Old 02-26-2008, 11:11 PM   #1
adWRXi
Member#: 130288
Default why does my car wobble?
on new years i slide around a circle and hit a curb in the snow (fresh snow ouch). the front passenger wheel was what hit the curb. the wheel was obviously bent in at the bottom. the car also pulled to the right. so i bring it to meineke thinking i need an alignment. they put it on the rack and see the control arm is bent. i replaced the control arm and the everything was back to normal. for the past week i noticed that after going above 70mph the steering gets very light and the front of the car seems wobbly. can anyone come on with some ideas on why this is happening?
adWRXi is offline   Reply With Quote
Old 02-27-2008, 02:38 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
because you took your car to a muffler shop for suspension work
a6n6d6y is offline   Reply With Quote
Old 02-27-2008, 02:51 AM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You might have bent to strut too.
Counterfit is offline   Reply With Quote
Old 02-27-2008, 04:49 AM   #4
agsais0
Member#: 172985
08 wrx
gray
u must of bent ur crossmember and check all other parts for bendings because thats a lot weight that follows when u hit a curb
agsais0 is offline   Reply With Quote
Old 02-27-2008, 06:19 AM   #5
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Maybe all you need is an alignment.
My car when it is windy feels like the front of the car is floating around when I go about seventy. Maybe that is all that you are feeling?
gtbensley is offline   Reply With Quote
Old 02-27-2008, 06:42 AM   #6
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
Check the tire/wheel to see if they still run true.
Try rotating the tires and see if the problems moves to the rear. You may just need a re balance.
You could have also bent the hub or damaged the wheel bearing.
GDR is offline   Reply With Quote
Old 02-27-2008, 07:53 AM   #7
Pearl Jam
Member#: 145180
2015 Fiesta ST
1994 Camry Luxo Puff
Pearl Jam is offline   Reply With Quote
Old 02-27-2008, 10:15 AM   #8
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Did they balance your wheel? Snow or ice in it?
To summarize, something related to your steering, suspension, wheels, drive train or frame has been compromised.
chapstien is offline   Reply With Quote
Old 02-27-2008, 10:50 AM   #9
bWRX
Member#: 6672
Have any of your neighbors gone missing recently? one of them might be inside your subframe pushing against the control arm at speed down there, trying to get out.
bWRX is offline   Reply With Quote
Old 02-27-2008, 10:51 AM   #10
bWRX
Member#: 6672
Uneven tire wear can make for a vibrating steering wheel at speed, too.
Old 02-27-2008, 09:31 PM   #11
RoadTrippin
Member#: 161175
You answered your own question, if you still have that wheel on there replace it. Bent wheels will cause wobble and eventually cause bearing failure. Dont try to have the wheel balanced because if it is bent no amount of counterweights will help it.
Better to spend the money for a new wheel than even more on replacing your bearings and anything else that could fail if the bearings fail in traffic.
RoadTrippin is offline   Reply With Quote
Loss of power, why does my car feel slower, is it in my head? Hotrodguru Texas Impreza Club Forum -- TXIC 22 03-15-2005 04:04 PM
Why does my car sound like my mom's car? wlchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-27-2003 01:14 AM
Why does my car have a strong gas odor after filling up? Eric SS Normally Aspirated Powertrain 2 09-08-2002 01:40 AM
why does my car rev between gears? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-20-2002 02:27 PM
why does my car suck?? spunky General Forum Archive 4 11-27-2000 11:19 PM
