Old 02-27-2008, 11:36 AM   #1
Malibusa
Member#: 126139
2001 wrx bugeye SADM
blue 95H
Default Newbie log need some opinion
Hi , i just started doing some datalogin and i already posted on osecu.org, but no response, i am trying to learn how to tune and monitor my car, here in Buenos Aires there isn't any good tuner, so i am on my own.
Could someone put his opinion about my log? what i found is that a can't get 100% throttle opening angle , only 85%, and i don't know why (gasoline is Shell V-power 98RON) and my IAM is 15 and not 16.
http://www.romraider.com/forum/topic2851.html
Thanks
Malibusa is offline   Reply With Quote
Old 02-27-2008, 01:32 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I think you posted a bad link.
06rexwagon is offline   Reply With Quote
Old 02-27-2008, 02:18 PM   #3
Malibusa
Member#: 126139
blue 95H
thanks, corrected.
Old 02-27-2008, 03:38 PM   #4
06rexwagon
Member#: 114730
[email protected]
Your ecu has learned to pull 1-2* of timing across a large area. This is in addition to the fact that your IAM is at 15. I would want 0 learned correction if my IAM wasn't 16. Also, your car has learned a 15% fuel correction across the pull. That means that upon a reset you would be running lean. I would clean your MAF sensor if you haven't done it in a while.
Old 02-27-2008, 04:32 PM   #5
Malibusa
Member#: 126139
blue 95H
it has a K&N inbox filter, HKS catback, all the cats in place, and a Greddy BOV, could that help running lean?
thanks again
Old 02-27-2008, 04:34 PM   #6
06rexwagon
Member#: 114730
[email protected]
The bov could cause problems when not in boost if it isn't recirculated and is partially open.
Old 02-29-2008, 10:13 PM   #7
Malibusa
Member#: 126139
blue 95H
i just cleaned the MAF,and made a hard reset, right now the throttle opening angle goes to 100% but the IAM is 8, i reset it again but sticks in 8, do you know why??
thanks
Old 03-02-2008, 02:19 PM   #8
Pablo WRX
Member#: 162901
2002 Impreza WRX
Blue Mica
We need some help please. The iam its still 8.
Does it change during some days or within several miles??
Pablo WRX is offline   Reply With Quote
Old 03-02-2008, 02:49 PM   #9
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I am pretty sure the IAM defaults to 8 after a reset. You have 2 options:
1: drive the car for a while, and it will relearn.
2: Do the quick IAM trick, which will get it to 16 almost instantly. Considering your previous logs, and the timing the ECU was pulling, I would let the ECU increase the value normally.
aboothman is offline   Reply With Quote
hi im a newbie and need some help thanks 93stiImperza Newbies & FAQs 2 05-29-2009 11:10 PM
Newbie and need some advice!! faqmofo Newbies & FAQs 3 02-02-2009 10:15 PM
Going to buy a WRX... I have some options, now I need some opinions. Nismonic Newbies & FAQs 27 12-09-2007 06:04 PM
Hey everybody Im a newbie and need some help subydude80 Newbies & FAQs 1 10-24-2007 04:13 PM
I need some opinions and some help with this setup krazedant Car Audio, Video & Security 0 05-05-2003 12:59 PM
