Old 02-26-2008, 09:16 PM   #1
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Default installation auto dimming mirror and compass
HI any one know hot to install auto dimming mirror and compass on 07 sti thanks
subaru222 is offline   Reply With Quote
Old 02-26-2008, 09:51 PM   #2
jezzy
Member#: 121883
I believe you need to twist your mirror arm 90degrees, it'll pop upwards towards the ceiling liner.
The harness you need will be located in the headliner, you might have access if you remove the maplight and follow the harness. Then push it through the front of the headliner where your mirror is located.
Anyone confirm? Should be pretty simple. Then you need to calibrate the mirror as mentioned in your user manual in the glovebox..
I haven't done this yet myself, but I've already installed the harness.. (I had to, 2.5i's don't come with the same harness as the STI..)
jezzy is offline   Reply With Quote
Old 02-26-2008, 10:43 PM   #3
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
OK thanks you very much ya it come with the harness i will try it out any one else do this thanks agian
Old 02-26-2008, 11:26 PM   #4
ezsleeper
Member#: 152517
2005 Sti
thats pretty much it. twist. put the adapter on. used a t20 to tighten it. the plug it into the map light and run it down.
ezsleeper is offline   Reply With Quote
Old 02-27-2008, 07:07 PM   #5
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I installed i tlast night took like 20 min easy install thansk alot guys for all your help.
Old 12-14-2008, 12:53 AM   #6
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Back from the dead. I am about to order an auto dimming mirror with homelink, compass, and temperature for my 2005 WRX. Any tips on the install of this mirror? Seems easy aside from the temperature probe
v8eaterWRX is offline   Reply With Quote
Old 12-14-2008, 06:19 PM   #7
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
nobody?
Old 12-14-2008, 06:40 PM   #8
RedCamber
Member#: 139526
its easy everything is under the head liner, and you get directions with the mirror
RedCamber is offline   Reply With Quote
Old 12-14-2008, 07:52 PM   #9
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Okay cool. Thank you!
'08-'09 WRX Auto Dimming mirror /w compass install lightgod86 Interior & Exterior Modification 7 08-23-2013 10:16 AM
Auto Dimming Mirror w/ compass install? yo14jman Newbies & FAQs 0 10-17-2009 10:55 AM
WTT: My Auto dim mirror with compass plus cash for your Homelink Auto Dim mirror. ScoobyNubieToo! Private 'Wanted' Classifieds 3 06-29-2008 10:39 PM
WTB: 02 WRX Clock and Auto-dimming mirror w/ compass chuckywang Private 'Wanted' Classifieds 3 11-28-2006 04:44 AM
How do you like your Compass/auto-dimming mirror and arm rest ext? sonicsuby Bay Area Impreza Club Forum -- BAIC 5 08-31-2003 04:30 AM
