Old 02-27-2008, 09:16 AM   #1
instinct: decay
Member#: 158727
Default car trouble, need advice
2000 i have a subaru legacy that's been having stall out trouble at speed, however is seems to only happen whem my tank gets lower that halfway full and when i go up hills. i think it's a fuel pressure sensor, but i need to if it could be something else so i can weigh my options. thanks
instinct: decay is offline   Reply With Quote
Old 02-27-2008, 10:07 AM   #2
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Whats a fuel pressure sensor?
Could be anything, fuel filter, aged ignition system etc.
Subyroo2.5 is offline   Reply With Quote
Old 02-27-2008, 02:57 PM   #3
instinct: decay
Member#: 158727
oop, i think i meant regulator. i tried replacing my filter, no change. new plugs, no change. maybe plug wires? highly doubt it but i'm due for some anyways. problem gets progressively worse the less gas in my tank, till eventualy it stalls, backfires and takes off again. the feeling is just like a sudden, progressive loss of power till the (i'm guessing fuel system) is able to get fuel flowing...
Old 02-27-2008, 05:06 PM   #4
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
is it cold where your at?? Ive had a few problems with cars building up ice around the fuel sock. this is ok on a full tank because it floats to the top, but once your fuel level drops, it covers the sock completely. highly doubtful but just an idea, try some isoheat or other water removing fuel additive.
rivman05 is offline   Reply With Quote
Old 02-27-2008, 08:21 PM   #5
instinct: decay
Member#: 158727
no not too cold, but thanks
Old 02-27-2008, 10:53 PM   #6
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Just a guess mind you, but if there was a small hole in the fuel line inside the tank about halfway down, it would mimic those symptoms
Buck
Buck Rogers is offline   Reply With Quote
Old 02-27-2008, 11:51 PM   #7
instinct: decay
Member#: 158727
yeah that could be true, damn would that be a pain to fix...
Old 02-28-2008, 12:00 AM   #8
novacivic
Member#: 117980
2005 sti
wr blue
not really i have seen this before in a legacy it was th part that holds the pump to the sending unit wouldn't hold the pump in place because it broke and allowed the pump to suck air. try pulling the pump and inspecting it. they are very easy to remove
novacivic is offline   Reply With Quote
Old 02-28-2008, 09:15 AM   #9
instinct: decay
Member#: 158727
hmm. i gotcha thats not as bad as i thought
Warranty work needed on a "Brand New Car." Need advice from SoCal people. Jelphree Southern California Impreza Club Forum -- SCIC 49 05-17-2006 12:36 PM
Car trouble, need some help. Zerolapse Normally Aspirated Powertrain 5 01-18-2005 07:35 PM
Car keyed.... need advice EricB New England Impreza Club Forum -- NESIC 46 02-20-2004 05:15 PM
('93-'01) What's my car worth? - need advice omahasubaru Impreza Forum 4 01-15-2003 02:10 PM
Ticket troubles... need advice please. Tree Killa Tri-State Area Forum 18 07-11-2002 06:54 AM
