Old 06-27-2008, 07:38 PM   #101
ryanswrx
Member#: 181999
2002 Impreza WRX
got everything taken apart and set to go so please pm me with any info or advice Thanks
ryanswrx is offline   Reply With Quote
Old 06-28-2008, 01:36 AM   #102
mars636
Member#: 74547
2005 WRX
WR Blue
Strip the wire back about 1/2 an inch solder it and then bend it in half. Stick it into the cluster connector and silicone it in place. this is all i did and it has worked for about 10K with no problems.
Originally Posted by ryanswrx View Post
hi all I have a stupid question for you all. I did my cluster swap and my outside air temp doesn't work which I knew would happen. I got all the parts I need according to the DIY on scoobymods except that cluster pin. I have no junk yard near me and I am assuming the pin comes from the wire end not the cluster end. I don't wanna have to buy an entire harness for that one stupid pin. Could anyone please help. What can I do or where can I get this pin from?
mars636 is offline   Reply With Quote
Old 06-28-2008, 04:02 PM   #103
ryanswrx
Member#: 181999
2002 Impreza WRX
which wire and thanks! Please help me get this going
Old 06-30-2008, 01:36 AM   #104
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
most dealerships will have a "terminal repair kit" in either parts or service that should have the pin you need.
ProdriveDreams is offline   Reply With Quote
Old 06-30-2008, 08:23 AM   #105
ryanswrx
Member#: 181999
2002 Impreza WRX
thank you I will go over to curry subaru and ask! Keep ideas coming in case subaru doesn't have it
Old 06-30-2008, 04:44 PM   #106
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
^^^Let us know if the OAT does indeed work with the scoobymods guide!
tonecold is offline   Reply With Quote
Old 06-30-2008, 05:39 PM   #107
ryanswrx
Member#: 181999
2002 Impreza WRX
as soon as I get this pin I will finish and let you know
Old 07-01-2008, 01:03 AM   #108
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
comments on the scooby mods page report no success from a few of the people who tried it... love to see this work!
good luck!
Old 07-01-2008, 09:11 PM   #109
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
^^^Yea, I've been reading mix reviews on the scoobymod page.
Some say it doesn't work, but some say it does work.
Old 07-02-2008, 07:48 AM   #110
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I have got to get the ball rolling on mine. I can't find that one 2K resistor though.
CoolRex is offline   Reply With Quote
Old 07-02-2008, 09:49 AM   #111
rUDEbOYiAN
Member#: 124534
2007 WRX
Satin White Pearl
V8 STI Cluster into 07 WRX
-Illumination does not work
-ABS light stays on
please let me know how i can fix these 2 things
rUDEbOYiAN is offline   Reply With Quote
Old 07-02-2008, 09:52 AM   #112
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
-ABS light stays on
The illumination is probably on the cluster itself like mine is. press the odometer pin until you see Ill. Then use the other pin to change it up or down.
Old 07-02-2008, 10:03 AM   #113
rUDEbOYiAN
Member#: 124534
2007 WRX
Satin White Pearl
i just tried that but when i use the other pin it changes my red line light. I want to be able to change it from the controls on the indicator knob.
Old 07-02-2008, 10:05 AM   #114
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Then how to make the indicator on the knobs work is discussed in this thread. Did you read everything?
Old 07-02-2008, 10:12 AM   #115
rUDEbOYiAN
Member#: 124534
2007 WRX
Satin White Pearl
i did but just wasn't sure it that was for all models
Old 07-02-2008, 10:13 AM   #116
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
It should be but don't quote me on that.
Old 07-02-2008, 11:59 AM   #117
rUDEbOYiAN
Member#: 124534
2007 WRX
Satin White Pearl
since the wires are already there for the illumination, can't i just wire them to the correct port? but i also don't know which wire is which.
Old 07-03-2008, 02:07 AM   #118
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
I believe on the 06-07 you can not alter the illumination with the stalks on the gauge cluster. you have two options really and they are discussed in detail in a devoted thread in this forum or on scooby mods, but i think its here on nasioc. Basically you can either control the cluster OR youre dash with the stalk. Alternatively you could just wire in a potentiometer and mount it somewhere to control the cluster independently. search around some.
Old 07-03-2008, 09:42 AM   #119
ryanswrx
Member#: 181999
2002 Impreza WRX
you can get that 2.2 ohm resistor at radioshack
Old 07-03-2008, 09:50 AM   #120
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
It's not a 2.2 ohm resistor. The diagram says it's a 2.2 K ohm resister. Thats 2200 ohm resistor right?
Old 07-04-2008, 09:43 PM   #121
ryanswrx
Member#: 181999
2002 Impreza WRX
all are the same thing just typed different 2.2k ohm resister can be bought at radioshack for under two bucks. I got mine there
Old 07-05-2008, 02:14 PM   #122
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Got all my stuff....working on it tonight I hope.
Old 07-06-2008, 06:44 AM   #123
ryanswrx
Member#: 181999
2002 Impreza WRX
nice def. keep us updated Good luck
Old 07-07-2008, 07:46 AM   #124
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Dang fridge went out at home so I was not able to get to this. I will soon though!
Old 07-08-2008, 07:54 PM   #125
ryanswrx
Member#: 181999
2002 Impreza WRX
just an update but I can't find a subaru or honda cluster to get a pin and wire off without having to buy a hole harness. Any one know where to get one please let me know I am going nuts. There are no junk yards near me and local dealership was of no help. I have searched the Internet like crazy. Just send me a pm please I wanna try it this weekend
can we get some mods to start deleting duplicate threads? [27] Political Playground 2 11-05-2008 02:01 AM
STi hare emblem? where can i get one... evoeater8 Interior & Exterior Modification 13 07-12-2006 08:53 PM
can we get something started in RDU???(nc) imprezivSTi04 Mid Atlantic Impreza Club -- MAIC 3 04-04-2006 06:47 PM
02 sti hood scoop?? where can i get one? slaterdrew Private 'Wanted' Classifieds 2 02-06-2004 11:37 AM
lighted keyhole ring, can we get one? makanouchi Interior & Exterior Modification 12 11-22-2002 08:38 PM
