Old 02-27-2008, 12:14 PM   #1
joelikewhoa
Member#: 39892
Angry Idle fluctuating at startup and at a roll! Fuel cutoff at 5k..
Hey everyone-
Im trying to figure out wat is wrong, i'm planning on taking my car to the dealership but i wanted to see if anyone might have an idea what the prob is?
CEL light is on but i haven't gotten it checked yet, it was on from before though because of the exhaust, never got the spacer for the o2 sensor.
When i start my car it starts off with a fluctuating idle btwn 1400-1900. It does it a few times and then drops down to about 1400 and stays constant which is higher than my normal idle. If im driving it on the road and im going above 35+ and i put the car in neutral while on a roll to a slow, the rpms drop but then start fluctuating until i slow down to about less than 20 miles then it just stays constant at 1400 again as if i wasn't moving.
The car also occasionally cuts off the fuel at about 5k. limp mode?
Anyone ever have this problem? Thanks for your help..
joelikewhoa is offline   Reply With Quote
Old 02-27-2008, 12:50 PM   #2
marcus.raw
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
check the check engine light, a fouled o2 sensor can put the car in limp mode, shouldnt have fuel cut off. if o2 sensor went out your car will run rich
marcus.raw is offline   Reply With Quote
Old 02-27-2008, 01:26 PM   #3
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
The wandering idle sounds a lot like a problem I had a month or two ago. My problem was the IACV on top of the throttle body. When the problem first occurred I was able to clean the IACV and it went away for about a month. When it came back cleaning no longer helped and I had to buy a new one.
First though get your code pulled.
http://forums.nasioc.com/forums/showthread.php?t=781242
brettm is offline   Reply With Quote
Old 02-27-2008, 07:26 PM   #4
joelikewhoa
Member#: 39892
K i just chcked the code, its the IACV for sure. Im going to try cleaning it, hopefully that fixes it cause i dont really have the $_$ to buy a new one.. just fkn crashed my car and had to buy a new jdm headlight and a bunch of other replacement crap... Is it bad to be temporarily driving it with the IACV all dirty? i think my gas milage went down a little though.. thats it.. tahnks for the help
Old 02-27-2008, 07:36 PM   #5
smokeone954
Member#: 166006
2004 WRX
You should also get the gasket and new bots before you attempt to clean iacv.
smokeone954 is online now   Reply With Quote
Old 02-27-2008, 07:40 PM   #6
nick_02_wrx
Member#: 168450
02 subaru wrx
my car is doin the same exact thing.i am throwin a code p1507.i cleaned my iacv and didnt help at all.so more advise would also help me out
nick_02_wrx is offline   Reply With Quote
Old 02-27-2008, 11:31 PM   #7
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
yup, definitely get a new gasket. IACV is $215 from http://www.thekingofparts.com. The bolts are a good idea too but not necessarily mandatory (I was able to reuse the bolts, I was VERY careful when removing them).
Its really pretty easy to replace.
Old 02-28-2008, 03:44 PM   #8
joelikewhoa
Member#: 39892
should i even waste my time trying to clean it, is there a possibility that it May fix it?
Old 02-28-2008, 04:03 PM   #9
joelikewhoa
Member#: 39892
Old 02-28-2008, 04:51 PM   #10
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Whats more valuable to you? 30 minutes of your time or $215. It doesn't hurt to try cleaning it. I tried cleaning it first and it fixed it for about a month.
Idling rough and stalling at startup? bigdweeb Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-03-2009 08:35 PM
Need HELP! Fuel cutoff at 0 psi!!! 13rus Newbies & FAQs 8 01-24-2007 08:15 AM
Running like crap at startup. Barely idling. Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-01-2005 10:14 PM
Idle going up and down at startup, any ideas? Robmat Normally Aspirated Powertrain 8 09-14-2002 01:13 PM
Fuel cutoff at 110MPH? Possible air starvation with K&N cone filter? Sean New England Impreza Club Forum -- NESIC 13 05-12-2002 02:31 PM
