#1 |
Member#: 112765
Vehicle:2005 Impreza WRX Crystal Grey Metallic |
Was wondering if someone has had this problem before or knows what it could be...
I'm just driving at a fairly normal speed, when all of a sudden, my car "hiccups". The revs drop almost 1,000rpm, and feels like my car has hit a wall. This hiccup is less than a second long, and then the car drives normal as if nothing has happened. This has happened twice. My theory is air/water in the fuel lines, because it has been very cold outside and there could be possible condensation in the gas tank. Any ideas on what could have caused this, and how I could resolve this would be much appreciated!
#2 |
Member#: 113271
Vehicle:2006 STi Obsidian Black Pearl |
Could it be your A/C compressor engaging ? If that's not it, I'm not sure what to tell you !
#3 |
Member#: 112765
nope, not the AC. Even if it were a faulty wire or something with the A/C...it wouldn't have been that sevre.
When this "hiccup" happens, its scary...feels like my car has thrown a road or something...not that i know what that would feel like, but i'm just saying its not the slight loss in power you get from turning the AC on. Thanks though! |
#4 |
Member#: 90347
AKIC
Vehicle:2013 BRZ & Imp 2.5RS Yamaha FZ8 |
Only felt something like once in someone's car with boost creep and that was under load... not driving along.
#5 |
Member#: 47646
Vehicle:0211 RallyWagon DGM Sedan |
Are you driving under steady boost at the time? Could be, with the cold weather, you run knock just at the edge of operation so it pulls a lot of timing for a little while.
Its not condensation in the gas line. What mods do you have? |
#6 |
Member#: 94283
NESIC
Vehicle:'05 OBXT Stage 2 Min bil är svart |
My car does this when it's snowing. It feels like fuel cut, but I think it's an airflow problem. I have no idea what causes it.
#7 |
Member#: 131268
Vehicle:.... GOD........ |
Could be a slight miss by one of the plugs...my car did this before, but threw a misfire code...
Patrick |
#8 | |
Member#: 112765
TurboXS Stealth back mated to the Prodrive Axle back SPT Intake (please don't jump to conclusions and blame this as the source )This happens under load. first time was moderate load, 2nd time i was flooring it in 2nd gear. It is random, so i cannot replicate it whenever i wish, otherwise i'd take a datalog. All my data logs look normal...just running a bit rich. |
#9 | |
Member#: 16517
NESIC
Vehicle:09 WRX |
I have been trying to figure out for the past few winters its really strange![]() |
#10 | |
Member#: 112765
I was thinking it could be a plug misfiring... Could changing them out for 1 step colder help? |
#11 |
Member#: 94283
NESIC
#12 |
Member#: 112765
bump!
Does anyone else have a huge problem starting their Suby in cold (below freezing) weather? It took me about 5 attempts to start my WRX this morning...just keeps cranking and cranking... ![]() would this be a battery or starter issue? |
#13 | |
Member#: 131268
Also, I have always heard you don't need to run colder plugs if you are on the stock td04 turbo. It sounds like you could have a coil / ignition problem since you car has problems starting too. Patrick |
#14 |
Member#: 139983
NESIC
Vehicle:2006 WRX Sport Wagon WRB |
My 06 wagon does this occasionally when I am driving slow 30mph or so and its snowing out. Usually I will be holding speed in 3rd gear, but under some load going up hill, and the car just bucks hard once and then is fine. Its probably happened 3 times in the last year. I've been meaning to post on here about it. Its never thrown a CEL.
#15 | |
Member#: 76817
NESIC
Vehicle:2005 WRX Black |
#16 |
Member#: 155358
Vehicle:2008 Forester Steel Silver |
^^ did you guys ever check for the code with a code reader. even though a cel never came on a code may still be stored.
#17 |
Member#: 171561
Vehicle:2002 WRX wagon blue |
it sounds like an air problem to me. That is exactly what would happen if your throttle body suddenly closed or air flow suddenly stopped or decreased significantly. It isn't the cold because everyone is saying it happens when it is snowing, not just when it is cold. My assumption is that since snow is real light that it gets sucked to the cold air easier than rain. This could cause water to be getting in and likely consfusing the ecu at some point and closing the throttle on you or decreasing gas flow significantly. This is just a theory, maybe it is ridiculous but it has to be the snow, not the cold
#18 |
Member#: 38400
Vehicle:2004 WRX Wagon DRZ400SM |
Not jumping to conclusions, but for lack of any other solutions perhaps try replacing the stock intake. You won't really lose any power and it might solve your problem.
#19 | |
Member#: 112765
It didn't happen when it was snowing... I think its the cold. |
#20 |
Member#: 244114
South East
Vehicle:2005 subaru |
Has anyone isolated this issue??
I have had my subie replicate this exact behavior at random, while under moderate load, and snowing. throws no visible cell.. |
#21 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
#22 | |
Member#: 250152
#23 |
Member#: 244114
South East
#24 |
Member#: 160725
NESIC
Vehicle:2005 STi WRB sittin on GOLD |
I've had it happen a couple of times this winter as well. I have no idea what the cause of it is but it bugs the **** out of me.
Still looking for an answer. |
#25 |
Member#: 45076
Vehicle:2004 Stg2 Wagon 4eat Silver |
Did you try some dry gas, just in case it was from water in the tank. If you run the tank low condensation can build up.
| Thread Tools | |
| Display Modes | |
| Any young people with kids? Or had kids at a young age with advice? | stevey323 | Off-Topic | 30 | 02-26-2007 12:22 PM |
| had a buddy get a bad ticket any advice | WRX_Nick | Texas Impreza Club Forum -- TXIC | 24 | 03-20-2006 08:58 PM |
| More banking advice. Credit card, never had one, want to build credit. | 2.5RSMatt | Off-Topic | 63 | 09-27-2004 11:24 PM |
| Tire had a nail, need advice for next track day | ilara72 | Tire & Wheel | 2 | 09-10-2004 07:29 PM |
