Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 02-26-2008, 09:26 PM   #1
iRick.
Member#: 158155
Default open pathway for air?
we've all seen it before. and for people like me, i get "what the...does that do?" going in my head
i'm talking about the cut out hole in the headlight...i'm assuming to run air to the intake
what benefits do you get from doing this?
aka why is it done?
thanks
iRick. is offline   Reply With Quote
Old 02-26-2008, 11:22 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
On a track car, it would be to get the freshest, coolest air available into the engine with the least restriction.
Simple.
DLC is offline   Reply With Quote
Old 02-27-2008, 12:23 AM   #3
SpeedbeeqS
Member#: 26664
1999 Impreza 2.5 RS
It's for the "ram air" effect. It will actually raise the atmospheric pressure of the air in the intake and engine. Kind of a supercharger in a way.
SpeedbeeqS is offline   Reply With Quote
Old 02-27-2008, 01:24 AM   #4
iRick.
Member#: 158155
so is it plausible for a street car?
i assume no correct?
i'm basically trying to find the cheapest routes for some gains
Old 02-27-2008, 03:17 AM   #5
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Umm.. The term "street car" to me means that you want to have both headlights.
Subyroo2.5 is offline   Reply With Quote
Old 02-27-2008, 09:55 AM   #6
iRick.
Member#: 158155
yes. thats why i said it prob isn't likely.
couldn't you just remove the right high beam though?
Old 02-27-2008, 10:01 AM   #7
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
And cut a hole in the headlight housing to let the air through?
Old 02-27-2008, 10:28 AM   #8
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
lmao wouldn't make sense.
EdHilario is offline   Reply With Quote
Old 02-27-2008, 10:42 AM   #9
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Not worth it, you wouldnt have any noticeable ram air effect even at highway speeds...
Old 02-27-2008, 02:24 PM   #10
imprexaRS03
Member#: 145883
2008 wrx
psm
^word to that
imprexaRS03 is offline   Reply With Quote
Old 02-27-2008, 02:31 PM   #11
iRick.
Member#: 158155
for sure. thanks for the help. just a pondering thought in my head..nothing more
Old 02-27-2008, 02:57 PM   #12
fgummett
Member#: 172732
2006 Impreza N/A
Yeah... the ram air effect is not worth the effort at daily driver speeds. Mostly the engine is sucking in the air so just make sure it has access to cool and fresh
fgummett is offline   Reply With Quote
Old 02-27-2008, 03:03 PM   #13
iRick.
Member#: 158155
are there other cheap ways to get some more cool air to the stock intake?
Old 02-27-2008, 04:05 PM   #14
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Turbinator!
Old 02-27-2008, 04:13 PM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Pipe it to the fenderwell and call it a day.
If youre extra anal, heat wrap the intake pipes so heat from the engine bay won't somehow penetrate the intake piping
rougeben83 is offline   Reply With Quote
Old 02-27-2008, 11:46 PM   #16
GrundleJuice
Member#: 165749
Buy a NACA scoop from an aircraft parts catalog and cut a hole in your hood and mount the scoop. it will provide some positive pressure @ highway speeds. 80 mph on my CP301 (airplane) blows a lot of outside air into the cabin, enough to make loose paper fly around. kind of like having a window open in your car on the highway. now that would be a lot of work for not a lot of gain. oh yeah, put a airfilter in there somewhere.
Old 02-28-2008, 09:17 AM   #17
fgummett
Member#: 172732
2006 Impreza N/A
RAM AIR. THEORETICAL POWER GAINS
Atmospheric pressure is about 14.7 psi at sea level.
At sea level, the pressure from ram air at 60 mph is about 0.08 psi. This is about 0.5% of atmospheric pressure. On a 200 horsepower engine, a 0.08 psi pressure increase will add about 1 horsepower.
At 85 mph, the pressure from ram air is about 0.16 psi. or about 1% of atmospheric pressure (at sea level). On a 200 horsepower engine, this will add about 2 horsepower.
At 100 mph, the pressure from ram air would be about 0.22 psi, or about 1.5% of atmospheric pressure. On a 200 horsepower engine, this will add about 3 hp.
COLD AIR. THEORETICAL POWER GAINS
Cold air intakes are very important for maximum performance and fuel economy. It is generally accepted that for every 10F temperature drop of intake air, an engine will gain 1% more power. Under hood temperatures can be over 100F higher than outside temperatures, so cold air can be good for a 10% power gain compared to air filters which get hot air from the engine compartment. On a 200 horsepower engine, a 100 F temperature reduction can be good for 20 horsepower.
Cold air provides significantly more power gains than ram air.
Old 02-29-2008, 02:25 AM   #18
littlebhatia
Member#: 170532
07 2.5i
obsidian black
if you dont have factory foglights put a factory foglight housing with no light(ONLY ON RIGHT SIDE) that would work right? They sell them individually at genuinesubaruparts.com
that would give a unique look to the front end as well.
littlebhatia is offline   Reply With Quote
Old 02-29-2008, 02:29 AM   #19
iRick.
Member#: 158155
yeah i've seen it done. anyone have any comments on this?
Old 02-29-2008, 02:51 AM   #20
littlebhatia
Member#: 170532
07 2.5i
obsidian black
Do think you would get better gas mileage taking both fog light covers off and have them act as intakes. Or, are you better off with the aero-dynamicy?
Open rotated stock air box? maniplex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-28-2009 06:32 PM
Registration Open Now for 3/10 Firebird AutoX gdog South West Impreza Club Forum -- SWIC 5 03-07-2002 06:30 PM
open lot for me to run my RC this weekend? ^jynx^ Tri-State Area Forum 3 09-22-2001 07:24 PM
('93-'01) GT3 opening movie for japanase version!!! STi_22B Impreza Forum 0 04-27-2001 01:23 PM
Good price for air gun and air compressor "rental"..for strut bolts GregBolby General Forum Archive 0 08-07-2000 12:06 AM
