Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 02-27-2008, 11:05 AM   #1
NewGwrx
Member#: 103645
2011 Subaru Legacy
Default spark plug question on a built 2.5
Ok so i have an axxis power racings 2.5l Sti block in my 02 wrx. I do unfortunately have stock heads with it. I pulled my check engine codes and im miss-fireing in cylinders 2 and 4. Would this be caused by burnt out spark plugs or something wrong with the coil packs.
Also if anyone could suggest a spark plug type for my application then that would be great. I was thinking about going with the NGK platinum tips.
Ken
NewGwrx is offline   Reply With Quote
Old 02-28-2008, 03:38 PM   #2
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Default I doubt its your plugs.
Its pretty uncommon to have both plugs burn out. Its even more uncommon to have two coil packs go bad at the same time. Check the clearance on your valves. Most noteably your exhaust valves. I bet its that.
PSolbergfan is offline   Reply With Quote
Old 02-28-2008, 03:41 PM   #3
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
Oh, I use would denso iridium IK22's. One step colder than the IK20's.
Old 02-28-2008, 04:39 PM   #4
dmross
Member#: 2818
2000 2.5RS
BKR7E
It's a one step colder copper plug. They cost like $1.80 each. I run them for about 2-3000 miles gapped at 0.030. Ron will recommend them too if you ask him.
I've tried a ton of different plugs - Denso iridiums (IK22, IK24 $$$), NGK platinum (PFR7B), etc. and I've had the best results with the BKR7E. You can't beat the price either. Part no. is 6097 at auto parts shops.
dmross is offline   Reply With Quote
Old 03-04-2008, 07:24 AM   #5
NewGwrx
Member#: 103645
2011 Subaru Legacy
Well its been way over my time for spark plugs. Like 10 maybe even 15k since i last replaced them. I just always kept forgetting to do it and never got around to so i know i needa do them now. I wouldnt be suprised if they both burnt out on me.
Also if i were to check the exhaust valve clearance wouldnt that involve pulling the motor?
Spec C intake manifold on a built 2.5?? frayz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-20-2008 10:56 PM
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
Questions on the older 2.5 Rs's Foss General Community 5 09-09-2005 07:30 PM
OBD-II Scan - Where to plug into on a my01 2.5 RS? RigdenZW Texas Impreza Club Forum -- TXIC 15 12-18-2001 04:29 PM
