Old 02-26-2008, 10:55 PM   #1
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Default Cracked windshield
Back in late December I was on the highway and something hit the upper part of the windshield.
Whatever it was, it left two small divits in the glass and under one of the divits, the glass had a "star" crack.
Now, last week, with the temps going between 20 and 45 degrees Fahrenheit, the star has begun to walk and now there is a crack going vertically up to the edge, and also down.
So, when I go to have it replaced I'm going to remove the following:
wiper arms, cowl cover, interior A-pillars and the leading edge at base of dash (next to windshield).
I figure that I should remove the interior parts because I know that sometimes the glazer can put on a little too much adhesive-sealer and it pushes in and gets on the trim.
Any suggestions?
I have glass coverage with no deductible so that's good.
I just have to make sure I get a factory glass.
Thanks.
Old 02-26-2008, 11:04 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Leave everything as it is...no need for you to do any work. Leave it to the windshield installer. Also, they should replace the windshield molding with the glass.
I have never seen a windshield installed damage any of the parts you have listed, and most do not need to be removed.
And even if they do damage anything, they too, have insurance to cover it.
Depending on your insurance and who they go thru, will depend on whether or not you get factory glass. It can be ordered from a dealer, but most installers don't like waiting for glass to arrive, they like to use their own suppliers.
You can request if from your insurance company, but you might not get it.
RexyGirl is offline   Reply With Quote
Old 02-27-2008, 05:04 PM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
^^12345 I had to have my windshield replaced (JN Phillips) and the installer did not remove any of that stuff or get goop on any of it. Also, the OEM windshields are not that great so there's no reason to insist on an OEM replacement.
Mike Wevrick is offline   Reply With Quote
Old 02-28-2008, 11:10 PM   #4
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Is it helpful to put a little epoxy in a divot to prevent it from opening up?
whtlegacy is offline   Reply With Quote
Old 02-28-2008, 11:24 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
if it hasn't run already, you can get the window repair kits at any auto place that will help. Once it has a runner started, it will eventually go until it finds an edge.
Also, as others have mentioned, subaru OEM glass is crap! aftermarket stuff easily outperforms it.
Old 03-03-2008, 01:30 AM   #6
mostasz
Member#: 170512
2012 WRX
Ice Silver
Do not take anything off the car. Safelite in Hampton, VA did my windshield. Everything is good.
Who is Your insurance company? Allstate doesn't have glass policy..
mostasz is offline   Reply With Quote
Old 03-03-2008, 10:03 AM   #7
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
im in ct too .. had a similar thing happen. i think its all the garbage on our roads. also i think wrx has thinner glass than usual, right?
i went to payless autoglass, im not sure if they are down in that part of the state .. guys did a great job, no problems .. if they are near you and your insurance lets you choose who you use, see if you can get them to do it!
http://www.paylessautoglass.com/
ronaldwrx is offline   Reply With Quote
Old 03-03-2008, 12:31 PM   #8
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I've had many windshields replaced. Don't do anything. The installer will take care of everything. Only thing you may need to do is provide a place that is covered if they come to do it at your place of business. If weather is fine, it won't be a problem. RP
drivin blind is offline   Reply With Quote
Old 03-03-2008, 08:48 PM   #9
jetskibucky
Member#: 136694
07 STI LimitD #242
SPW Stage 2+
One priniciple drving practice would eliminate 99.99% of all broken and cracked windshields, DON"T FOLLOW TOO CLOSE BEHIND SEMI"S OR LARGE PICKUPS! I know it sounds simple, but be aware. When you are thinking, "I know I can get around this slow @ss truck and I'll only be behind him for one second." POW, happens every time.
jetskibucky is offline   Reply With Quote
windshield info for all you with cracked windshields jmott Texas Impreza Club Forum -- TXIC 16 01-16-2002 12:37 PM
('93-'01) Is a cracked windshield under warrenty? Alex RS Impreza Forum 6 06-15-2001 12:59 PM
('93-'01) Cracked windshield Grap Impreza Forum 8 05-18-2001 01:47 AM
9 days old and cracked windshield Mazoku Mid West Subaru Owners Club Forum -- MWSOC 7 05-11-2001 10:41 PM
Cracked Windshield : maybe a dumb question Matt General Forum Archive 4 07-10-2000 07:54 AM
