Old 02-26-2008, 10:57 PM   #1
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Default Does any 2.5i owners have both the light weight pulley and flywheel?
I have read that this combo can potentially cause CEL's due to the engine shaft rev down to fast. First of, I don't know if it is true. Then, on the DBW 2.5i's, the rpm drops down slowly after you lift your foot, so slowly it actually bathers some owners. So does this slowness mean that the light weight combo won't be as problematic on the late model cars?
I only have the LWCP. It feels great. Do any of you have both. If you do, could you share some 1st hand experience please.
Jerry
Jerry Xu is offline   Reply With Quote
Old 02-26-2008, 11:50 PM   #2
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
I read somewhere (2.5RS I think) that you increase your likelihood of throwing the time belt as the rotational mass of the engine has been significantly reduced. Not sure if there's any truth to that. You'll definitely have to re-learn how to drive your car, letting out the clutch with such a light rotational engine mass can make seamless starts a bit of a chore.
LTracer is offline   Reply With Quote
Old 02-27-2008, 12:19 AM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I have a lightweight Exedy flywheel and a Cobb lightweight pulley. Didn't get a CEL after I had them installed.
No timing belt issues either.
Exhaust, however, was another story.
DLC is offline   Reply With Quote
Old 02-27-2008, 12:28 AM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
It's nothing mechanical, it's one of the stupid sensors (I think cps) that goes haywire on some cars if the revs go up or down too quickly; it THINKS there's something wrong on the crankshaft.
It's not 100% either, some cars get it, some cars (like DLC's) don't. Some cars even throws CEL's if you put a lw pulley or lw flywheel too. Just be prepared with the consequences if it does happen.
<--- just has the lw flywheel, no CELs. Brought the car to life IMO.
rougeben83 is offline   Reply With Quote
Old 02-27-2008, 12:28 AM   #5
novacivic
Member#: 117980
2005 sti
wr blue
as long as you dont get an extremely light flywheel you will be ok. and the cel is at idle there is not enough rotating mass and it causes the ecm to think it is missfiring but isn't really because there is a fluctuation in the revolutions.
novacivic is offline   Reply With Quote
Old 02-27-2008, 07:20 PM   #6
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
ive got lightweight pully and a lightweight flywheel. no cel at any time, no problems with exhaust. car revs rather quickly.
atech_rallyrs is offline   Reply With Quote
Old 02-27-2008, 07:23 PM   #7
Jerry Xu
Member#: 36629
07 2.5i
Is it on your NA car? How much does the flywheel weight? Does it idle to low?
Old 02-28-2008, 02:20 AM   #8
ericb269
Member#: 115962
i had no problems with this
ericb269 is offline   Reply With Quote
Old 02-28-2008, 11:59 AM   #9
Jerry Xu
Member#: 36629
07 2.5i
I appreciate your input. Looks like you probably have an 06 or 07 2.5i? If so you're the 1st one that has the combo on a late model car.
Please let me know which FW you have (and yes, its weight). Please also comment on the driving experience with the combo.
Thanks
Jerry
are light weight pulleys and underdrive worth it bereda Normally Aspirated Powertrain 31 06-13-2009 06:03 PM
FS: extendy light weight clutch and flywheel Icon25rs Drivetrain 51 02-23-2008 12:56 AM
pros&cons of having light weight pulley kit+ racing flywheel? qtr_wrx Normally Aspirated Powertrain 15 02-16-2007 09:35 PM
Any '06 2.5i owners have the SPT axleback? grngc8 Normally Aspirated Powertrain 7 07-20-2006 10:07 PM
Is the light weight pulley worth it? TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2001 01:50 AM
