Old 02-27-2008, 09:08 PM   #1
Venom911
Member#: 136182
2006 WRX
Default I have 2 problems with my WRX plz help!
1.have a 06 WRX and here latley the cars' engine temp gauge goes up to hot but when you start driving it will go back to normal...
2. Also my horn and hazards do not work, so i checked the fuse it was blown so i changed it and it keeps blowing over and over when i use the horn.
Does anyone have any suggestions to these problems....Thank you for your time.....
Venom911 is offline   Reply With Quote
Old 02-27-2008, 09:13 PM   #2
WizardGandoff
Member#: 36667
04 DrgSmugrXps
Blackwiththablingblingold
check the coolant
WizardGandoff is offline   Reply With Quote
Old 02-27-2008, 09:42 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
since the temp goes back to normal when you drive it sounds more like an airflow issue over the rad than a coolant level / circulation issue
add to that your other electrical issues and I would think it's most likely the fan is not running - check the fan fuse(s) too
UkNuck is offline   Reply With Quote
Old 02-28-2008, 03:31 PM   #4
Venom911
Member#: 136182
2006 WRX
Yeah im thinking the same thing now that u mentioned the fan issue it just makes since you know, what can be causing these fuses to blow all of a sudden think a wire is grounding out somewhere or something!
2 Problems with my car, Need help please! subiee sTi Newbies & FAQs 4 04-28-2010 11:00 PM
PROBLEM WITH MY WRX STI - please help me bradsti Newbies & FAQs 33 03-28-2008 06:09 PM
having problems with my 96...need help fast zer0321 Service & Maintenance 1 07-09-2006 09:28 PM
03 wrx problem with the ecu? plz help pizdets Commercial ECU Reflashes 1 06-08-2006 12:50 PM
Having some problems with my WRX Subarubrim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-19-2005 10:36 PM
