Quote
Old 12-14-2012, 12:53 AM   #830
Ikant
Member#: 235925
so what about the a9 wire? i thought we were supposed to cut that one? does it hurt anything if you do?
Ikant is offline   Reply With Quote
Old 12-17-2012, 12:53 AM   #831
noHkost
Member#: 290422
2004 Subaru WRX
Java Black Pearl
Have a Nice Day? 05 STi cluster swap into 04 WRX
HELPP! Everything plugs in except the harness that plugs into the gas/temp I need to know whether this can be modified or not . Also, how to get rid of the buzzing noise , I can care less about the Brake light and other lights. I just need some help. Thanks!
noHkost is offline   Reply With Quote
Old 01-08-2013, 11:17 PM   #832
Rymaster
Member#: 296277
2002 Impreza WRX
Did you figure it out? You have to shave down the A plug sometimes, it leaves two pins open. What year is your car and what year cluster are you putting in? Wrx? Sti?
Old 01-08-2013, 11:41 PM   #833
Rymaster
Member#: 296277
2002 Impreza WRX
No it's the C9 wire, NOT A9.
At least for my year that I posted about, 02 WRX with 05 STI cluster.
It's been mistakenly called the A9 previous in this thread. If you are looking at the cluster it goes left to right labeling them. A- --B-- -C
Old 01-09-2013, 07:28 PM   #834
Infidel82
Member#: 343068
1999 RSTI
Red on red
Default Help
Hello everybody. I may be in the wrong place but hoping to get some insight.
I have a 1999 RS 2.5 (98 wiring) with a JDM V5 EJ20 running on a Haltech Sport 1000. Most everything is jiving, my issue lies in the fuel gauge department. After I installed the Haltech I lost my fuel gauge. Now I have done some poking around, as of yet the best I got was the low fuel light to work..... Atleast I know when Im bingo fuel. For that I ended up Grounding the ground wires on bulkhead B84: 80,20,69,95,94,19,46,17 and 18. Pretty much all the factory ecu grounds. Now Im left with the only real possibility that the 5 volt ref is missing. This I suspect is B84 wire 21...... Now the big question, if the Factory ecu provided this 5v, how to supply it without ECU?
Any help or insight would be greatly appreciated.
Thanks
Infidel82 is offline   Reply With Quote
Old 01-10-2013, 05:12 PM   #835
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
just installed my Ver7 ecu last night into my Canadain spec bugeye wagon, and it was a complete plug and play, no modifying plugs, cutting wires, or anything, and I have NO abnormal lights on. looks like it came in the car originally!
tersplat is offline   Reply With Quote
Old 01-19-2013, 03:51 PM   #836
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Does anyone know where I can get the 2003 WRX pinout diagram USDM?
Trying to hook up a 2007 sti to 2003 wrx and make my DCCDPro see the sti cluster.
sackytar is offline   Reply With Quote
Old 01-20-2013, 04:24 PM   #837
sackytar
Member#: 149262
PrimerGrey
Fingered it out!
Old 01-25-2013, 10:36 PM   #838
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Originally Posted by todeswalzer View Post
05 + 06 clusters are the same
Originally Posted by 05-rsx View Post
Originally Posted by Micky View Post
^^^ What he said. Here is 2004 ~ 2006 comparison for the 3 plugs, B + C are the same.
I'm an 07 STi owner that is needing a replacement STi cluster. I have gone through and searched the thread but there is no definite comment on which STi clusters are the same. Based off of this and my reading in the thread, would I be correct in saying that the USDM 04 STi is different from the USDM 05-07 STi clusters? Can I get any 05-07 STi cluster as a plug and play replacement?
I need to replace my cluster and do not want to modify the cluster wiring because I want everything to be working as it should. (I'm not trying to make "shortcuts" but am looking for the CORRECT replacement). Thanks in advance!
arco is offline   Reply With Quote
Old 02-17-2013, 10:27 PM   #839
Denninger16
Member#: 290966
2005 Wrx
World Rally Blue
Bumping this up. But I'm looking to put a 07 Sti cluster in my 05 wrx I looked got write ups and stuff couldn't find anything. If anyone has any info, or a write up please let me know thanks!!
Denninger16 is offline   Reply With Quote
Old 03-11-2013, 05:56 PM   #840
minorc
Member#: 208229
2010 STi
Probably the dumbest question ever but how do you ground a pin? Do I cut it and add wire to a chassis ground ? Pull out and tape.. ?
minorc is offline   Reply With Quote
Old 03-31-2013, 10:51 AM   #841
Tiller35
Member#: 217006
Has anyone swapped 04-07 wrx/sti gauges into an 02 RS?
When I bought a "full" 07 wrx wiring harness, it didn't come with the 'gauge' harness. One of the 02 RS plugs does fit in with the new 07 harness but the other side is too small. Is my only option to get the new gauge cluster and 'gauge harness'? or can I merge them?
Tiller35 is offline   Reply With Quote
Old 04-02-2013, 08:42 PM   #842
25rsti
Member#: 166324
It's not your only option but if I were you I would search for an 07 wrx gauge harness. Don't cheap out now, seems like you did right as to swap out the entire car.
Old 04-05-2013, 10:28 AM   #843
DUST 3000
Member#: 298544
2006 WRX
Gray
Default 2007 STi to a 2006 WRX Cluster swap
Does anyone have any info on how to do a STi cluster swap to a 2006 WRX? is it the same as the 2007 STi to a 2007 WRX?
Any help is appreciated, Thanks in advance!
DUST 3000 is offline   Reply With Quote
Old 04-15-2013, 01:03 AM   #844
spokenlastchance
Member#: 310930
2003 WRX
I've been having trouble with my water temp needle. It will do an entire full sweep, but it will not read anything after that is just goes all the way back down. After moving the needle around it looks like it's not fully on there from what I can tell. I haven't really found any information on how to pull them off the only person that I have known to have done that was Interior Flair any he is no longer doing this stuff. Anyone got any advise?
spokenlastchance is offline   Reply With Quote
Old 04-18-2013, 03:58 AM   #845
keegancdr
Member#: 226355
2002 Bugeye
wrb
Originally Posted by CoolRex View Post
^^^^^^Don't need to
Oh here's the diagram guys.
This works for my 2004 WRX using a 2004 USDM STi. Use at your own risk.....I'm not responsible if you damage something.
ok after a bunch of searching of this thread i found this picture. now i just bought a 2004 USDM STI gauge cluster and my car is a 2002 USDM wrx, my question, is will this work for me ?
keegancdr is offline   Reply With Quote
Old 04-18-2013, 02:04 PM   #846
keegancdr
Member#: 226355
2002 Bugeye
wrb
bump for my question^^
Old 04-18-2013, 03:43 PM   #847
spokenlastchance
Member#: 310930
2003 WRX
Yes it should that is a geneal mock up most people have had success with it.
Old 04-19-2013, 04:02 AM   #848
keegancdr
Member#: 226355
2002 Bugeye
wrb
does anyone have pictures of this?
Old 04-30-2013, 02:30 AM   #849
bigcale
Member#: 55959
05 WRX Wagon
OK I have an 05 wrx, what is the easiest (least amount of wires to mess with since I have color blindness issues) STI cluster to swap in?
bigcale is offline   Reply With Quote
Old 04-30-2013, 03:57 AM   #850
keegancdr
Member#: 226355
2002 Bugeye
wrb
i got in there today, you shouldnt have too much trouble with the color blindness because the connector sais in really small print on the connector itself what the pin numbers are. As for easiness i would say go with an 04 STI gauge cluster. thats what i picked up and i had huge success with mine. but then again i have an 02 bugeye. i would say that it should work out the same for you tho. use the thread search button in this thread because there is a bunch of info in here.
can we get some mods to start deleting duplicate threads? [27] Political Playground 2 11-05-2008 02:01 AM
STi hare emblem? where can i get one... evoeater8 Interior & Exterior Modification 13 07-12-2006 08:53 PM
can we get something started in RDU???(nc) imprezivSTi04 Mid Atlantic Impreza Club -- MAIC 3 04-04-2006 06:47 PM
02 sti hood scoop?? where can i get one? slaterdrew Private 'Wanted' Classifieds 2 02-06-2004 11:37 AM
lighted keyhole ring, can we get one? makanouchi Interior & Exterior Modification 12 11-22-2002 08:38 PM
